Eugene Zimmerman
Posted: Wed Apr 07, 2010 5:34 pm Post subject: Looking for help to fix radio noise? |
Kolb friends,
I have been using an A5 ICOM for several years with an external antenna. It gives me good service in reception and transmitting and I am satisfied with it except for one problem, and I know next to nothing about radio tech.
I get lots of interference, or feed over noise whenever I get within two or three miles of a local radio tower.
Is there some kind of antenna filter or something I can use to prevent this?
My antenna I believe came off a general aviation, possibly a Cessna 172.
Any radio experts out there in Kolb land that can point me in the right direction to fix this?
Gene Z
Posted: Wed Apr 07, 2010 5:51 pm Post subject: Looking for help to fix radio noise? |
Gene,
Can you describe your "ground plane".....the area that your antenna mounts to.
If I'm not mistaken, and I'm no expert, I believe you have to have at least a rectangular metal grid, the length of your antenna in each direction, that the antenna mounts in the center of.
You can use 1/2" wide copper tape, soldered in the center of a cross, with all 4 arms 23" long. You then mount the antenna in the center of the cross, making sure you attach the antenna's ground to your "antenna plane".
This is how I understand it. If we have any antenna gurus, I'm sure they can correct me. IIRC, Boyd knows some details on electronics and stuff.
Hope I helped,
Mike Welch
MkIII
[quote] Subject: Looking for help to fix radio noise?
Date: Wed, 7 Apr 2010 18:34:36 -0700
Kolb friends,
icrashrc
Joined: 16 Mar 2006 Posts: 247 Location: Mishawaka, In
Posted: Thu Apr 08, 2010 3:18 am Post subject: Re: Looking for help to fix radio noise? |
Gene,
Obviously we need more info on the type of coax and antenna you're using but here's my best guess...
To my knowledge picking up a radio or TV station when close to the broadcasting tower means you need a balun in your system. Without one it's actually possible to overload and ruin the input side of the radio, if it's not protected internally. I've attached a file with a good description of what a balun does and how to make one yourself. It was easier than typing it all myself!
Scott
 Download |
| Filename: |
Antenna Design.pdf |
1.3 MB |
| Downloaded: |
503 Time(s) |
Eugene Zimmerman
Posted: Thu Apr 08, 2010 4:33 am Post subject: Re: Looking for help to fix radio noise? |
Scott,
Thank you,
That is precisely the kind of help I was looking for.
I will be trying the balun soon.
pj.ladd(at)btinternet.com Guest
Posted: Thu Apr 08, 2010 6:09 am Post subject: Looking for help to fix radio noise? |
I believe you have to have at least a rectangular metal grid, the length of your antenna in each direction, that the antenna mounts in the center of.>>
If an ordinary handheld works fine from a little `rubber ducky` antenna about 6 inches long why is all this other stuff required?
info please
Pat
by0ung(at)brigham.net Guest
Posted: Thu Apr 08, 2010 7:14 am Post subject: Looking for help to fix radio noise? |
Gene Z
| Quote: | >>>>>>>>>>>>>>>>>>>>>>>>>
More specific information needed. Radio, coax, antenna, how mounted and
installed. And I am trusting that you have used an swr meter to make sure
all the components are matched and tuned properly. Not knowing all the
details here is a few possibilities. And if the above is not true,,,,
that would be the first things I would do. NO even if you have done it,
do it again, things change.
By local radio tower am I to understand it is an am or fm radio tower...
or police / public safety system.
The basic problem is your radio inability to filter out the signals from the
radio towers. It could be fixed with a radio with a better filter in the
receiver. Or you could add a filter. Adding a filter may be 1/2 the
cost of a new radio.
For am fm you could install a high pass filter. Which would attenuate
(reduce the signal strength) of all the frequencies below the aircraft band
For public safety,, you could put in a low pass filter
Or for both you could install a band pass filter that would only pass the
aircraft frequencies and attenuate all below and above.
Google band pass filter and see what you can find.
The canister filters that I have used are rather large. 2 x 3 x 12 inches.
However you may be able to find some combination of capacitor and inductor
to hook across the antenna lead that would do the same. Sorry I am not much
help in designing or specifying the parts.
Boyd Young
ham radio operator n7wfm
do not archive.
Ok just read pats reply. The rubber duck should be tuned by the
manufacture to the proper frequency, but because of the nature of rubber
duck antennas, in order to make them short and convenient, they are a
compromise out of the box. A full quarter wave antenna with a ground
plane, or 1/2 wave dipole, should transmit and receive twice as far,
don't get me completely wrong, the rubber duck may go 50 miles or so
provided it is mounted in such a way that the signal is not blocked by
surrounding structure.
Posted: Thu Apr 08, 2010 12:19 pm Post subject: Looking for help to fix radio noise? |
Pat,
The flexible antenna that is usually found on handheld radios is a compromise, at best. It is a skinny wire of about 23" or 58.5 cm, or so, coiled up and cast in rubber.
In an open environment, it works sufficient to allow for "basic" radio reception. It is hardly the best antenna, it just happens to be the most practical......for a handheld radio.
But, in an aircraft structure, which often means lots of metal, it's ability to receive and transmit is significantly diminished. Therefore, a person might have to resort to better antenna designs to achieve proper reception, if you want to use the handheld radio in an aircraft.
There are several "types" of antennas. The dipole antenna Scott shared with us is one. The is also the conventional aircraft mast, and the copper foil antenna (usually for fiberglass airplanes), to name a couple more. (I made one of these copper foil antennas for my GlaStar. I avoided the need for a balun by using tri-ax cable)
The are many other antenna designs, each fulfilling it's best role in performance and practicality.
As I said before, I'm no antenna expert, but I did play one on tv once. (I was an electronics and electrical engineering student in college)
For a radio to perform very well, a ton of factors must be taken into account. These factors are what an electronics expert could use to design a decent antenna with.
Mike Welch
Subject: Re: Looking for help to fix radio noise?
Date: Thu, 8 Apr 2010 15:05:26 +0100
info please
Pat
The New Busy is not the old busy. Search, chat and e-mail from your inbox
Posted: Fri Apr 09, 2010 2:25 am Post subject: Looking for help to fix radio noise? |
Hi Mike,
thanks very much. i am still playing with mine as I don`t use it a lot. I just used the extension lead supplied with the radio.(which i bought from John H some years ago) an stuck the rubber ducky on the end sticking out below the pod. i think it picks up a signal OK until the engine is run. Then its useless.
i was thinking more about shielding from the engine but perhaps I should investigate further.
The Eurostar which I previously had a share in had a hand held wired in but necause it worked perfectly on delivery I never investigated further.
First flight of the season yesterday. An hour in perfect weather. Did a timed climb, a Vne dive, and a couple of stalls to get the figures for my annual permit and then just swanned around enjoying the glorious Spring countryside.
Having not flown since last September I have an excuse for making a bog of the landing. Much too high and had to go round. I had to do a baulked landing for the permit as well so that was useful. Unfortunately the engine stopped on my second approach. i took the flap off a bit smart to extend the glide and just squeaked in over the hedge.
Engine started again to taxi in but on inspection I found a plug lead had become detached. A bungee seems to be indicated to hold the leads on.
All part of lifes rich pattern.
Cheers
Pat
Posted: Fri Apr 09, 2010 6:38 am Post subject: Looking for help to fix radio noise? |
its useless.
Pat
Patrick/Gang:
Install a 20,000mf capacitor, or there abouts, in the 12VDC wires after the
regulator/rectifier. The capacitor will act like a big filter and soak up
much of the ignition and alternator noise.
john hauck
_________________ John Hauck
Titus, Alabama |
Posted: Fri Apr 09, 2010 8:09 am Post subject: Looking for help to fix radio noise? |
| Quote: | regulator/rectifier. The capacitor will act like a big filter and soak up
john hauck
John,
I've heard of this remedy before ( I think from you a couple of years ago). Exactly how would a person hook up this capacitor? IIRC, it hooks up between the + & - posts of the battery, correct?
Aslo, is this something everyone should do (that uses a radio), or do you think only on a "as needed" basis?
Mike Welch
MkIII
The New Busy think 9 to 5 is a cute idea. Combine multiple calendars with Hotmail. Get busy. [quote][b]
Posted: Fri Apr 09, 2010 8:34 am Post subject: Looking for help to fix radio noise? |
Mike Welch
MkIII
Mike W/Gang:
Like a lot of things, I learned it by chance.
Put lights on a dirt bike without a battery. Bought a kit from JC Whitney.
Kit included a small capacitor (battery replacement).
Wanted to take advantage of the alternator on the 447 on my Firestar,
remembered the JC Whitney kit and stole the capacitor from the old dirt
bike.
A year later, during modification and repairs of FS, decided I probably
didn't really need that capacitor, so I did not reinstall it. First flight
I could not use my radio to receive or transmit. The ignition and
alternator noise overwhelmed the it. I reinstalled the capacitor and the
noise went away. Additionally, I had to run resisitor plugs (against Rotax
recommendation not to)(no change in performance or reliability was observed)
and shield the plug wires and run metal resisitor NGK plug caps.
The capacitor has a + and - terminal. + goes to the 12VDC positive wire,
and the - goes to a good ground on the airframe.
john hauck
Titus, Alabama |
Posted: Fri Apr 09, 2010 2:43 pm Post subject: Looking for help to fix radio noise? |
On 4/9/2010 11:28 AM, John Hauck wrote:
between the +& - posts of the battery, correct?
Mike Welch
MkIII
Mike W/Gang:
bike.
john hauck
To add to what John told you, if you hook up the capacitor at the
battery it isn't likely to help you much. (The battery itself does a
pretty good job of filtering noise at its terminals.)
Try putting it as close to the noise generator (typically the alternator
or generator) terminals as is reasonably possible. You can add another
one as close to the radio's power terminals as possible, also, if the
1st one doesn't do the trick.
Having said all that, it's possible that the radio station's transmitter
could just be overwhelming your radio's 'front end'. If that's
happening, think about that HEE HAW TV doctor's advice: "If it hurts
when you do that, don't do that" (go near the radio transmitter) I know
that's not much of a solution, but it might end up being the only one
that's not financially painful.
Posted: Sun Apr 11, 2010 7:31 am Post subject: Looking for help to fix radio noise? |
Mike Welch
MkIII
Yes... everyone should consider it. It will smooth out the electrical
noise in the system. One other thing that you can do is to take an old
film canister, or pill bottle. Cut a small piece of tubing that will run
from end to end, wrap a wire around the tubing, and slide it into the
canister. This will work as a resistor to voltage spikes by preventing a
spike from going straight through. And when there is a voltage drop, it will
try and keep the electricity flowing more evenly. A lot of your high end
car stereos will have these installed on the main power lead.
Boyd Young
