Posted: Thu Apr 29, 2010 7:34 am Post subject: IVO Prop Current Limiter/Electronic Circuit Breaker |
It took a bit more 'praying' than I anticipated
and I'm only 99.6% sure that my confidence in
having met design goals have been met. But I'll
invite other 'electron herders' on the List
to review the following and see if I've stubbed
my toe anywhere:
See:
http://aeroelectric.com/Pictures/Schematics/IVO-Prop_Pitch_Controller.pdf
Design goals:
Provide absolute current limit on the order of 9A:
Q114 is a power FET that saturates with bias
through R104, R105 and D109 when power is applied
through "M" connections that sense motor power.
Voltage drop across R117/R118 is monitored through
R116 causing Q115 to turn on when drop across the
R117/118 exceeds Vbe of Q115. This is approx .6
volts. When Q115 turns on, it starves Q114 of gate
drive and causes it to become a constant current
generator with calibration set by the combination
of R117/R118.
Any time the constant current loop is active,
LED D109 will be illuminated. D109 will flash
each time the prop pitch motor is energized
and the system becomes an active inrush current
limiter.
Limit the duration of the current limit mode to
100-200 mS whereupon the system goes open circuit
and removes power from the motor:
At any time the current limiter is active,
Q115 collector current through R105 will turn
on Q103 causing the collector to pull up to
the supply rail. This causes C112 to charge
through R106 until zener D110 conducts at about
8V. This event will occur approximately 120 mS
after onset of current limit.
When D110 conducts, it pulls the base of Q115
more positive causing the Q115/Q103 pair to
"latch up" not unlike an SCR. When the latching
event occurs, the collector of Q115 pulls to
a few millivolts above ground depriving Q114
of all gate drive.
Normal operation:
D109 will flash each time the motor control switch
is closed due to motor inrush current being
electronically limited. D109 will also flash a
bit longer (about 120 mS) when the prop pitch motor
reaches the mechanical stop and the current limit is
invoked.
As long as the prop pitch motor is powered
D108 will be illuminated. When the prop
pitch system reaches a mechanical limit and
the control switch is NOT relaxed, D019 flashes
for about 120 mS and D108 goes dark.
Releasing the motor control switch removes
power from the latching loop and discharges
C112 through R119, R104, BC junction Q103,
and R106.
The system spends so little time in I-limit
mode that Q114 does not require a heat-sink.
D109 and D108 staying on together indicates
a malfunction and the motor control switch
needs to be released within a second or so
to avoid over-heat damage to Q114.
Don't anyone run out and build this yet. Let's
thrash the bushes a bit for rats.
dennis.glaeser(at)hp.com Guest
Posted: Fri Apr 30, 2010 8:43 am Post subject: IVO Prop Current Limiter/Electronic Circuit Breaker |
The reed switch circuit is already in place and operational, so my initial goal has been achieved!
I already have the parts for the first design - only half assembled at the moment (having to work for a living gets in the way of the 'important stuff'
The latest design literally dummy-proofs the operation of the IVO, and will undoubtedly increase the MTBF of the motor and gearbox by limiting the motor electrically rather than mechanically jamming the gears!
I can follow your description on how it works, but my knowledge falls short of being able to analyze and comment. When you declare the updated circuit complete, I'll build it (already have most of the components and let you know how it works!
It was me who was doing the 'praying' for a solution! You did the 'perspiration' part - per Thomas Edison.
Dennis
my toe anywhere:
See:
N20DG
Joined: 02 Jan 2008 Posts: 61 Location: lancaster, texas
Posted: Fri Apr 30, 2010 4:31 pm Post subject: IVO Prop Current Limiter/Electronic Circuit Breaker |
Dennis
Do you have a circuit diagram/photos of your installation that you can share??
Dick
In a message dated 4/30/2010 11:44:48 A.M. Central Daylight Time, dennis.glaeser(at)hp.com writes:
| Quote: | --> AeroElectric-List message posted by: "Glaeser, Dennis" <dennis.glaeser(at)hp.com>
Dennis
my toe anywhere:
See:
========================= Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
Joined: 28 Mar 2008 Posts: 1974 Location: Riley TWP Michigan
Posted: Mon May 03, 2010 4:13 am Post subject: Re: IVO Prop Current Limiter/Electronic Circuit Breaker |
| Quote: | Dennis
share??
Dick |
Dick,
Did you see this picture that Dennis posted?
http://forums.matronics.com/viewtopic.php?t=70557&sid=1bdd10db5d3c9ab625b4465b86c3de08
No modification is required to the existing prop motor circuit. Just find some slack in a wire going to the motor (hot or ground doesn't matter) and wrap 3 turns around a reed switch. Then connect the reed switch in series with a power source and indicator LED. The reed switch is made of glass and will break easily. It should not be stressed by the lead wires or while wrapping with turns of wire. Also, a heat-sink should be used if soldered because the switch will be damaged by heat.
Joe
_________________ Joe Gores |
N20DG
Posted: Mon May 03, 2010 8:31 am Post subject: IVO Prop Current Limiter/Electronic Circuit Breaker |
Joe
Dennis sent me some additional photos and a wiring diagram off line showing what I wanted to know.
I will be modifying the wiring some when I get to that project
Dick
In a message dated 5/3/2010 7:26:59 A.M. Central Daylight Time, fran4sew(at)banyanol.com writes:
| Quote: | --> AeroElectric-List message posted by: "user9253" <fran4sew(at)banyanol.com>
| Quote: | Dennis
share??
Dick
Dick,
Joe
Joe Gores
http://forums.matronics.com/viewtopic.php?p=296570#296570===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp; ===================================================
