dgraham7(at)TWCNY.RR.COM Guest
Posted: Sat Mar 27, 2010 2:54 pm Post subject: Ask the Dar |
Hey guys, I own a 601 HDS and I was considering a future switch to the HD wings and then flying LSA. I wanted to know the procedure so I sent a note to the "Ask the DAR" column at Kitplanes. Here is his answer. (He sent me a personal reply, which I appreciate).
Damien
Ron Lendon
Posted: Sat Mar 27, 2010 4:18 pm Post subject: Ask the Dar |
Ron:
I don't know what happened. I will try to forward it again.
Damien
DO NOT ARCHIVE.
psm(at)att.net Guest
Posted: Sat Mar 27, 2010 4:32 pm Post subject: Ask the Dar |
Hi Damien,
I'm sure the Mel is correct with regard to the actual rules.
On the other hand, if you happen across a CH601HD it might be impossible to discover that once apon a time it had HDS wings on it. Also, some folks seem to think an HDS actually meets the LSA definition. It is mostly a matter of the stall speed which might be considerably different from one home-built plane to another.
This is just one example of many I have run across where the new rules are both unfathomable and a bit ridiculous. I think the intent was to keep people from "Pencil whipping" planes (like C-140s) that are a bit above the LSA definition to change them to just within the specs. This is just one of those things that makes a lot of sense to a government bureaucrat but is crazy to a normal person.
Good luck,
Paul
XL installing upgrade
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Damien
Sent: Saturday, March 27, 2010 3:54 PM
Subject: Fw: Ask the Dar
Damien
----- Original Message -----
To: dgraham7(at)twcny.rr.com (dgraham7(at)twcny.rr.com)
Cc: Marc Cook (marc(at)kitplanes.com)
Sent: Saturday, March 27, 2010 2:03 PM
Subject: Re: Ask the Dar
First off, you can never "recertify" an aircraft to make it LSA. If the aircraft meets light-sport parameters, it may be flown by a sport pilot regardless of its classification.
To change the wings on your aircraft would require a model change by amending the airworthiness certificate and operating limitations. This could be done by either the FAA or a DAR holding function code 33.
However in you case this would not solve your problem as the light-sport rules require that the aircraft must have continuously met light-sport parameters from it's original certification. Since you aircraft has been certificated and flying with flight characteristics outside of light-sport rules, it could never qualify as being "light-sport compliant."
Sorry, I know this is not the answer you're looking for.
Mel
972-784-7544
To: Mel Asberry (n168tx(at)flytx.net)
Sent: Tuesday, March 23, 2010 9:12 PM
Subject: Fwd: Ask the Dar
naumuk(at)windstream.net Guest
Posted: Sat Mar 27, 2010 6:22 pm Post subject: Ask the Dar |
Damien-
What you're going through has been revisited a couple of times a year on this and other lists.
An HDS will absolutely qualify Light Sport using VGs ,and in many cases without. Additionally, an HD absolutely qualifies to begin with. The sticking point is, either configuration has to meet LS requirements AT THE TIME the AC is issued.
My hypothesis is, HDS and other models have been happily putting along LS legal since long before the requirements were finalized. However, since early builders didn't have a specific stall speed goal to shoot for, they were sloppy about what they entered into their operation manuals and unknowingly killed half the utility and resale value of their aircraft. It's sad there is no way correct the mistake retroactively, but ....
Bill
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sat Mar 27, 2010 7:01 pm Post subject: Ask the Dar |
I do not recall anyone but me ever seeing my ops manual and it get revised as needed.
Floyd Wilkes
601XL hopefully mod finished tomorrow and flying again!!
From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of Bill Naumuk
Sent: Saturday, March 27, 2010 9:16 PM
Subject: Re: Fw: Ask the Dar
Damien-
Bill
To: zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)
Sent: Saturday, March 27, 2010 6:54 PM
Damien
Mel
972-784-7544
Begin forwarded message:
Date: March 23, 2010 6:15:01 PM PDT
To: <editorial(at)kitplanes.com (editorial(at)kitplanes.com)>
Subject: Ask the Dar
Hello. I own a Zodiac 601 HDS. I am not the builder. The 601 HDS does not qualify as LSA because of the high stall speed. I would add the HD wings, which does qualify for LSA. Would I have to recertify the plane to make it LSA? Does the plane need to be inspected again?
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-Listhref="http://forums.matronics.com">http://forums.matronics.comhref="http://www.matronics.com/contribution">http://www.matronics.com/c | | 0123456789 | Quote: | | href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List | 0 | Quote: | | href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List | 1 | Quote: | | href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List | 2 | Quote: | | href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List | 3 | Quote: | | href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List | 4
_________________ Floyd Wilkes |
