outrigger wheels
roberthatton1(at)googlema
PostPosted: Wed Mar 31, 2010 10:53 am    Post subject: outrigger wheels Reply with quote
Hello Fred,
I know this is an old thread, but did you go with these wheels and if so, what did you think? I am about to replace mine and I too am looking for a better outrigger wheel.
Rob
A128
On Wed, Sep 23, 2009 at 7:56 PM, Fred Klein <fklein(at)orcasonline.com (fklein(at)orcasonline.com)> wrote:
Guys...I've been looking into substitutes for the kit-provided outrigger wheel, and thought I'd found the answer with a Colson Performa wheel which comes w/ sealed ball bearings. After Kingsley acquainted me w/ the distinction between "sealed ball bearings" and "maintenance-free precision ball bearings" I found the following in the McMaster catalogue (I hope the text and graphics gets thru the matronics server). This "Easy-Roll Rubber-Tread Wheel" (McMaster part # 2439T42) which comes with "maintenance-free precision ball bearings" has a ridiculous low price of $7.81. I've queried McMaster, and they confirm that yes, it does come w/ these bearings. I'm wondering if anyone has tried them and can comment on their performance.
Or...has anyone found the ultimate outrigger wheel?
Fred
A194
Easy-Roll Rubber-Tread Wheels [img]cid:1C81C9C3-3FEC-427E-BA07-FF2EEDF7E7FF[/img] 3 1/2" to 6" Dia.
[img]cid:B7A55908-0BAA-4E6A-A009-E4BADA0E7EEA[/img] 8" to 10" Dia.
  • Blue rubber on nylon core
  • Durometer is 70A
  • Temperature range is -40° to +200° F
   Resilient rubber tread rebounds quickly, so you can roll and turn easily on most surfaces. The maintenance-free precision ball bearings require minimal effort to get these wheels rolling.
Wheel Size, For Axle Hub Cap. Ea.,   Dia. x Wd. Dia. Lg. lbs. Each 3 1/2" x 1 1/4"  3/8" 1 5/8" 225 2439T41 $7.10 4" x 1 1/4"  3/8" 1 5/8" 250 2439T42 7.81
 Filesize:  4.03 KB
 Viewed:  3348 Time(s)
 Filesize:  5.38 KB
PostPosted: Wed Mar 31, 2010 12:02 pm    Post subject: outrigger wheels Reply with quote
Rob,
No I did not...as w/ so many aspects of our passion, there is a whole
world, if not a universe, to be explored w/ respect to wheels and
bearings, in particular the distinction between bearing types (seems
there are varying grades of "precision").
I ended up with the following, purchased online at www.skates.com:
2 - 100 mm inline skate wheels w/ ABEC 5 bearings (installed); these
wheels, weighing 0.6 pounds each, somewhat harder (82 durometer) than
the Colson wheels (65 durometer) but resilient nonetheless, are fine
silent spinners, noticeably quieter, and much easier to spin up, much
longer running than wheels w/ non-precision bearings.
4 - ABEC 9 bearings which can be substituted for the ABEC 5s...the
best bearings I could find short of going to ceramics.
8 - aluminum 8 mm spacers...4 of each of two types...potentially
useful when installing the wheels on the Europa forks...to center the
wheels on the forks will require shortening of the spacers.
A hint at how these bearings are removed and changed: Insert one of
the spacers w/ the reducers on each end into the installed wheel
bearing...gently "rock" the bearing from side to side...they will move
outward from the wheel hub in small increments...work patiently, and
they will then "pop out". This technique was recommended by the wheel
sellers and I've found that it does in fact work, though patience is
key.
Enjoy,
Fred
PS: ZERO FLIGHT EXPERIENCE OR TESTING !!
acrojim7534(at)YAHOO.COM
PostPosted: Wed Mar 31, 2010 12:49 pm    Post subject: outrigger wheels Reply with quote
I'm on my second set of the Performa wheels, and I have nothing but good to say..
I fly off paved runway's 99 % of the time, The bearings are needle bearings, they are full length in the hub. Much more robust than the wheels with ball bearings on each side of the wheel...
Grease the bearing when you install the wheel, and they will be good to next annual.... The wheel will wear out before the bearings do, on paved runways...
Jim Brown
Monowheel N398JB
From: Robert Hatton <roberthatton1(at)googlemail.com>
Sent: Wed, March 31, 2010 2:51:28 PM
Subject: Re: outrigger wheels
Hello Fred,
Rob
A128
Fred
A194
Easy-Roll Rubber-Tread Wheels [img]cid:1.3654932008(at)web45006.mail.sp1.yahoo.com[/img] 3 1/2" to 6" Dia.
[img]cid:2.3654932008(at)web45006.mail.sp1.yahoo.com[/img] 8" to 10" Dia.
  • Durometer is 70A
 Filesize:  4.03 KB
 Viewed:  3342 Time(s)
 Filesize:  5.38 KB
PostPosted: Wed Mar 31, 2010 9:45 pm    Post subject: outrigger wheels Reply with quote
Jim...nuthin like an endorsement by someone who's had some real experience...thanks for your comment..I'll hang onto my set of Performa wheels...just in case.
From my armchair, I got to thinkin about those wheels...after ordering a set of Performas, by chance I happened to notice that it's the same wheel used on the carts at Costco, a use where robustness and maintenance (and cost) were doubtless considered. Still, the forward speed for those carts can't be more than 2 mph, and at the time I believe I figured that our outriggers were spin up to approx. 5000 rpm at TO and landing speeds if memory serves...a very different performance environment...that realization made me look further.
I do know of two mono drivers who swear by their skate wheels...so there's doubtless more than one way to skin this cat...
Fred
A194
still a'buildin
Jim Brown
Monowheel N398JB
From: Robert Hatton <roberthatton1(at)googlemail.com (roberthatton1(at)googlemail.com)>
Hello Fred,
Rob
A128
Fred
A194
Easy-Roll Rubber-Tread Wheels<2439tp1s.gif>3 1/2" to 6" Dia.
<2439tp2s.gif>8" to 10" Dia.
  • Durometer is 70A
Wheel Size,For AxleHubCap. Ea., Dia. x Wd.Dia.Lg.lbs.Each3 1/2" x 1 1/4" 3/8"1 5/8"2252439T41$7.104" x 1 1/4" 3/8"1 5/8"2502439T427.81
kevann(at)gotsky.com
PostPosted: Thu Apr 01, 2010 4:51 am    Post subject: outrigger wheels Reply with quote
Do you guys have a part # for the wheels your speaking of?
Kevin
PostPosted: Thu Apr 01, 2010 9:23 am    Post subject: outrigger wheels Reply with quote
Hi Kevin,
If you're askin bout the Performa wheel, go to mcmaster cat. pg 1347...there are different part #s for different bearing types.
If you're askin bout the in-line skate wheels, I don't have a part # handy, but the specs of the wheels I purchased were listed in my first email yesterday.
Fred
erichdtrombley(at)juno.co
PostPosted: Fri Apr 02, 2010 7:03 am    Post subject: outrigger wheels Reply with quote
I am one of those mono guys that has been using the scooter wheel since day one on my Eruopa. Not realizing just how good these little wheel are I purchased several sets from the local sporting goods store thinking I was going be changing them out frequently. However, after seven years of flying I am still only on my second pair. These wheels are the 100mm diameter with abec 5 bearings. I don't know what the hardness of these are however, they seem to be soft. I made my own mouting hardware, getting rid of the Europa bracket. The wheels fit perfectly within the width of the outrigger leg. The scooter wheels are significantly lighter, very durable, long lasting, and quite. The lighter weight may even help keep the outriggers from sagging.
Erich Trombley
N28ET Classic Mono 914
____________________________________________________________
2547% Penny Stock Picks?
Our last pick exploded 2547% - Join our free newsletter today!
PennyStockAdvice.com [quote][b]
Fergus Kyle
PostPosted: Fri Apr 02, 2010 7:03 am    Post subject: Outrigger wheels Reply with quote
PPS:
I forgot yo mention page 1304 of the catalogue gives some explanation for picking the proper wheels....
Ferg [quote][b]
PostPosted: Fri Apr 02, 2010 7:46 am    Post subject: outrigger wheels Reply with quote
Hi Ferg...thanks for the price update on those wheels!!...the $7.81
price was good back in Sept. '09.
BTW, I don't know of anyone who has inspected or mounted that
particular wheel. Although it's still reasonably priced, as I learned
more about the world of precision bearings, there are multiple grades
(ABEC ratings). If I recall correctly, these "Easy-Roll" wheels,
although they do have "maintenance-free precision bearings", they have
the lowest possible rating.
I wouldn't imagine that parts ordered from www.skates.com would raise
any eyebrows with the technology-transfer-police...see my email of 31
Mar 10. The wheels I ordered came w/ ABEC 5 bearings...for a few more
bucks I also ordered some ABEC 9 bearings, but frankly, the wheels w/
the #5 bearings are wonderful silent spinners and I see Eric Trombley
has had good experience with them.
Fred
PostPosted: Fri Apr 02, 2010 3:19 pm    Post subject: outrigger wheels Reply with quote
Fred
