Proper SWR meter
mdnanwelch7(at)hotmail.co
PostPosted: Thu Apr 22, 2010 11:05 am    Post subject: Proper SWR meter Reply with quote
Electric gurus,
  I've got an SWR meter I borrowed from a neighbor who's a HAM radio buff.  The SWR meter is a Lafayette, stock no. 99-25835.  I'm waiting for the bnc/pl259 adapter to get here tomorrow, before I can use it.  (It has the bnc male/PL259 adapter to hook it up to my Icom A200).
  It was suggested to me to make sure it is the "right frequency meter", to be able to properly check for standing waves.  I wasn't aware of that aspect of an SWR meter.
  Does anyone know if this meter can properly check the standing waves on frequencies of an aircraft radio/antenna?      It only refers to "amateur radio stations".
Mike Welch
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. [quote][b]
deej(at)deej.net
PostPosted: Thu Apr 22, 2010 11:46 am    Post subject: Proper SWR meter Reply with quote
I was unable to find the exact specs for this unit, but I found a forum
thread on it here:
http://forums.qrz.com/showthread.php?t=88199
If that thread is true, then if you are looking for a relative reading
(ie, a maximum or minimum reading), it might be okay. If you are
looking for an exact correct numerical reading, then no.
Typically, if you are tuning an antenna you are looking for a minimum
reading, so it would probably be okay. Tune, check SWR, tune, check
SWR, etc.
If you are inserting this inline to check the SWR reading of an
existing antenna installation and need an accurate number, then it
probably won't do you much good on aircraft freqs.
-Dj
Dj Merrill - N1JOV
Glastar Sportsman 2+2 Builder #7118 N421DJ - http://deej.net/sportsman/
Grumman Yankee Driver N9870L - http://deej.net/yankee/
PostPosted: Thu Apr 22, 2010 12:43 pm    Post subject: Proper SWR meter Reply with quote
 > Typically, if you are tuning an antenna you are looking for a minimum
SWR, etc.
-Dj
  Thanks for the reply, DJ.
  After reading some of those comments on it, now I'm concerned it may damage my Icom A200.
  The antenna I was planning on checking with it is my recently constructed "copper foil groundplane" antenna.
  I have plugged the antenna into the radio, and the local airport unicom replied with a "loud and clear", but they are only 1/3 of a mile away.
  Should I not risk screwing up my Icom, and try to find a more appropriate SWR meter?
Mike Welch
GlaStar and Kolb MkIIIX builder
Hotmail is redefining busy with tools for the New Busy. Get more from your inbox. See how. [quote][b]
deej(at)deej.net
PostPosted: Thu Apr 22, 2010 1:14 pm    Post subject: Proper SWR meter Reply with quote
I do not know anything about that particular SWR meter, so I can't say
for sure. If you can find an SWR meter that covers the amateur radio
144Mhz band, that would probably be close enough so that you can tune
your antenna. Any local amateur radio operators in your area? I'm sure
they'd come out and help you for free just to see a cool project like an
airplane being built. Smile
Try looking here:
http://www.qrz.com/db/?cmd=1
and then look up their name in the phone book and give them a call.
-Dj
Dj Merrill - N1JOV
PostPosted: Thu Apr 22, 2010 2:00 pm    Post subject: Proper SWR meter Reply with quote
-Dj
DJ,
  Re: ham radio operators, yes.  That's where I got this SWR meter from.  Like I said in my original email, the instruction manual only refers to "amateur radios".
  Sounds to me as though I should be okay.  I'll get the adapter from Radio Shack tomorrow, and give it a try.
Mike Welch
GlaStar and MkIIIX builder
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. [quote][b]
kuffel(at)cyberport.net
PostPosted: Thu Apr 22, 2010 2:09 pm    Post subject: Proper SWR meter Reply with quote
Mike,
<< SWR meter is a Lafayette, stock no. 99-25835. .. the "right frequency meter >>
Lafayette isn't known for excellence in design. There are two problems with the meter you mention. First it is specified for use only up to about 30 MHz, one fourth the frequency of the aviation communication band around 120 MHz. As DJ mentions, it might be able to determine a minimum bad. But personally, I wouldn't trust it. And for sure it wouldn't tell you about the performance of your antenna near the band edges, which is just as important as the "minimum" frequency.
Second, to work you must *transmit* power on the frequencies of interest, a practice frowned upon by the FAA and the FCC unless you are communicating with someone. Current practice says to use an input noise bridge antenna analyzer such as sold by MFJ. Contact your local ham radio club. They will probably have one as part of the club's equipment. Even if not, for sure one of their members will have one and be delighted to come over and help you tune/analyze your setup.
To find your local ham club log on to arrl.org. In the upper right hand corner is a website search box. Select the Category "Clubs" and press Go. This takes you to a clubs page. On the left side enter your Zip code, select the desired mileage range next to it and press Search at the bottom of this grey box. Or fly up to Whitefish Montana and I'll be happy to help you.
Tom Kuffel, AL7AU
PostPosted: Thu Apr 22, 2010 5:06 pm    Post subject: Proper SWR meter Reply with quote
Tom,
  Thanks for the tips.  I'll see if I can find a local ham operator guy to help get me squared away.
  If I came up to Whitefish, MT, I wouldn't have time to deal with the antenna....with my fishin' taking up all my time.  Smile
Thanks again,   Mike Welch
PostPosted: Thu Apr 22, 2010 5:26 pm    Post subject: Proper SWR meter Reply with quote
At 04:59 PM 4/22/2010, you wrote:
Mike,
Agreed. I blew away a lot of $time$ building matching
harnesses "checked" with a similar transmission line
reflectometer of this genre . . .
[img]cid:7.1.0.9.0.20100422201433.0037fb48(at)aeroelectric.com.0[/img]
Optimized for the 3-30 Mhz range, these critters become
VERY accommodating and tended to show that EVERYTHING you
attached to it at 145 Mhz had a good SWR!
Actually, the MFJ259 is an active emitter too but in
the milliwatt level. But the best part is that it's
ability to accurately display antenna and transmission
line characteristics is quite good at 130 Mhz.
I use to rent one to the OBAM aviation community but
wear and tear outgo was higher than rental income.
 Filesize:  20.27 KB
 Viewed:  9789 Time(s)
PostPosted: Thu Apr 22, 2010 8:49 pm    Post subject: Proper SWR meter Reply with quote
Me:
<< you must *transmit* power on the frequencies of interest, a practice frowned upon by the FAA and the FCC unless you are communicating with someone. >>
Bob:
<< Actually, the MFJ259 is an active emitter too but in the milliwatt level. >>
Absolutely true, but in this context all receivers are "active emitters". For example, Canadian police use a special receiver to detect the miniscule signal emitted by radar detectors to enforce their ban on such devices. The point being made is the amount of power needed to operate the old style SWR meters *will* cause appreciable interference to other users while the MFJ259 and such for all practical purposes will not.
Tom Kuffel
PostPosted: Fri Apr 23, 2010 5:33 am    Post subject: Proper SWR meter Reply with quote
At 11:46 PM 4/22/2010, you wrote:
Me:
Bob:
Sure, but that wasn't the point, the MFJ device one is
looking for is not the "noise bridge antenna analyzer"
or MFJ202. This network analyzer excited by a broadband
noise source requires a receiver with a signal strength
indicator tuned to the frequency of interest as part of
the test equipment. Further their only noise bridge offering
http://mfjenterprises.com/man/pdf/MFJ-202B.pdf
is more of a system designer's instrument than
a technicians test tool.
Bob . . . [quote][b]
earl_schroeder(at)juno.co
PostPosted: Fri Apr 23, 2010 5:45 am    Post subject: Proper SWR meter Reply with quote
When you 'rented' the MFJ259, did you include a simplified instruction sheet?
As a proud owner of a MFJ259, I would like a 'cook book' type instructions tailored to the OBAM aviation community.
I would like to know all the theory etc but at this time do not have the time to invest in learning its complete capability and retaining it. I am interested but short on time. My Grandson currently has priority!
I just want to know how to correctly connect it and read the SWR. Then some clues as to how to correct it if necessary.
Then I would like to assist my EAA chapter folks in checking their installations. The MFJ259 sitting on the shelf isn't doing anyone an favors... (no, it isn't for sale at this time) Earl
PostPosted: Fri Apr 23, 2010 8:41 am    Post subject: Proper SWR meter Reply with quote
<< Sure, but that wasn't the point, the MFJ device one is
or MFJ202 >>
As usual, Bob is correct. I falsely "remembered" my MFJ HF/VHF SWR Analyzer Model MFJ-259B used noise bridge technology. Should have checked my instruction manual first and used the full, official name. The Model MFJ-259 Analyzer is what you will commonly find available from local ham radio operators/clubs. The original point remains, it is a much better tool to adjust aircraft antennas than the Lafayette style SWR meters.
Tom Kuffel
PostPosted: Fri Apr 23, 2010 1:35 pm    Post subject: Proper SWR meter Reply with quote
or MFJ202 >>
ABSOLUTELY!! I've owned three of them
and it's the first tool I pick up when there
are questions of feed line and/or antenna
quality to be explored.
I used to have a noise-bridge. It does perform
as advertised and was VERY reasonably priced because
the heavy lifting for test equipment was the companion
receiver not supplied. I think I gave that one away
many moons ago.
PostPosted: Sat Apr 24, 2010 7:27 am    Post subject: Proper SWR meter Reply with quote
As a matter of fact, I think I did but it's
on the computer in M.L.
I'll see if I can did it up and post it early
next week. If not, I'll write up a new one.
It's pretty straight forward . . . perhaps
a cognizant user of such devices will come
up with a procedure before I get to it.
PostPosted: Sat Apr 24, 2010 11:10 am    Post subject: Proper SWR meter Reply with quote
My response:
Thanks very much! I'll be watching for it from you or anyone.. Earl
Do not Archive.
