rickofudall
Posted: Mon Apr 05, 2010 9:39 am Post subject: Seats for a MkIIIC |
Has anyone come up with a seat for the Mk IIIC that offer more support than the sling seat? I'm getting cramps in my right thigh and haven't been able to find a position that relieves cramp. I've been looking at the molded seats at Jegs and thought I might as well inquire of the forum members to see if anyone else has already come up with better seating. I have the upholstery insert from Kolb that velcros in but it doesn't offer anything but a little padding. This is the seat I've been thinking about
http://www.jegs.com/p/JEGS/JEGS-Pro-High-Back-Race-Seats-Seat-Covers/763085/10002/-1
[url=http://www.jegs.com/p/JEGS/JEGS-Pro-High-Back-Race-Seats-Seat-Covers/763085/10002/-1][/url]
Rick Girard
lcottrell
Posted: Mon Apr 05, 2010 11:13 am Post subject: Seats for a MkIIIC |
Why not just put an aluminum sheet across the bottom and then use the sling for the back. You could could then use Tempra (type) foam for the bottom. Much lighter.
Larry
Note: If you forward this email, please delete the forwarding history, which includes my email address.
rickofudall
Posted: Mon Apr 05, 2010 12:03 pm Post subject: Seats for a MkIIIC |
I almost feel guilty saying this, but my leg hurt so much after 45 minutes on Saturday, I really don't care if a seat weighs 20lb. Lightness doesn't do me any good if I can't fly for pain. Getting rid of the sling back is the second objective. I've straightened the top bar so many times it has all the stiffness of warm dog exhaust.
Rick
On Mon, Apr 5, 2010 at 2:10 PM, Larry Cottrell <lcottrell(at)fmtcblue.com (lcottrell(at)fmtcblue.com)> wrote:
[quote] Why not just put an aluminum sheet across the bottom and then use the sling for the back. You could could then use Tempra (type) foam for the bottom. Much lighter.
Larry
by0ung(at)brigham.net Guest
Posted: Mon Apr 05, 2010 12:34 pm Post subject: Seats for a MkIIIC |
Rick Girard
Rick
I bought some seats that come out of a piper tomahawk. there were some rollers used for moving the for and aft, that I removed. and the pins that hold the seat in the for and aft position,,, I use to take the seat in and out quickly. they couple into some brackets I made and welded in place.
just for fun. the fbo had a seat out of a Cessna 150 that I trial fit. they would have been a second choice. I cant remember now what type of brackets I would have had to build.
I know I have taken some pictures but cant find them right a way. probably on the old computer.
Boyd Young
Kolb mkIII
Posted: Mon Apr 05, 2010 1:18 pm Post subject: Seats for a MkIIIC |
Getting rid of the sling back is the second objective. I've straightened the....>
dont you guys have the upholstered seats that Kolb issued. Very smart with the logo. As for bending the bar....what do you do?. i weigh 210 lbs straight out of the shower so I reckon at least another 20lbs for clothes and I couldn`t bend the bar if I jumped on it.
Cheers
Pat
Posted: Mon Apr 05, 2010 2:00 pm Post subject: Seats for a MkIIIC |
Rick,
I had one of those molded plastic seats that Jeg's sells. It was the standard issue seat that the Wizard ultralight (looks like a Quicksilver) came with.
The seat is double walled, very sturdy, and also quite heavy. It would be a chalenge to get it installed into your MkIII properly, but I know you could handle it. However!!!!.....
Personally, if it were me, I'd be looking to make my own custom fiberglass drop-in shell.
You could then use the Kolb seat cushion, and it ought to work "mightly fine".
(Essentially, this is what TNK sells for the Xtra. That might also be a possibility, but it may need some trimming, too.)
I'd probably drop the actual seat mold shell down a little, so I could come back in with a glued in layer of the temperfoam.
Although you might be able to use that Jeg's seat, I think you'd have to cut it up quite a bit, in addition to some MkIII surgery.
Mike Welch
MkIII
Date: Mon, 5 Apr 2010 12:37:44 -0500
Subject: Seats for a MkIIIC
Rick Girard
Hotmail has tools for the New Busy. Search, chat and e-mail from your inbox. Learn more. [quote][b]
russkinne(at)mac.com Guest
Posted: Mon Apr 05, 2010 2:21 pm Post subject: Seats for a MkIIIC |
In re seats -- Ken Brock made up a seat-tank years ago that held 5
gallons or more. Sounds like a good idea, tho it must be COLD in the
winter.
Someone must have tried this? Good or bad?
rickofudall
Posted: Mon Apr 05, 2010 3:45 pm Post subject: Seats for a MkIIIC |
Boyd, Real aircraft seats, well that's one I hadn't thought of.Pat, We're about the same weight, I wonder if my Mk III being an early model, the tubing is a thinner wall than what's made now. All I know is that it's been bending since I bought the airplane and I'm tired of straightening it.
Mike, I was afraid of that, simple solutions rarely are.
Russ, There's a brace behind the seat that would most likely prevent using the Brock seat.
I thank you all, I shall have to do some more research.
Rick
On Mon, Apr 5, 2010 at 5:18 PM, russ kinne <russkinne(at)mac.com (russkinne(at)mac.com)> wrote:
[quote]--> Kolb-List message posted by: russ kinne <russkinne(at)mac.com (russkinne(at)mac.com)>
In re seats -- Ken Brock made up a seat-tank years ago that held 5 gallons or more. Sounds like a good idea, tho it must be COLD in the winter.
http://forums.matronics.com
le, List Admin.
Dana
Posted: Mon Apr 05, 2010 3:58 pm Post subject: Seats for a MkIIIC |
At 06:18 PM 4/5/2010, russ kinne wrote:
| Quote: | --> Kolb-List message posted by: russ kinne <russkinne(at)mac.com>
winter.
Someone must have tried this? Good or bad? |
I almost bought a seat tank for my UltraStar, but then I sat in one in my friend's gyrocopter. I don't know how cold it is, but it's not terribly comfortable. Decided to keep the existing (comfortable) fiberglass seat and install a custom aluminum tank behind the seat.
-Dana
Assassins do it from behind. [quote][b]
zeprep251(at)aol.com Guest
Posted: Mon Apr 05, 2010 4:25 pm Post subject: Seats for a MkIIIC |
Rick,
I'll take some pictures of the set up in my MK-3,not of my doing but comfortable.I think Russ Kinne
was a passenger one time.
G.Aman
ASchlem
Posted: Mon Apr 05, 2010 4:33 pm Post subject: Re: Seats for a MkIIIC |
There is a post out there where a guy used seats out of a Rans S6/7. He had some good photos of the install. Also his setup was adjustable.
ASchlem
Posted: Mon Apr 05, 2010 4:48 pm Post subject: Re: Seats for a MkIIIC |
Here is a link to his site. http://www.kilocharlie.us/Kolb%20history.htm The seat info is about half way down the page
rickofudall
Posted: Mon Apr 05, 2010 4:51 pm Post subject: Seats for a MkIIIC |
Thanks, I appreciate it.
Rick
On Mon, Apr 5, 2010 at 7:23 PM, <zeprep251(at)aol.com (zeprep251(at)aol.com)> wrote:
[quote] Rick,
G.Aman
Richard Pike
Posted: Mon Apr 05, 2010 5:43 pm Post subject: Re: Seats for a MkIIIC |
I know what ya mean about bending that tube. I replaced mine with one that had a LOT more wall thickness. Cured that -
Also know what ya mean about cutting off circulation to the leg. I fit pretty good, no problems, but the Good Lookin' Old Poop needs a pad under her leg over the front tube, the stock seat thing just doesn't fit right for her.
Richard Pike
MKIII N420P (420ldPoops)
rickofudall
Posted: Mon Apr 05, 2010 6:01 pm Post subject: Seats for a MkIIIC |
You don't post your name but I do appreciate the lead, so thanks ASchlem.
Rick
On Mon, Apr 5, 2010 at 7:48 PM, ASchlem <aschlem77(at)yahoo.com (aschlem77(at)yahoo.com)> wrote:
[quote]--> Kolb-List message posted by: "ASchlem" <aschlem77(at)yahoo.com (aschlem77(at)yahoo.com)>
http://forums.matronics.com/viewtopic.php?p=293122#293122
le, List Admin.
rickofudall
Posted: Mon Apr 05, 2010 6:24 pm Post subject: Seats for a MkIIIC |
Thanks, Richard.
Rick
On Mon, Apr 5, 2010 at 8:43 PM, Richard Pike <richard(at)bcchapel.org (richard(at)bcchapel.org)> wrote:
[quote]--> Kolb-List message posted by: "Richard Pike" <richard(at)bcchapel.org (richard(at)bcchapel.org)>
Richard Pike
http://forums.matronics.com/viewtopic.php?p=293135#293135
le, List Admin.
ASchlem
Posted: Mon Apr 05, 2010 6:30 pm Post subject: Re: Seats for a MkIIIC |
Sorry, new to the group. My name is Aaron. I'm working on a MarkIIIX
Posted: Mon Apr 05, 2010 6:39 pm Post subject: Seats for a MkIIIC |
At 06:43 PM 4/5/10 -0700, you wrote:
her.
Richard, & Richard,
I like my full sling seat. I am short legged, and so at first I used a lot
of padding to move my self forward so that I could reach the rudder pedals.
Then I realized that, if I released the material from the lower rear cross
tube and hiked up the back it would form a true sling seat that would
automatically slide me forward. It almost worked too well, in that I
slipped too far forward, and I had to remember to push my self back in the
seat.
Although I could reach the rudder pedals ok, I found that after an hour
flight, I staggered like a drunk upon arrival. The front cross piece was
cutting into the back of my legs and cutting off the circulation. To get
around this problem I made a cheek board and some padding to raise my cheeks
a sufficient amount to get the pressure off my legs and to prevent the
problem. Currently, the whole works weighs a little over 1.5 pounds.
A true sling seat has a tendency to let your rear end swing around a little
in rough air. I found a five point set belt and shoulder harness seems to be
the answer to this problem, and it also prevents you from sliding forward
during the flight.
How the cheek board was made can be seen at:
http://jackbhart.com/firefly/firefly37.html
FWIW
Jack B. Hart FF004
Winchester, IN
rickofudall
Posted: Tue Apr 06, 2010 2:59 am Post subject: Seats for a MkIIIC |
Thanks, Jack. I always like looking at your work.
Rick
On Mon, Apr 5, 2010 at 10:41 PM, Jack B. Hart <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)> wrote:
[quote]--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
her.
Richard, & Richard,
seat.
during the flight.
FWIW
Jack B. Hart FF004
Winchester, IN
le, List Admin.
rayw
Joined: 18 Jul 2009 Posts: 25 Location: Wisconsin, Central
Posted: Tue Apr 06, 2010 4:04 am Post subject: Re: Seats for a MkIIIC |
How about a go-kart seat? I would think a lot lighter than those JEGS seats.
http://www.bmikarts.com/shop/?shop=1&cat=176
Click for larger image Go Kart Bucket Seat
Bucket Seat Complete with Seat Brackets and Hardware. Sold with or without seat cover. Seat cover also sold seperately.
High Impact Nylon Seat.
Reinforced Mounting Sockets
Part #400511 (with Cover) $89.95
Part #400510 (no Cover)$59.95
Part #400509 (Cover Only) $42.95
SKU Number:400510
Price: $59.95
Seat Cover: Without Cover #400510 ($59.95)With Cover #400511 ($89.95)Cover Only #400509 ($42.95)
3250:=:59.95,3251:=:89.95,3569:=:42.95
Quantity:
