longg(at)pjm.com Guest
Posted: Wed Apr 21, 2010 9:46 am Post subject: Surface temperature sensor |
Q,
Has anyone come across an example of a surface temperature sensor (generic)) that could be used on engine parts or perhaps the firewall and send a digital reading back to the panel?
Example. – I would like to measure the temperature on the surface of my oil filter/fuel pump and display that value on the panel.
FYI – I have stick-on thermometers that work great when performing engine checks on the ground but they are of little use in the air.
Glenn
rampil
Posted: Wed Apr 21, 2010 12:10 pm Post subject: Re: Surface temperature sensor |
Ahhhh, how bout a thermocouple? how bout a resistive probe like
many engines use for CHT. This discussion group is replete with temp.
monitoring
Posted: Wed Apr 21, 2010 1:04 pm Post subject: Surface temperature sensor |
Thanks IRA,
Yes, I'll do some digging. I was thinking about something with a flat
profile and perhaps a stick on for a flat surface. There must be
somebody putting out a device that can be fastened to a flat surface
that has two wires sticking out of it.
Glenn
rampil
Posted: Wed Apr 21, 2010 3:18 pm Post subject: Re: Surface temperature sensor |
The actual sensors for t/c or thermistors are tiny inside those cans
they get mounted in. A tc is just two wires twisted in each other.
Either is easy to JB Weld in place on a surface
Posted: Wed Apr 21, 2010 9:58 pm Post subject: Surface temperature sensor |
At 03:58 PM 4/21/2010, you wrote:
Thanks IRA,
We usually use a thermocouple wire and stick it to
the surface with some epoxy. If you don't have
a thermocouple reading instrument, you can rig
a direct reading semiconductor sensor like the
the LM285. It's powered up directly from your
14v system through a 10K resistor and reads
directly in degrees Kelvin. It's in the shape
of a plastic TO92 transistor with a flat side
easily bonded to the surface of interest.
You can read it's measurement directly on
a multimeter where 2.75 volts is equal to
275 degrees K.
Very handy for a quick-n-dirty look-see.
Radio Shack and Harbor Freight both stock
temperature reading multimeters based on
type K thermocouple wire.
rv8iator
Posted: Thu Apr 22, 2010 5:54 am Post subject: Surface temperature sensor |
Thermocouples are quite small. I would think a piece of aluminum tape over the thermocouple onto the oil filter would get you a very accurate temp reading.
chris stone
Thanks IRA,
Glenn
_________________ C. Stone (RV8iator) |
Posted: Thu Apr 22, 2010 5:56 am Post subject: Surface temperature sensor |
Thanks all for the suggestions. Time to experiment.
Glenn
Do Not Archive.
deej(at)deej.net Guest
Posted: Thu Apr 22, 2010 10:44 am Post subject: Surface temperature sensor |
On 04/21/2010 01:42 PM, longg(at)pjm.com wrote:
| Quote: | Has anyone come across an example of a surface temperature sensor
Tons of digital thermometers with remote wireless sensors are available
in Home and Garden sections of retail stores.
Not a recommendation, but here is one example:
http://www.amazon.com/Crosse-Technology-Digital-Thermometer-Wireless/dp/B001DNIIOS/ref=sr_1_2?ie=UTF8&s=home-garden&qid=1271961133&sr=8-2
<http://www.amazon.com/Crosse-Technology-Digital-Thermometer-Wireless/dp/B001DNIIOS/ref=sr_1_2?ie=UTF8&s=home-garden&qid=1271961133&sr=8-2>
Drop by your local Walmart, Home Depot, or Lowes and I'm sure you can
find plenty to choose from.
Probably not too hard to tear apart the remote sensor housing and get
to the actual sensor itself to attach it directly to something.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
mcculleyja(at)starpower.n Guest
Posted: Thu Apr 22, 2010 12:21 pm Post subject: Surface temperature sensor |
I've been using a very inexpensive system with 18 sensor locations in my
Wittman Tailwind for well over 500 hours and 7 years, with never a
malfunction. It's based on inexpensive thermistors available from most
electronics suppliers and feeds into the display head of an ordinary
digital meat thermometer mounted on my instrument panel. It can handle
up to 300 degree F which covers everything firewall-forward except
engine cylinder EGT and CHT.
If you want some part numbers and more details contact me off list at
mcculleyja(at)starpower.net.
Jim McCulley
Q,
Example. I would like to measure the temperature on the surface of my
FYI I have stick-on thermometers that work great when performing
Glenn
lists(at)stevet.net Guest
Posted: Fri Apr 23, 2010 5:08 am Post subject: Surface temperature sensor |
Why off-list? I'm sure that many readers of the list would be interested. Please share with all of us!
Steve Thomas
________________________________________________________________________
On Apr 22, 2010, at 1:19 PM, J. Mcculley wrote:
I've been using a very inexpensive system with 18 sensor locations in my Wittman Tailwind for well over 500 hours and 7 years, with never a malfunction. It's based on inexpensive thermistors available from most electronics suppliers and feeds into the display head of an ordinary digital meat thermometer mounted on my instrument panel. It can handle up to 300 degree F which covers everything firewall-forward except engine cylinder EGT and CHT.
If you want some part numbers and more details contact me off list at mcculleyja(at)starpower.net.
Jim McCulley
> Q,
> Example. I would like to measure the temperature on the surface of my oil filter/fuel pump and display that value on the panel.
> FYI I have stick-on thermometers that work great when performing engine checks on the ground but they are of little use in the air.
> Thanks,
> Glenn
rampil
Posted: Fri Apr 23, 2010 12:45 pm Post subject: Re: Surface temperature sensor |
Don't count on home and garden type thermometer systems to be
especially accurate. They have no requirement to be calibrated
or calibrateable.
Posted: Fri Apr 23, 2010 6:41 pm Post subject: Surface temperature sensor |
Sorry Steve and others...I just thought this subject might be of
interest to so few that I should not take up bandwith that those not
interested would have to deal with. But, here it is:
This is a very accurate system that I tested with a laboratory quality
temperature meter and found the accuracy of all my sensors to be ± two
degrees F. It may not be very sophisticated, but it is super-inexpensive
and has never malfunctioned. I use it on every flight to assure myself
that no changes suddenly occur that could indicate a malfunction.
Mine is about a $15 to $25 system that I've operated now for over seven
years and upwards of 600 flight hours on it's original internal
watch-size battery. The sensors are standard mini glass-encapsulated
thermistors available from most electronic supply sources. I used
Digi-Key # KC013-ND, 100k ohm units.
For those sensors measuring metal surface temperatures (cylinder bases,
starter, mags, boost pump, alternator, etc.) the sensors are attached to
the surfaces with heat sink grease, and held in place mechanically
and/or with a coating of the red 600 degree RTV, then insulated from
surrounding radiation with fireman's suit material. To assure firm
contact with the surface until the RTV sets requires some simple tricks
I wont cover unless you desire later.
Those sensors that measure airflow temperatures are mechanically
supported in various ways depending upon the surrounding environment,
and are then shielded from nearby heat radiation, using standoff shields.
The display is a panel mounted single LCD with a compact surface mount
IC unit that I adapted from a meat thermometer with a range up to 300F.
The head of the meat thermometer becomes the panel mounted digital
display after cutting off the long stem, but retaining the internal pair
of wires to the display head.
The individual sensor locations are selected for readout through a
rotary switch on the panel. The delay in the presentation from one
sensor selection to the next is less than one second and my poor-man's
data recording system is via my hot mike through the intercom to a voice
recorder. In this current era of exotic digital commercial boxes for
anything a person desires, my "keep-it-simple and build-in-lightness
mentality" may not be the answer for others, but I don't mind
post-flight manually inputting the data from my recorder into a
spreadsheet for further massaging if needed.
The installation of the thermistors is simpler and much less expensive
than thermocouples and since the thermistors operate in a very
high-impedence circuit the wiring need not be any larger size than
needed to assure mechanical robustness. I used 22 gauge wire and joined
all the ground return wires together to pass through the firewall as a
single lead, so the wire bundle becomes very small aft of the firewall.
Also, because of the very high impedence of the circuitry, there is no
sensitivity to length of individual sensor wires between thermistor and
display for any possible location within a general aviation
installation. Good quality soldering technique is very adequate for
connections, as are properly-crimped-on terminals, if desired.
Steve Thomas wrote:
| Quote: | Please share with all of us!
Steve Thomas
> AeroElectric-List message posted by: "J. Mcculley" <mcculleyja(at)starpower.net>
> Jim McCulley
>> Q,
a digital
| Quote: | >> Example. I would like to measure the temperature on the surface of my
| Quote: | >> FYI I have stick-on thermometers that work great when performing
| Quote: | >> Thanks,
>> Glenn
Posted: Sat Apr 24, 2010 7:20 am Post subject: Surface temperature sensor |
At 09:38 PM 4/23/2010, you wrote:
bandwith that those not interested would have to deal with. But, here it is:
How was it that you determined that the 100K devices were
appropriate to your particular display? Folks should understand
that there are hundreds of remote temperature measurement
products on the market. I've see them use thermocouples, solid
state LINEAR temperature sensors, diodes, the junctions of
transistors (also a diode) AND thermistors.
http://www.gesensing.com/products/resources/datasheets/ge1.pdf
Thermistors are inexpensive AND rugged but they have the
distinct disadvantage of being non-linear. So the accurate
temperature display not only needs to know what the resistance
of the device is at say 25C, the designer will compensate for
the shape of temperature/resistance curve as well.
The first thing one needs to do when adapting a commercial
off the shelf (COTS) indicator to their airplane is to determine
the sensor technology. If a thermistor, then you need to get
the 25C resistance rating, and then the resistance at some
other handy value (boiling water - 100C) and then find
substitute sensors of identical characteristics.
The really cool thing about the linear, solid state sensors
is that they are direct reading, linear, and of known accuracy
out of the box. I'm not discouraging anyone from exploring
adaptation of any COTS temperature display but understand that
there are some inviolate rules by which the sensing technology
is identified and then duplicated so that the display performs
as expected.
Posted: Sat Apr 24, 2010 10:18 am Post subject: Surface temperature sensor |
Using a laboratory quality temperature instrument I determined the
readings (at about 10 degree F intervals) of a typical digital display
meat thermometer (10-15 dollar variety some 10 years ago) and found the
error varied well within +/- 3F within the range of interest I
considered appropriate as about 70 to 300F for firewall-forward
applications.
Then by carefully extracting the sensor inside the very tip of the meat
thermometer, I compared it in size and appearance to a variety of
commercially available thermistors and tested several by electrically
substituting them in place of the original until finding the one I
mentioned by source and part number to be apparently identical in
performance over the same range of temperature interest.
After completing the installation in the aircraft, another test with the
lab-quality meter for comparison gave the same ballpark results and also
showed that with the nominal 100K resistance value stated for the
thermistor, the total impedance of the completed installation for any
likely difference in length of wiring between the closest versus
greatest distance of sensors created no error even when wired with the
smallest gauge wire I felt appropriate for use in an aircraft
installation with heat and vibration considerations.
My assumption was/is that the surface mounted electronic circuitry in
the meat thermometer display head performs the necessary compensation
for non linear characteristics of the basic thermistor. Although I was
unable to obtain any data from the thermometer vendor, I assume I was
just lucky enough to perhaps have stumbled upon the exact same-source
thermistor used in the retail unit.
Jim McCulley
<nuckolls.bob(at)aeroelectric.com>
as expected.
Posted: Sat Apr 24, 2010 6:31 pm Post subject: Surface temperature sensor |
| Quote: | Then by carefully extracting the sensor inside the very tip of the
meat thermometer, I compared it in size and appearance to a variety
of commercially available thermistors and tested several by
electrically substituting them in place of the original until
finding the one I mentioned by source and part number to be
apparently identical in performance over the same range of
Aha! Then there was a rational exercise to pick a
thermistor that matched the operating characteristics
of the device being cloned.
This is the point that we needed to make clear
to our readers. There are thousands of thermistor
parts of which only a few will directly replace the
sensor used in a randomly selected off the shelf
thermometer.
I assume I was just lucky enough to perhaps have stumbled upon the
exact same-source thermistor used in the retail unit.
Don't know about 'luck'. You can measure the 25C
resistance point for device under study. You could
also measure it's resistance at say, two other points
over the range of interest . . . like 0C (ice point)
and 100C (boiling point). Then by studying the
temperature/resistance transfer curves (or as you
did, experimentation) you can find a match. Afterr
that, you're home free. As you've described, you
can switch as many remote sensors in to the display
as you like.
The only thing I wanted to make clear was that
unlike thermocouples and factory calibrated
temperature sensors, thermistors are a breed
unto themselves. The successful user will have
to learn a few dditions to their back of
electro-whizzy tricks.
Thanks for sharing your experience in this
discussion!
user9253
Joined: 28 Mar 2008 Posts: 1967 Location: Riley TWP Michigan
Posted: Sun Apr 25, 2010 5:32 am Post subject: Re: Surface temperature sensor |
Jim McCulley,
Good job making an economical and accurate multi-point temperature sensor and indicator. I admire your ingenuity and resourcefulness.
Joe
_________________ Joe Gores |
Posted: Sun Apr 25, 2010 9:48 am Post subject: Surface temperature sensor |
Thanks, Joe, for the compliment! Hope you find the concept useful for
your purposes.
Jim
Posted: Tue Apr 27, 2010 1:07 pm Post subject: Surface temperature sensor |
I'll second that - Jim, thanks for the due diligence. I'm not that
creative at this point so I found a relatively low cost source for a 4
channel display which supports standard thermocouples and can also be
panel mounted. While not their main business, these folks seem keen
towards supplying the aircraft market. http://www.omega.com is sort of a
go-to joint for thermo-stuff. Of course there are hundreds of other
options.
http://www.aprsworld.com/thermok/
Glenn
