leckers
Posted: Sat Apr 10, 2010 12:34 am Post subject: Fuel Pump - dual switching |
I have the original panel mounted switch for the fuel pump on my Glasair - simple 'on/off'. On the copilot side I have the stock stick and only a single PTT on the grip. On the pilot side, I have JD's Infinity grip with one of the switches (at present it is a simple on/off) ear-marked to also operate the fuel pump. I need to retain the panel switch capability so the copilot can operate the pump if (s)he is flying.
My thoughts were along the lines of a switching system like the staircase example of a switch at top and bottom being able to turn on or off the light from either position. I would be quite happy to have a warning lamp to indicate the pump is actually on/running. I need a different type of S700 switch (Which?) on the panel, and also need to find a smaller equivalent type to fit in JD's grip - both of which accomplish the necessary internal switching. (I definitely need assistance with a simple wiring diagram too!). I don't see the necessity for a relay set-up as I've used for the flaps with a similar scenario - normal panel switch and JD's toggle switch on pilot's stick grip. I've been through the chapter in Bob's book on switches a couple of times, but I can't find an applicable example to help me on this - though it is, I have to say, that I may be me missing the obvious - "can't see the wood for the trees" etc. etc.
This particular switching scenario must have been resolved many times before, and I'd be most grateful if a member could point me in the right direction?
_________________ IanL |
bgray(at)glasair.org Guest
Posted: Sat Apr 10, 2010 3:33 am Post subject: Fuel Pump - dual switching |
Hi Ian,
Check a house wiring book.
Bruce
www.Glasair.org
mrspudandcompany(at)veriz Guest
Posted: Sat Apr 10, 2010 5:49 am Post subject: Fuel Pump - dual switching |
IanL
Here is a simple circuit that requires using 2 single pole
double throw (on - on) switches. Hope this helps a bit.
Roger
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
253.93 KB |
Downloaded: |
491 Time(s) |
bbradburry(at)bellsouth.n Guest
Posted: Sat Apr 10, 2010 6:57 am Post subject: Fuel Pump - dual switching |
IanL,
I doubt you will find a switch small enough to fit in JDs grip that will
carry the amps necessary for the fuel pump. If you already know how to do
this with a relay, I suggest you go ahead with that method. Or you can
stick a relay in the schematic that was provided by one of the readers.
Bill B
fvalarm(at)rapidnet.net Guest
Posted: Sat Apr 10, 2010 10:09 am Post subject: Fuel Pump - dual switching |
While the schematic in the drawing will work, I wouldn't use that architecture because it will be confusing. Sometimes switch toggle up will be on and sometimes switch down will be on, depending on the position of the other switch. That drawing is OK for light switches at home or for pushbutton latching switches.
I would just wire both switches in parallel so that either one can turn the pump on, but both must be off to turn pump off. I think this would be best and satisfy 99% of your flying needs without confusion.
My $.02 worth.
Bevan
_____________________________________________
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of ROGER & JEAN CURTIS
Sent: Saturday, April 10, 2010 6:47 AM
Subject: Fuel Pump - dual switching
IanL
Here is a simple circuit that requires using 2 single pole double throw (on - on) switches. Hope this helps a bit.
Roger
<< File: Dual switch fuel pump.pdf >> [quote][b]
Posted: Sat Apr 10, 2010 12:34 pm Post subject: Fuel Pump - dual switching |
When the light is on the pump is on, flip
either switch and it is off. I personally would not find this confusing.
If up, down is confusing, mount the switch for left, right.
If both switches are on they must both be
turned off to shut down the pump.
If you are going this route, might I suggest
that you put a switch on the panel within ease reach of either pilot, fewer
parts, fewer single points of failure.
There are other ways of accomplishing this,
but this is simple and will work.
Roger
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
4.86 KB |
Downloaded: |
595 Time(s) |
leckers
Posted: Mon Apr 12, 2010 12:48 am Post subject: Re: Fuel Pump - dual switching |
Really sorry, but I cannot open either of the .dat files to see the diagram..... Clues? I use Windows 7. Thanks for the suggestions.
Posted: Mon Apr 12, 2010 5:47 am Post subject: Fuel Pump - dual switching |
IanL
Go to (get.adobe.com) and download the reader. This will
allow you to open the [Dual switch fuel pump.pdf] file attached.
Roger
Description: |
 Download |
Filename: |
winmail.dat |
Filesize: |
250.45 KB |
Downloaded: |
549 Time(s) |
leckers
Posted: Mon Apr 12, 2010 6:07 am Post subject: Re: Fuel Pump - dual switching |
Roger - adobe reader will NOT open the file that is in this forum as winmail.dat.
There is no attachment file that I can see in pdf format.
Any chance you could try direct to me ianleckenby(at)yahoo.co.uk? Thanks.
