kjohnsondds(at)yahoo.com Guest
Posted: Tue Apr 27, 2010 8:48 am Post subject: stopping engine |
Aircraft Electrical Gurus,
This subject has been presented briefly recently, but I was looking for the opinion of several. This may have an electrical solution of not. The question is: "What is the best way to stop your aircraft engine?
In the recent past, at this site I have seen recommended a switch to the fuel pump. Turn off the fuel pump and eventually the engine stops.
I rent Cessna 172 and the prefered way to stop the engine is to minimize both the throttle and richness knobs by pulling them out. Technically, what exactly does this do? Could I place a simple ball valve on my fuel rail and phsically close it? Is this what I do on the Cessna 172? The Cessna fuel is fed throught a carburetor and my engine is fuel injected. Does that make a difference?
On the automobile engine, when we turn off the engine, are we just closing the switch that provides current to the spark plugs, or is something else involved? Is this what should be done for the aircraft engine?
Thanks for your advice.
Ken Johnson
bgray(at)glasair.org Guest
Posted: Tue Apr 27, 2010 9:22 am Post subject: stopping engine |
In an Aviation carb’ed or injected engine, the shutoff method is the same- turn off the fuel. The reason for this is to prevent a fuel/air mixture being left in a cylinder. If a P lead wire is broken and the propeller is turned, it could fire and injure someone. From your question I assume you’re installing an auto engine.
Auto engines kill the spark. Some might also kill the pressure in the fuel rail. You’re going to have to blasé your own trail here.
Bruce
www.Glasair.org
Neal.George(at)hurlburt.a Guest
Posted: Tue Apr 27, 2010 9:45 am Post subject: stopping engine |
Depends on the engine and the application. On most certificated systems,
pulling the mixture shuts off the fuel flow in the metering device
(injection servo or carb) - thus the term Idle Cut-Off (ICO). The fuel
servo manufactured by Airflow Performance, popular among the experimental
crowd, DOES NOT completely stop fuel flow at the low idle stop. Airflow
Performance incorporates a valve to shut off fuel between the servo and the
distribution spider.
Generally speaking, to shut down an aircraft engine we turn off the fuel
supply to starve the engine. The idea is to get the fuel out of the intake
system so that a hot cylinder or un-grounded mag won't fire unexpectedly and
hurt someone. I've had more than one airplane fire a cylinder when
positioning the prop after a run-up for maintenance - with the mags off and
keys in my hand.
Just turning off the ignition is no guarantee and leaves fuel in the system.
Hot aircraft engines will diesel, and the higher the compression, the more
likely it is to happen.
Neal
A&P/IA
 Download |
| Filename: |
smime.p7s |
5.09 KB |
| Downloaded: |
488 Time(s) |
rlborger(at)mac.com Guest
Posted: Tue Apr 27, 2010 9:59 am Post subject: stopping engine |
| Quote: | Ken,
What kind of engine are you using or planning to use? Makes a difference.
My Rotax 914 is shut down by shorting the ignition module output to ground preventing spark. This method ensures you know that the ignition is properly grounding.
Traditional aircraft engines such as Lycoming and Continental are shut down by setting the throttle to idle and pulling the mixture control to Idle/cutoff. This shuts off the fuel going into the engine from either the carb or F/I system. Makes the engine safe as described by Bruce Gray.
Auto engines are shut down by turning off the key which removes the electrical source from the ignition, computers & fuel pump, shutting things down all over the place.
There are valid reasons for each method. You should determine what would be best for your engine based on the manufacturers recommendations. If you are doing an automotive conversion, I guess you'd use the automotive method.
Bob Borger
Europa XS Monowheel, Rotax 914 w/ Intercooler, Airmaster C/S prop.
Building a Little Toot Sport Biplane.
On Tuesday, April 27, 2010, at 11:45AM, "Kenneth Johnson" <kjohnsondds(at)yahoo.com> wrote:
Ken Johnson
jon(at)finleyweb.net Guest
Posted: Tue Apr 27, 2010 10:18 am Post subject: stopping engine |
Hi Ken,
I too have seen that discussion. For clarity - all of my comments are in regards to an automotive multi-point EFI engine (not to be confused with any carbureated engine or any mechanical fuel injection system).
With my flying Subaru EJ-22, the ignition switch cuts power to the ECU (Real World Solutions EC2), injectors, and coils. Has worked fine for 300 hours.
I believe (but am not 100% positive) that most modern automotive EFI systems all shut down the ECU, coils, and injectors when switched off. Talking specifically about automotive EFI engines, I see no value in starving the engine for fuel. I am told (but have no statistics or tests to prove) that this can harm a high pressure EFI fuel pump (running it dry).
Jon
mprather(at)spro.net Guest
Posted: Tue Apr 27, 2010 10:56 am Post subject: stopping engine |
I think it's worthwhile to be precise (reduce ambiguity) in matters such
as this.
I believe many (most?) light airplane POH's specify that engine shutdown
is accomplished by moving the mixture control to idle-cutoff (ICO).
Usually this causes the engine to stop running fairly rapidly - in a
matter of a couple of seconds. Selecting rich mixture and hitting the
starter usually allows the engine to restart very quickly/easily.
Certainly many airplanes still have Stromberg carbs (or similar) which
don't have a mixture control effective enough to cause "idle-cutoff". I
have ridden with pilots of such airplanes who only use the magneto
switches to stop the engine. One benefit of this procedure is that you
check to see if you have a "hot mag" on each flight. If the engine stops
dead, you can be somewhat certain that the p-lead circuit is in working
condition.
Most (all?) light airplanes also have at least one fuel control valve
(selector), which can also be used to stop the flow of fuel to the engine.
On the carbureted engines that I have operated, closing this fuel valve
does eventually stop the engine, though depending on how low the throttle
setting is, it might take a few minutes for the float bowl in the carb to
get low enough to cause the engine to lean-out and die. Usually when I
pull up to a parking spot, I don't feel like waiting for the carb to
empty, so I never do this.
If the fuel valve was turned off, on carbureted airplanes with gravity
feed fuel, turning on the fuel valve and waiting a few moments will refill
the carb float bowl, at which point the engine may be restarted. For an
airplane with pump driven fuel, turning on the electric pump will allow
restarting much faster/sooner than if only the engine driven pump is used.
Turning on the electric pump is often in the engine start procedure.
In an airplane that depends on a high pressure electric pump, I'm not sure
it makes sense to "turn off the fuel," if that implies closing some kind
of fuel valve. It might make more sense to turn off the electric pump(s).
My impression of automotive fuel injection is that turning the key off
stops power to both the ignition and the fuel pump(s). This leaves
burnable mixture in the cylinders and intake manifold. In an airplane,
this method of stopping the engine increases the risk of unexpected prop
motion. Turning the key to run causes the fuel pump(s) to run until the
specified system pressure is reached, at which point the pump(s) turn off.
One other thing I have noticed is that some electronic ignition systems
may fire the spark plugs one time when the system is energized. This will
likely cause the prop to turn if there is a burnable mixture in the
cylinders. In fact, my Varieze has such a system. A number of times I
have actually had the engine start spontaneously because of this effect -
prime with accelerator pump, walk the prop to pull fuel into the
cylinders, turn on the ignition, and away it goes. So, magnetos aren't
the only things that will fire unexpectedly. In fact, a mag without an
impulse couple isn't likely going to spark on its own..
So to get back to the original question, I agree that stopping the fuel
delivery in some way is generally a good idea. I think turning off the
pumps while leaving the ignition firing is the best bet, as that should
dump fuel system pressure, and yield the least burnable mixture in the
cylinders.
With all that said, everyone working around aircraft should be very
careful of the propeller, whatever method is used to stop the engine.
Pilots need to be vigilant to not allow anyone to haphazardly move the
prop or stand in the prop arc.
Matt-
[quote] In an Aviation carb’ed or injected engine, the shutoff method is the
Bruce
www.Glasair.org
Posted: Wed Apr 28, 2010 8:12 am Post subject: stopping engine |
Hi All,
I would like to thank all who responded.
It would seem the best reason to stop an engine with fuel starvation would be to prevent possible danger from the prop. If a prop was repositioned, fuel in a cylinder might ignite, which in turn would turn the prop and that might hurt someone. In an automobile, if dieseling occurs, no is hurt. The car is in "Park" or "Neutral."
I have a Mazda rotary engine I will be using for my airplane. Eventhough this is not a piston engine, the threat of danger from the prop with fuel left in the burn chamber still exists. For safety reasons, fuel starvation would be the best way to stop the engine. Turning off the ignition will stop current to the spark plugs, coils, and will turn off the high pressure fuel pump. However, it would seem that turning off the fuel pump before turning off the ignition would be a safer way to eliminate fuel from the burn chambers.
By using a valve on my fuel rail, I could stop fuel. However, the fuel pump would still be working and could be damaged. Again, it would seem that switching off the fuel pump before the ignition might be the best solution.
If anyone has a better solution, please post.
Ken Johnson
Sent: Tue, April 27, 2010 1:54:43 PM
Subject: RE: stopping engine
--> AeroElectric-List message posted by: "Matt Prather" <mprather(at)spro.net (mprather(at)spro.net)>
as this.
condition.
cylinders.
Matt-
Bruce
www.Glasair.org
mikef(at)apexconsultingse Guest
Posted: Wed Apr 28, 2010 8:42 am Post subject: stopping engine |
I have a GEO engine, EFI is the EC2 system, with 2 fuel pumps going into a
single line, then to the fuel rail. In that line is a 3 way valve that I can
use to bypass the rail and spill back into the fuel tank. Turning off the
engine by starving the fuel, yet keeping the pumps running smoothly works
quite well.
On Wed, Apr 28, 2010 at 10:11 AM, Kenneth Johnson <kjohnsondds(at)yahoo.com>wrote:
[quote] Hi All,
burn chambers.
Ken Johnson
*To:* aeroelectric-list(at)matronics.com
*Sent:* Tue, April 27, 2010 1:54:43 PM
*Subject:* RE: stopping engine
as this.
condition.
bbradburry(at)bellsouth.n Guest
Posted: Wed Apr 28, 2010 9:11 am Post subject: stopping engine |
Ken,
You didn’t say if you have fuel injection or a carb on your Mazda rotary, but if you have FI, you can shut off the injectors and the engine will immediately stop due to fuel starvation. No fuel will be left in the rotor faces. The fuel regulator will then immediately open up to keep the fuel pressure at your set point, so the fuel pumps will not be adversely affected. In fact, this is the condition you will have the regulator and pumps in when you set the fuel pressure. This is the way it is designed to work so no damage will ensue. After the engine stops you can leisurely shut everything else down. There will be no fuel in the rotors so there will be no danger if you want to move the prop for whatever reason.
If you have a carb, well, you are on your own.. :>)
Bill B
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Kenneth Johnson
Sent: Wednesday, April 28, 2010 12:11 PM
Subject: Re: AeroElectric-List: stopping engine
Hi All,
Ken Johnson
Subject: RE: AeroElectric-List: stopping engine
as this.
condition.
cylinders.
Matt-
> Bruce
> www.Glasair.org
Posted: Wed Apr 28, 2010 9:54 am Post subject: stopping engine |
Ken,
If you are building a Mazda rotary for your plane you should really look into the rotary forum. There is a tremendous amount of knowledge available there. Come join us!
http://mail.lancaironline.net:81/lists/flyrotary/List.html
How to subscribe is at the lower right corner.
Bill B
Hi All,
Ken Johnson
as this.
condition.
cylinders.
Matt-
> Bruce
> www.Glasair.org
Posted: Wed Apr 28, 2010 10:09 am Post subject: stopping engine |
Bill,
My only concern about this (and it's probably a remote concern) is that if
you have a leaking injector, it may dribble fuel into the engine after
shutdown. Otherwise, this is very much analogous to pulling the mixture
to ICO on an aircraft carb or mechanical injection.
Matt-
[quote] Ken,
rotor
to
shut
be
Bill B
_____
Johnson
Subject: Re: stopping engine
Hi All,
that
The
starvation
pressure
burn chambers.
pump
solution.
Ken Johnson
_____
<mprather(at)spro.net>
as this.
condition.
cylinders.
Matt-
> Bruce
> www.Glasair.org <http://www.glasair.org/>
wschertz(at)comcast.net Guest
Posted: Wed Apr 28, 2010 7:12 pm Post subject: stopping engine |
I have Mazda Rotary with EC-2 and electric fuel pump. shut down consists of shutting off the fuel pump, engine dies quickly, and there is no residual pressure in the lines to leak past the injectors and cause flooding or richness on the start.
Bill Schertz
KIS Cruiser #4045
N343BS
Phase I testing
Sent: Wednesday, April 28, 2010 12:09 PM
Ken,
Bill B
Hi All,
Ken Johnson
as this.
condition.
cylinders.
Matt-
Bruce
www.Glasair.org
Posted: Thu Apr 29, 2010 12:24 am Post subject: stopping engine |
A couple of thoughts.
With electronic automotive injection, killing the injector power will
stop the injectors, but the fuel rail will still be pressurized. If an
injector is a bit leaky, fuel can still make it to the combustion
chamber after shutdown. Some guys provide a tiny bleed hole that
bypasses the regulator so the fuel rail will depressurize a minute or so
after shutdown (probably overkill, but there it is).
On the subject of traditional a/c engines with carbs, there is a
possible misconception buried below (I hate RPN posting....). I read
about the following somewhere & was surprised, but cutaway drawings of
some a/c carbs seem to support the story. I believe that the McNeilly
(sp?) leaning block for Holley carbs works this way, too, and the
technique has been used to lean some motorcycle carbs on alternative
engines. Here's the 'story':
On at least some a/c carbs, the mixture control is actually controlling
the vent to the fuel bowl on the carb. Pulling mixture to idle cutoff on
those carbs just causes the 'head' (air pressure+fuel weight) on the
fuel in the bowl to drop until it equals the absolute pressure in the
venturi, stopping flow. Once the engine stops, pressure can equalize at
ambient. If the prop spins after that happens, and the mags are on, the
engine can fire because there's still fuel available & there's now a
(short term) normal 'head' of ambient pressure on the fuel in the bowl.
On 4/28/2010 11:32 AM, Mike Fontenot wrote:
[quote] I have a GEO engine, EFI is the EC2 system, with 2 fuel pumps going
into a single line, then to the fuel rail. In that line is a 3 way
valve that I can use to bypass the rail and spill back into the fuel
tank. Turning off the engine by starving the fuel, yet keeping the
pumps running smoothly works quite well.
<kjohnsondds(at)yahoo.com <mailto:kjohnsondds(at)yahoo.com>> wrote:
Hi All,
or "Neutral."
Ken Johnson
*From:* Matt Prather <mprather(at)spro.net <mailto:mprather(at)spro.net>>
<mailto:aeroelectric-list(at)matronics.com>
matters such
as this.
shutdown
"idle-cutoff". I
that you
engine stops
working
condition.
engine.
valve
throttle
carb to
when I
will refill
For an
allow
is used.
not sure
some kind
pump(s).
airplane,
unexpected prop
until the
turn off.
systems
This will
times I
effect -
aren't
without an
the fuel
off the
should
cylinders.
Matt-
fuel/air
in the
> Bruce
Matt,
One other consideration about the Mazda rotary vs a typical piston airplane
engine is the blade rotation involved. If either whacked you in the head,
you would probably not be real happy about it. However...
The 4 cycle piston engine will rotate the prop 180 degrees on one power
stroke, but the rotary will only rotate the crankshaft 120 degrees if all
three rotor faces fire and only 40 degrees if one face fires. Since the
rotary has a PSRU on it which is probably either 2.17 or 2.85 to 1, this
would further reduce the prop movement to 18.5 to 14 degrees depending on
which PSRU.
The rotary would give you a good whack, but you would have to be standing
close to the blade for it to hit you.
Bill B
Posted: Thu Apr 29, 2010 4:23 am Post subject: stopping engine |
Matt,
An injector with much of a leak will show up on the way the engine performs,
but some have installed a small orifice (.050") in a bypass line around the
fuel pressure regulator. This small leak is not more than the pump and
regulator can handle, but when the pump is turned off, the line pressure
quickly bleeds off into the tank return line. This would stop any possible
problems from a leaky injector.
Bill B
Ed Anderson
Posted: Thu Apr 29, 2010 5:08 am Post subject: stopping engine |
Ken, you didn’t say,
But if you are using electronic fuel injectors with your rotary engine, a power cut off switch to the injectors will instantly stop injection even with your pumps still running. That is the method I use for shut down and there is no fuel left in combustion chamber nor any potential to damage the fuel pumps by running them dry.
http://www.flyrotary.com/
You may want to consider joining our FlyRotary list – there are many flying who have solved most problems you are likely to encounter and the information is there.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://www.andersonee.com
http://www.dmack.net/mazda/index.html
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
http://www.rotaryaviation.com/Rotorhead%20Truth.htm[/url]
Hi All,
Ken Johnson
as this.
condition.
cylinders.
Matt-
> Bruce
> [url=http://www.glasair.org/]www.Glasair.org
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
Posted: Thu Apr 29, 2010 12:15 pm Post subject: stopping engine |
We're off in the weeds a bit as far as Aero Electrics..
I'm pretty sure that the Marvel Schebler carbs pass all of the fuel
through the main metering valve - even the idle circuit. Thus, pulling
the mixture to ICO on these units does, in fact, positively stop fuel
flow.
The Stromberg carbs, and those commonly installed on Rotax engines work as
you suggested. I believe these carbs are known variously as "altitude
compensating".
My impression of the Manual Mixture Control for the Holley is that it
works much like the Schebler - positively controlling fuel flow, not by
controlling venting of the float chamber. I could be mistaken here.
Matt-
<ceengland(at)bellsouth.net>
n801bh(at)netzero.com Guest
Posted: Thu Apr 29, 2010 3:13 pm Post subject: stopping engine |
I will add a correction to the Mc Neilly mixture block for Holley carbs.. Tom Mc Neilly designed the block to act like a variable main jet, not to alter float bowl pressure... Some 2 and 4 stroke snowmobile motors use the bowl pressure method to trick the carb into thinking it is at a different altitude..... Just for the record....
Ps... I LOVE my Mc Neilly mixture block on my V-8 powered experimental. It works sooo good. !!!!!!
Ben Haas
N801BH
www.haaspowerair.com
Eric M. Jones
Joined: 10 Jan 2006 Posts: 565 Location: Massachusetts
Posted: Fri Apr 30, 2010 4:36 am Post subject: Re: stopping engine |
In learning to fly in a C150/C172, the explanation was:
The fuel was gravity fed with a left-right- both selector (was there an OFF?), the spark was magneto. In the event that the prop was turned by hand, the magneto could start the engine if its P-lead to ground lead was defective. So throttle at idle, mixture pulled lean until engine quit, switch off.
Your mileage may vary.
_________________ Eric M. Jones
www.PerihelionDesign.com
113 Brentwood Drive
Southbridge, MA 01550
(508) 764-2072
emjones(at)charter.net |
