TSO'd Instrumentation For IFR?
Site Admin
PostPosted: Tue Apr 20, 2010 5:49 pm    Post subject: TSO'd Instrumentation For IFR? Reply with quote
Dear Listers,
I'm working with the local FSDO this week and had my airframe inspection on Monday will get my sign-off this Friday if all goes well. Looking over the requirements for IFR, it appears that I've got everything I need as far as equipment is concerned. I have a Garmin SL-30 for Com/Nav and a Garmin GTX-327 for Mode C transponder. All of the other equipment and functionality is provided by the GRT Horizon HX sytems including the encoder, attitude, airspeed, altitude, compass, etc, etc. I do not have any steam gauges or other flight instruments other than what is provided by GRT through an HX installation.
My question is can my RV-8 be approved for IFR flight with this compliment of GRT HX specific instrumentation? Or, would I need to have a TSO'd encoder and/or other TSO'd pieces such as rate-of-turn, slip, sensitive altimeter, artificial horizon, direction gyro, etc?
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Final Bits/Inspection/Test Flight
Gary.A.Sobek
PostPosted: Tue Apr 20, 2010 7:48 pm    Post subject: TSO'd Instrumentation For IFR? Reply with quote
The FAA does not approve it, you do.
Your Operating Limitations should have this Operating Limitation listed " Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->After completion of phase I flight testing, unless appropriately equipped for night and/or instrument flight in accordance with § 91.205, this aircraft is to be operated under VFR, day only."
Gary A. Sobek
2,346+ Flying Hours So. CA, USA
[quote] Date: Tue, 20 Apr 2010 18:48:01 -0700
To: rv-list(at)matronics.com; rv10-list(at)matronics.com; rv8-list(at)matronics.com; rv7-list(at)matronics.com
Subject: TSO'd Instrumentation For IFR?
--> RV-List message posted by: Matt Dralle <dralle(at)matronics.com>
Dear Listers,
RV-8 #82880 N998RV
Status: F========================
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy.
