Check Valve For Static System Cabin Venting...
Site Admin
PostPosted: Mon Apr 19, 2010 12:51 pm    Post subject: Check Valve For Static System Cabin Venting... Reply with quote
Dear Listers,
Looking at the requirements for IFR certification of the RV-8, it looks like the only thing I don't have is an "alternate static source". This seems like it would be as simple as adding a "T" valve in the 1/4 neoprem static air tube that goes along under the left hand canopy rail.
Does anyone have any suggestions on something I could just cut the tube and stick in line with a little thumb screw to switch between the fuselage or cabin source?
I'm assuming this will meet the requirement?
Thanks!
PS - Attached are a couple of pictures from Taxi-testing and Magnetometer calibration this weekend. Cool?
RV-8 #82880 N998RV
http://www.mattsrv8.com - Matt's RV-8 Construction Log
Status: Final Bits/Inspection/Test Flight
 Filesize:  118.16 KB
 Viewed:  3728 Time(s)
 Filesize:  111.58 KB
 Filesize:  100.12 KB
 Filesize:  105.41 KB
 Filesize:  104.35 KB
 Filesize:  93.51 KB
 Filesize:  84.37 KB
 Filesize:  77.18 KB
 Filesize:  95.49 KB
 Filesize:  98.4 KB
 Filesize:  92.02 KB
 Filesize:  99.33 KB
 Filesize:  107.22 KB
 Filesize:  168.96 KB
 Filesize:  94.25 KB
 Filesize:  167.76 KB
 Filesize:  113.65 KB
 Filesize:  101.8 KB
 Filesize:  95.41 KB
Site Admin
PostPosted: Mon Apr 19, 2010 6:48 pm    Post subject: Check Valve For Static System Cabin Venting... Reply with quote
At 03:53 PM 4/19/2010 Monday, you wrote:
Matt, cut the tubing, insert a 'T' with a short stub of tubing. Put a plug in the tube of a type that you can pull out easily if needed.
Simple, light, and inexpensive.
Linn
Matt Dralle wrote:
>Dear Listers,
>Thanks!
What a great idea, Linn! Thanks. Here's what I did tonight including a couple of pictures...
I added a small "T" Nylon fitting in the 1/4" tube for static air just in front of the instrument panel under the left cockpit rail. I cut a short piece of 1/4" tubing and filled it with black RTV and then put a piece of heat shrink tubing over it to form a handle. The whole thing fits nicely under the cockpit rail and from the pilot's position is just barely visible, yet can be accessed easy. In the event that icing conditions occur, the fitting can be unscrewed and the plug removed for cabin venting.
RV-8 #82880 N998RV
 Filesize:  251.37 KB
 Filesize:  160.45 KB
 Filesize:  162.27 KB
gaillard.peck.ctr(at)nell
PostPosted: Tue Apr 20, 2010 7:54 am    Post subject: Check Valve For Static System Cabin Venting... Reply with quote
Beautiful airplane Matt. Congratulations. I look forward to news of the first flight.
Gail Peck
RV-8 Wings slow build
Las Vegas
koppk1
PostPosted: Tue Apr 20, 2010 8:08 am    Post subject: Check Valve For Static System Cabin Venting... Reply with quote
Where did you get the ideal an alternate static source was required for IFR flight. No such thing as an IFR "certification" BTW...
smime.p7s
Download
 Filename:  smime.p7s
 Filesize:  4.8 KB
 Downloaded:  495 Time(s)
