912ULS Water Inlet Part 922 218
Tommy Walker
PostPosted: Mon Mar 29, 2010 7:24 am    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
Listers,
I've installed a 912 in my plane using the Rotax Ring Mount. The engine seems much less prone to vibration and kickback at startup and shutdown.
However, I do have a problem and I'm looking for solutions:
The water inlet to the water pump is a 90 degree fitting. This puts it in line with the Ring Mount with about 2 inches clearance (maybe less). I have to run my hose from there to my radiator and to get it to fit, I now have about a 1/2 inch or more offset on the hose in order to clear the backside of the Ring Mount. I don't like this as it puts stress on the rubber hose.
Any ideas? Does Rotax make an inlet with perhaps a 45 degree turn instead of the 90 degree? Any help appreciated.
Tommy Walker in Alabama
N8701T
Tommy Walker
N25A - Anniston, AL
hgmckay
PostPosted: Mon Mar 29, 2010 10:05 am    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
Tommy,
Do you have the 912 Installation Manual? If so look on page 57 of the
manual. You will see figures 27 and 28 showing the water pump inlet. You
will see that there are six positions for this inlet. See if one of them
meet your needs. If you don't have this manual get one!
Hugh McKay
Allegro 2000
Rotax 912 UL
N661WW
Sent: Monday, March 29, 2010 11:24 AM
To: <rotaxengines-list(at)matronics.com>
Subject: 912ULS Water Inlet Part 922 218
<twalker(at)cableone.net>
Listers,
rubber hose.
N8701T
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p=292221#292221
craig(at)craigandjean.com
PostPosted: Mon Mar 29, 2010 10:53 am    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
Actually as I recall the Zenith manual for the new FWF with the ring mount
tells you to rotate (and reseal) the threaded 90 degree elbow in the plate.
I think Tommy's complaint is the 90 degree angle, not the orientation but
let's see what he says.
-- Craig
Tommy Walker
PostPosted: Tue Mar 30, 2010 4:51 am    Post subject: Re: 912ULS Water Inlet Part 922 218 Reply with quote
Craig,
Yes, that is my complaint. A 45 degree ell would work fine. No matter how I turn the inlet, it runs directly toward the Ring Mount.
Hugh,
Yes, I have the Rotax manuals and refer to them often. Turning the inlet still doesn't avoid the Ring Mount.
Surely someone has run into this problem before. Zenith instructions are to run the hose in front of the Ring Mount, but there's no room because of the two left side cylinder head hoses in this area.
Thanks for the comments.
Tommy
Tommy Walker
N25A - Anniston, AL
flyadive(at)gmail.com
PostPosted: Tue Mar 30, 2010 5:53 am    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
Hello Tommy:
One trick I was taught many years ago was: "If you can't do it with a
45... You can do ANYTHING with two 45's."
The swivel combinations with two 45's are almost endless.
And that way you can keep a straight fitting on the hose.
Barry
On Mon, Mar 29, 2010 at 11:24 AM, Tommy Walker <twalker(at)cableone.net> wrote:
Listers,
N8701T
Tommy Walker
Tommy Walker
PostPosted: Tue Mar 30, 2010 7:20 am    Post subject: Re: 912ULS Water Inlet Part 922 218 Reply with quote
I wonder if I could take two 45's and a short 2 inch copper fitting and make it work. Does anyone know if a sweated joint would hold up? Each end of the fitting would be clamped to a rubber hose (thinking out loud).
flyadive(at)gmail.com wrote:
Hello Tommy:
Barry
[/quote]
Tommy Walker
N25A - Anniston, AL
PostPosted: Tue Mar 30, 2010 7:53 am    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
I don't know if you can put together a solution from these silicon hose
elbows from Pegasus but take a look around their web site:
http://www.pegasusautoracing.com/group.asp?GroupID=COOL22MM
-- Craig
elleryweld(at)aol.com
PostPosted: Tue Mar 30, 2010 2:15 pm    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
I have some copper sweated fittings on my airplane and they have been working great but one thing I did to keep the hose from coming off is wrap a peice of small copper wire around the fitting end that I was planning on putting my rubber hose on and sweat that wire in place I figured when I tightened the clamp it would give it a good bite so the hose dont slip off
Ellery Batchelder Jr.
Tommy Walker
PostPosted: Wed Mar 31, 2010 4:29 am    Post subject: Re: 912ULS Water Inlet Part 922 218 Reply with quote
Thanks for the suggestions folks. I'm looking at using silver solder to join the fittings. Craig, I'm looking at the Pegasus site too. Lots of interesting stuff there.
I have a beading tool borrowed to put a bead in the copper tubing to hold the hose. ACS sells them for about 55.00 bucks each size.
Plus I'm looking to another solution sent in an off forum email.
Thanks!
Tommy
Tommy Walker
N25A - Anniston, AL
Tommy Walker
PostPosted: Sun May 02, 2010 10:57 am    Post subject: Re: 912ULS Water Inlet Part 922 218 Reply with quote
Note: I resized the picture and uploaded it again. Sorry bout that.
I'm glad that I posted this problem on the Rotax Forum. Paul Mitchell, the Tecnam dealer in the UK had the perfect fix for my issue. Paul was coming to SNF and parcel posted it to me when he got here. I received it the next day and went out to the airport and replaced the stock one with it.
Ain't it great how folks like Paul will go out of their way to accommodate those of us in the builder community?
Tommy Walker the happy camper
N7462M - Sold
N8701 - Sold
N8701T - Sold
....searching for next project
Sorry the picture is so big. Sad
Thanks!
Tommy
Crying or Very sad
 Filesize:  171.34 KB
 Viewed:  14790 Time(s)
Tommy Walker
N25A - Anniston, AL
PostPosted: Sun May 02, 2010 11:15 am    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
So what was the fix? What does it look like and where does he get them from?
Pictures?
-- Craig
Tommy Walker
PostPosted: Sun May 02, 2010 12:27 pm    Post subject: Re: 912ULS Water Inlet Part 922 218 Reply with quote
Hi Craig,
I uploaded a picture with the post. You may have to go to the forums.matronics website in order to see it. It was sort of a big picture. What they did was take a piece of flat stock and some tubing and make a ninety degree El (is that redundant?).
The picture is too big and your email server may have stripped it out.
Let me know if you still can't see it on the matronics site and I will email a smaller version to you.
Tommy
Pictures?
-- Craig
Tommy Walker
N25A - Anniston, AL
PostPosted: Sun May 02, 2010 12:53 pm    Post subject: 912ULS Water Inlet Part 922 218 Reply with quote
Got it, thanks. I wonder how the rest of the world solves the problem.
Wouldn't anyone with the ring mount need a similar solution?
-- Craig
Tommy Walker
PostPosted: Sun May 02, 2010 1:09 pm    Post subject: Re: 912ULS Water Inlet Part 922 218 Reply with quote
I would think so. Someone said Rotax said to rotate the inlet neck and thread the hose in front of the Ring Mount. That wouldn't work in my situation.
Oh well....
Smile
-- Craig
Tommy Walker
N25A - Anniston, AL
