MHerder
Joined: 11 Feb 2008 Posts: 143 Location: Fort Worth TX
Posted: Mon Apr 26, 2010 12:05 pm Post subject: Horizontal Stabilizer Attach |
Anyone out there have any useful tips on how to do the final fitting of the Horizontal Stabilizer? How far fore/aft it should be. Any pictures of of the attachment bolts would be appreciated, seems like there is a good deal of play. Any special techniques to make sure that you got it parallel to the longeron and equidistant from the center. This seems like it could be a real PIA if your floor isn’t good and level and such.
Please send pics of your bolts, are there any other considerations?
_________________ Zodiac 601 HD
Jabiru 3300
Wood Sensinich 64x47
Finally Flying |
jaybannist(at)cs.com Guest
Posted: Mon Apr 26, 2010 1:05 pm Post subject: Horizontal Stabilizer Attach |
Michael,
The way the horizontal stabilizer attach brackets are made makes locating it left and right automatic. For fore and aft location, just center the forward stabilizer attach bracket on the fuselage attach bracket (see photo). The fuselage upper longeron must be level, fore and aft, and right to left. Level the stabilizer left and right. The second photo shows two clecoes in the outermost stabilizer ribs. Those are used to level the stabilizer fore and aft. I located a spot on the centerline of the forward upper skin bulkhead, and a spot on each end of the stabilizer at the tips. Making sure those dimensions were equal assured that the stabilizer was square with the fuselage. I checked each measure several times to make sure nothing changed before drilling the pilot holes for the bolts in the attach brackets.
Jay Bannister
101.43 KB |
4235 Time(s) |
123.88 KB |
4235 Time(s) |
chris Sinfield
Joined: 28 Nov 2006 Posts: 270 Location: Sydney Australia
Posted: Mon Apr 26, 2010 7:45 pm Post subject: Re: Horizontal Stabilizer Attach |
I have wondered If I should make the brackets a little thicker, what do others think? I thought Zenith may have made them thicker in the upgrade but they did not?
Chris Sinfield
Zodiac XL
Sydney
Scotsman
Joined: 27 Aug 2007 Posts: 89 Location: Johannesburg, South Africa
Posted: Thu Apr 29, 2010 4:52 am Post subject: Re: Horizontal Stabilizer Attach |
Hey Chris,
This is also on my list to upgrade as the current ones look a little anemic (like the original rear spar attach point). Although that being said I believe that the cracks seen in the rear stablizer were in the horizontal stabliser attach points not the plates that this attaches to on each side of the fuselage.
Cheers
j
_________________ Cell +27 83 675 0815 |
