601XL main spar question
Goto page Previous  1, 2, 3, 4  Next
sabrina
PostPosted: Fri Apr 16, 2010 10:09 am    Post subject: Re: 601XL main spar question Reply with quote
n801bh(at)netzero.com
PostPosted: Fri Apr 16, 2010 11:39 am    Post subject: 601XL main spar question Reply with quote
I thought the 6 G ultimate loading was for positive G loading and negative ultimate was 3 G. The pic shows weight on the top of the wing, that is testing the negative loading.... They would have to flip the plane over, suspend the fuselage on some saw horses and pile the weight on the bottom of the wings to test for positive loading..... Am I thinking wrong here ?
Ben Haas
N801BH
www.haaspowerair.com
sabrina
PostPosted: Fri Apr 16, 2010 12:24 pm    Post subject: Re: 601XL main spar question Reply with quote
paulrod36(at)msn.com
PostPosted: Fri Apr 16, 2010 1:48 pm    Post subject: 601XL main spar question Reply with quote
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Opinions being like another part of our anatomy (everybody has one), I'd like to throw in an unfounded suspicion for your consideration: If you take a piece of flat metal, any thickness or length will do, set it at 9 degrees (forward) from vertical, and subject it to a true vertical stress, it tries to bend backward under that stress. Could it be that the main spar bends backward some, puts pressure at the rear spar attach point, and starts the failure there, followed immediately by the main spar failure when the rear breaks? I have no evidence, stats, or analysis to back this up, but I can't think of any aircraft with a canted spar. Thoughts, anyone?
Paul R
psm(at)att.net
PostPosted: Fri Apr 16, 2010 2:33 pm    Post subject: 601XL main spar question Reply with quote
What a fascination notion!
I wonder if examination of the wreckage can shed light on this question. I have heard many anecdotal comments about elongated holes in the rear attach points. Perhaps the axis of elongation would be impacted if the spar is bending . . .
Paul
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of paulrod36(at)msn.com
Sent: Friday, April 16, 2010 2:47 PM
Subject: Re: Re: 601XL main spar question
Paul R
n1269k
PostPosted: Fri Apr 16, 2010 5:34 pm    Post subject: Re: 601XL main spar question Reply with quote
Sabrina
My plans for the 650 shows +6/-3, the upgrade shows +6/-3 for both the 601 and the 650. Both show 1320 max weight.
Terry
Plans building
Afterfxllc(at)aol.com
PostPosted: Sat Apr 17, 2010 6:04 am    Post subject: 601XL main spar question Reply with quote
In a message dated 4/16/2010 1:20:03 P.M. Eastern Daylight Time, chicago2paris(at)msn.com writes:
if I recall correctly, the only person to live to tell about flutter dived away rather than climbing...
PostPosted: Sat Apr 17, 2010 6:05 am    Post subject: 601XL main spar question Reply with quote
No he chopped the power and climbed. And I know the guy and it did happen.
Jeff
Terry Phillips
PostPosted: Sat Apr 17, 2010 6:37 am    Post subject: 601XL main spar question Reply with quote
At 11:59 AM 4/16/2010 -0400, Bryan Martin wrote:
Why do you keep denying the possibility of pilot error in these accidents? It's a fact that pilot error is a factor in more accidents than all other causes combined. It is an especially prevalent problem for low time pilots with low time in type. Low time in type seems to be about the only common thread in these accidents, along with low time on the airframe.
While we do not know everything about the 601XL accidents, there are some things that we do know. E.g. regarding common threads between the accidents. First, lets list the accidents in question:
1. Oakdale, CA 2/8/06
2. Yuba City, CA 11/4/06
3. St. Fulgent, FR 7/7/07
4. Polk City, FL 4/7/08
5. Capao do Leao. BR 5/5/08
6. Barcelona, SP 6/1/08
7. Markemeer, NL 9/14/08
8. Antelope Island, UT 3/4/09
9. Agnos, AR 11/6/09
I see some common threads in these accidents.
One thread is that all these accidents involve structural failure. I haven't listed the 601XL accidents that do not involve structural failure. If I had listed those, it is likely that Bryan's assertion that many accidents result from pilot error would shown to be correct.
Another thread is that they all involve Zenair CH601XL aircraft. There are no 600's, 601HD's, 601HDS's, 701's, Kitfox's, Rans, etc. As Paul has pointed out, it is almost impossible that, among all the homebuilt designs out there, the 601XL has somehow been blessed with the most incompetent, careless, unskilled collection of pilots and owners in the history of aviation. Meanwhile, the 600, HD, and HDS apparently have only a single inflight break up amongst them--Bramley, UK . Significantly, Bramley was attributed to pilot error based on detailed analysis and the observation of a very abrupt climbing maneuver. Personally, I do not find pilot error a creditable explanation for the 601XL accidents.
A third common thread is the occurrence of flutter in the majority of these accidents. Who says flutter occurred? Well, how about the NTSB and the FAA:
"Photographs and physical evidence:
The FAA evaluated the photographic evidence of several accident aircraft and observed
the physical evidence first hand of the Antelope Island accident aircraft. The evidence
indicates the presence of compression failures in both the upper and lower aft spar caps
(or skins). In some cases the evidence shows a complete wing failure in one direction, yet
exhibits compression buckling consistent with bending in the other direction as well. This
combined condition is indicative of complete load reversal and provides consistent
evidence that flutter occurred in these cases.
Reports and conclusions from the NTSB, other foreign government regulatory
agencies, and eyewitness accounts:
The NTSB identified flutter as the primary cause for several accidents, citing similar
evidence to what was stated in the previous section. Their expertise in accident
investigation enables them to distinguish between damage that occurred in flight during
the structural break-up sequence, and damage caused from impact with the ground. The
NTSB has pointed out that the location of the buckling failures on the upper and lower
surfaces of both wings has been observed consistently on several accident aircraft.
Additionally the direction of the loading that would create those buckles is typically in a
direction inconsistent with the loading from the impact with terrain. However the
evidence is consistent with wing bending and/or twisting as would be observed during
flutter where wing bending and torsion combine with control surface rotation about the
wing torsional axis. Additionally the NTSB observed the compression buckling of the
lower spar cap was at the lower edge of the hole that allowed the aileron push rod to pass
through the rear spar web. The compression buckling of the upper spar cap was several
inches inboard of the flap/aileron junction."
[Zodiac Special Review Team Report, FAA, p. 21]
The NTSB has published the photographic evidence in the Polk City Docket. You can buy a copy of the Docket from General Microfilms. Alternatively, the photos (from Oakdale, Yuba City, Polk City, Barcelona, Markemeer, Antelope Island, and Agnos) are available for study here:
http://groups.yahoo.com/group/ZBAG/files/NTSB%20Flutter%20Evidence%20091021/
And yet, the FAA report also says,
"Based on the evidence and analysis available, it is clear that flutter appears to be a causal
factor to the in-flight breakup of the airplanes. However, it is not clear whether it was the
primary causal factor, or occurred after some other initial structural deformation caused
local changes in wing section angle of attack. Flutter investigation requires a highly
technical, detailed, and complex analysis. The FAA did not perform a detailed analysis to
determine the flutter characteristics of the CH 601 XL .."
One might ask why the FAA would say, "it is not clear whether it was the primary causal factor," when there is unequivocal evidence that flutter occurred in 7 of the 9 accident aircraft, and it is common knowledge that aircraft structures cannot withstand the forces resulting from divergent flutter.
I cannot answer that question with certainty, but I can suggest a rationale:
In their April 14, 2009, Safety Recommendation Letter to the FAA, the NTSB wrote,
"Therefore, the National Transportation Safety Board recommends that the Federal Aviation Administration:
Prohibit further flight of the Zodiac CH-601XL, both special light sport aircraft and experimental, until such time that the Federal Aviation Administration determines that the CH-601XL has adequate protection from flutter, (A-09-30) (Urgent)"
Moving quickly, three months later the FAA responded to the NTSB's "Urgent" recommendation in a July 13, 2009 letter:
"The Federal Aviation Administration chartered a special review team to investigate the details of each recommendation. The team consists of FAA specialists from flight test, engineering, manufacturing, and accident investigation. The special review team will analyze the Zodiac CH-601XL and its derivatives.
At this time, the FAA lacks adequate justification to take immediate certificate action to ground the entire fleet."
So the FAA essentially rejected the NTSB recommendations and told the 601XL community to go on flying their airplanes while the FAA studied the problem.
The FAA did not discover "adequate justification to take immediate action," until November 7, 2009 when the FAA issued SAIB CE-10-08 in which the FAA,
"strongly recommend that all owners and operators of Zodiac CH601XL/CH650 comply with actions outlined in a forthcoming Aircraft Manufacturing & Design, LLC (AMD) Safety Directive / Safety Alert to address the above-referenced concerns before further flight."
I must say that I am impressed. After considering the NTSB's recommendations for 3 months before rejecting them in their letter of July 13, and then making no public statements on the 601XL for nearly 4 more months, the FAA came into work on a Saturday(!) November 7, 2009 to issue the SAIB!
Considering the above sequence of events, one rationale why the FAA would say, "it is not clear whether it [i.e., flutter] was the primary causal factor," becomes clearer. The FAA rejected the NTSB's Urgent recommendation to ground the 601XL, and one could make a strong case that, as a direct consequence of the FAA's inaction, the 9th 601XL structural failure accident occurred on November 6 in Agnos, AR. If, in their final report, the FAA acknowledged flutter as the probable cause of the 601XL accidents, the FAA would, in effect, be saying, "The NTSB's April 14 recommendation to ground the 601XL fleet was correct. We were wrong to ignore the strong evidence for flutter in the 601XL accidents and to reject the NTSB recommendation." Instead of acknowledging the obvious, the FAA chose to obscure the issue by suggesting that flutter was only one possible cause, and that the design's other documented flaws may have been primary. While my conjecture may not be correct, I must say that I've observed similar behavior in individuals and organizations. It can be difficult to admit you are wrong. Even more so when a fatality results.
Of course, that is just one rationale for the FAA's action, and an infinite number of others are possible.
My own personal view is that, while the original wing design is slightly under strength, that weakness was not primary cause of the accidents. I agree with the NTSB (as stated in the FAA final report) that the primary cause in most, if not all, of the accidents was flutter. If we can eliminate flutter, I believe the (structural failure) accidents will stop. The FAA's report states that Zenair should retest the modified design for flutter, and I agree that ASTM F2245 requires flutter testing before the (modified) S-LSA model can be sold. But the ASTM flutter test requirement does not apply to E-AB aircraft. I believe it's useful to consider the requirements for certified aircraft. The FAA will waive flutter testing if the control surfaces satisfy the criteria in A&E Report No. 45. I believe that the counterbalanced ailerons satisfy the A&E Report No. 45 aileron criteria, so I believe the upgrade will stop the flutter. That's good enough for me. But don't take my word for it. A&E Report 45 is available here:
Do the calculations yourself and report back to the group.
I don't want to leave the impression that I believe the wing strengthening is unimportant. The 601XL wing should meet spec. I just do not believe that the weak wing caused the accidents. And I am equally sure that a practical aircraft wing cannot be make strong enough to withstand divergent wing-aileron bending flutter. Stop flutter and you'll stop the accidents.
Enjoy the build.
Terry
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
ZU-601XL/Jab 3300 s .. l .. o .. o .. w build kit - Tail & flaps are done;
Upgrading wings & ailerons per the AMD Safety Directive
http://www.mykitlog.com/N47TP/ [quote][b]
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
Zenith 601XL/Jab 3300 slow build kit - Tail feathers done; working on the wings.
sonar1@cox.net
PostPosted: Sat Apr 17, 2010 9:23 am    Post subject: 601XL main spar question Reply with quote
Well said Terry - complete, concise, and with references. Good synopsis. As far as I am concerned: case closed. Next subject????? I do have a question though, do you know if all of the flutter incidents were with piano hinged ailerons?? I know that Yuba City was...............................Fred Sanford N9601 sold just before the edict...............
Terry Phillips
PostPosted: Sat Apr 17, 2010 10:40 am    Post subject: 601XL main spar question Reply with quote
Fred
'Good question.
Stephen had more complete access to the accident data than I did. (I.e., he saw everything I saw, but he managed to get access to info that he could not share further.) After Markemeer he told me that he did not have info about Polk City or St Fulgent, but that the rest of the accident aircraft had piano hinges. From the accident flutter evidence photos referenced earlier, it is clear that Polk City and Agnos had piano hinges. It appears to me from the photos that Antelope Island had flex hinges, and the Factual Report refers to "flexible skin ailerons." I conclude that Antelope Island had flex hinges. I suspect that the preponderance of piano hinges in the accident aircraft (at least 7 of 9) is much greater than the occurrence of piano hinged ailerons in the fleet. So, I would conclude that flutter is more likely with piano hinges than with flex hinges. But, Antelope Island and the experience of at least two "flutter survivors," indicate that flex hinges are not proof against flutter in the 601XL. (ZBAG questionnaire's and other "flutter survivor" naratives are included in the ZBAG Forum Files.) 'Hope that helps.
Terry
[/b]
Terry Phillips
ttp44~at~rkymtn.net
Corvallis MT
Terry Phillips
Corvallis, MT
ttp44<at>rkymtn.net
purplemoon99(at)bellsouth
PostPosted: Sat Apr 17, 2010 12:30 pm    Post subject: 601XL main spar question Reply with quote
PerfectTerry. End of story.... It IS time to move on,No more wing spar,wing spar,wing sparrrrrrrrBlaBla go to work on your planes so you can fly again. Joe N101HD 601XL-R Ram/Subaru ( now Corvett yellow red and black)
Sent: Sat, April 17, 2010 1:16:29 PM
Subject: Zenith-List: Re: Re: 601XL main spar question
Well said Terry - complete, concise, and with references. Good synopsis. As far as I am concerned: case closed. Next subject????? I do have a question though, do you know if all of the flutter incidents were with piano hinged ailerons?? I know that Yuba City was..............................Fred Sanford N9601 sold just before the edict..............
[quote][b][b]
bryanmmartin
PostPosted: Sat Apr 17, 2010 2:43 pm    Post subject: 601XL main spar question Reply with quote
As far as I have been able to determine, all the accidents involved failure in positive G loading except for Yuba City. There has already been a recommendation to limit the nose down elevator travel to about half of the nose up travel. I don't know if the Yuba City airplane had this modification.
>> the upgrade shows +6/-3 for both the 601 and the 650<<
My mentors were concerned that although the upgrade does appear to strengthen the wings as to torsional rigidity and positive Gs it may well detract from their ability to handle negative Gs due to the decision to only upgrade the top spar cap...
According to my plans, which CH still stands behind, if I don't upgrade I am at -6G, if I upgrade, I am at -3Gs, according to the upgrade paperwork.
If it "might be" negative Gs causing the failures, does an upgrade sound like a good idea without first addressing the stick sensitivity issue?
>> Is your comment below the reason you felt uneasy about the upgrade? ...wing fails first in negative gs?<<
Scott, this is what I meant by cold feet/feeling uneasy and why I am considering running a top mounted 1/8" cable between each wings' new rear spar mid-span doublers, and 3/16" cable between the inboard AN47 bolts of the new main spar struts.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
larry(at)macsmachine.com
PostPosted: Sat Apr 17, 2010 4:58 pm    Post subject: 601XL main spar question Reply with quote
Yes Patrick,
The angle of the spar related to the load would definitely make a
plausible rationale for the oblong holes and bent bolts. Otherwise how
would they
ever get to a point of beginning failure. Very good point!
Torsion.
Take a cardboard shoe box. Tape it up nice and tight. You can stand on it.
Take that same cardboard shoe box. Tape it up nice and tight, but with a 9 degree tilt to it. Then try to stand on it. Not nearly as strong.
The question is, "do the upgrades make the wing strong enough...?" It appears that as far as Zenith and the FAA is concerned, the answer is "yes".
Time will tell as more of us complete the upgrades and return to the air.
Patrick
XL/Corvair/BRS
http://forums.matronics.com/viewtopic.php?p=294356#294356
PostPosted: Sat Apr 17, 2010 5:36 pm    Post subject: 601XL main spar question Reply with quote
Exactly right Paul. The elongated holes and bent bolts suggest
improperly tightened bolts, or misalignment of the line of structural
connections. (Obviously the latter)
and the number of cracks in the center spar suggests over-stress was
prevalent a good bit before the failure. Moving the stress out through
the fuselage attach sheets
and angle works out to a rapid total failure when it all lets go. Still
don't think flutter had anything to do with it.
Paul R
zman601xl(at)aol.com
PostPosted: Sun Apr 18, 2010 7:35 am    Post subject: 601XL main spar question Reply with quote
I've often wondered why the Zenith demo airplane with 1300 hours on it did not have any sign of failure when they took it apart? My belief also is that there might have been builder error in some of these breakups.Just an opinion(you know what they say about opinions.....they are like armpits,everybody has a couple ,and some stink).I do remember a post awhile back that said that they had finished the wing portion of the upgrade,and it took about 5 manhours to do a wing .Anyways, I'm working on installing the upgrade now.I'll say this I really like the new(.125 thick) aft wing to spar attach point.I always thought the original was not beefy enough.
bill.pagan(at)yahoo.com
PostPosted: Sun Apr 18, 2010 7:55 am    Post subject: 601XL main spar question Reply with quote
My first wing took many more than 5 hours but the 2nd wing is going much faster.
On another note I'm wondering why the factory 601 didn't show up at Sun-N-Fun. Might have given a lot of people a great peace of mind to see it make a long trip. The only 601 there (I was only there on Saturday) looked like it was an AMD but I could be wrong. I only saw the 750 factory plane at their display and a couple 701's (One with a corvair and one with Gus pushing his engine). There was also a customer 801 there that was for sale for $100K plus. Sure would like to have seen the factory 601 on the field. I also didn't see a single 601 parked in the experimental parking area on Saturday.
Bill Pagan
From: "zman601xl(at)aol.com" <zman601xl(at)aol.com>
Sent: Sun, April 18, 2010 11:33:32 AM
I've often wondered why the Zenith demo airplane with 1300 hours on it did not have any sign of failure when they took it apart? My belief also is that there might have been builder error in some of these breakups.Just an opinion(you know what they say about opinions....they are like armpits,everybody has a couple ,and some stink).I do remember a post awhile back that said that they had finished the wing portion of the upgrade,and it took about 5 manhours to do a wing .Anyways, I'm working on installing the upgrade now.I'll say this I really like the new(.125 thick) aft wing to spar attach point.I always thought the original was not beefy enough.
PostPosted: Sun Apr 18, 2010 10:35 am    Post subject: 601XL main spar question Reply with quote
Hi Bill,
I'm well into the first wing upgrade,and it's going ok..I know one thing when I do the second one the leading edge skin is coming off.It will be a lot easier on my back......Smile.I've got to call Zenith.I only received six -3 & six -4 stiffeners for the nose ribs.Problem is I've got the early kit with 4 nose ribs on each side.
Bob Haring
sabrina
PostPosted: Sun Apr 18, 2010 7:09 pm    Post subject: Re: 601XL main spar question Reply with quote
sdthatcher
PostPosted: Mon Apr 19, 2010 5:25 am    Post subject: Re: 601XL main spar question Reply with quote
Sabrina wrote:
taking a break before my Calc-based Physics E&M test on Monday...
The bird looks great! That wouldn't be Palwaukee airport near Chicago would it?
Will your leading edge cuff be riveted back on or are you going to use camloc or other connectors?
Let us know what type of movement you get from your testing.
Scott Thatcher, Port Saint Lucie, FL
601XL with Corvair, Registered as E-LSA
N601EL, EAA203 140 hours and not flying currently.
Page 3 of 4
