slook(at)mchsi.com Guest
Posted: Sat May 08, 2010 3:29 pm Post subject: Aileron balance weight bolts |
I just completed the first of my aileron updates and in the course of
playing with the balance weights couldn't find four bolts that would
fit the job.
I'm surprised there are not four of a kind AN3 bolts to use.
What has been the required bolt to hold weights and was it in the upgrade kit?
I've considered the possibility that the two AN3-37 are for the
"light" aileron and the two AN3-30s are for the aileron with trim
{which I didn't install}.
If this is discussed in the notes or drawings, I missed it...
Steve
Steve Look
Monticello, IL
601XL
"Dogs have owners, Cats have staff"
DaveG601XL
Joined: 27 Oct 2006 Posts: 351 Location: Cincinnati, Oh
Posted: Sat May 08, 2010 5:59 pm Post subject: Re: Aileron balance weight bolts |
Steve,
The bolts I got in the upgrade kit did not work for me either. I had to buy bolts about 1/4 to 1/2" shorter. I guess Zenith packed in the bolt sizes that worked for them. My ailerons are polished and not painted so they must have weighed less. As long a they balance out, use whatever works.
Good luck,
_________________ David Gallagher
Cincinnati, OH area |
smgores
Posted: Sun May 09, 2010 6:34 am Post subject: Re: Aileron balance weight bolts |
Steve,
I asked Roger at Zenith the same question.He said the left aileron with the trim tab is heavier and will require more weights so they included 2 longer bolts(An3-37A).The right side (lighter) requires the 2 shorter, AN3-30A bolts.
If you don't have the trim tab,you will have to improvise,either get 2 shorter bolts or use some type of spacers.
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sun May 09, 2010 7:35 am Post subject: Aileron balance weight bolts |
Steve,
I have done two mods now.
On the first one, I bought shorter bolts.
On the second, I used a 10-32 die and cut the threads so the longer bolts
would work.
I guess from Zenith's view, they do not know what your ailerons weigh so
they gave bolts the would work with enough spacers attached.
Floyd Wilkes
601XL flying again.
_________________ Floyd Wilkes |
mhubel
Posted: Fri May 14, 2010 5:01 am Post subject: Aileron balance weight bolts |
Steve,
I filled the tubes with lead. The right side to a depth of 6 inches
and the left side (with the trim system) to 7 inches. Then I only needed
2 plates on the right side and 4 on the left side to balance. This was
then small enough to fit through the holes as specified in the drawings.
Of course much smaller bolts were used, AN3-15 and 16 sizes.
I didn't like the idea that it would be difficult or almost
impossible to adjust the balance or for that matter even remove the
ailerons.
If I had to do it all over, I would use a 1 inch or 1 x 3/4 tube
and use all lead weight, no side weights.
On 5/8/2010 7:28 PM, Stephen R. Look wrote:
fit the job.
upgrade kit?
Steve
Steve Look
Monticello, IL
601XL
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com
978-443-3955
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
