Jhp 520 PTT cable
dan42101(at)yahoo.com
PostPosted: Sat Mar 27, 2010 6:49 am    Post subject: Jhp 520 PTT cable Reply with quote
Does anyone know where I could get a remote PTT switch that works properly for this unit? I read in the archives that it does not take a PTT that grounds to talk.
I am uncertain about the note to "connect the PTT line to one of the other lines".
Thanks.
- DjD
PostPosted: Sat Mar 27, 2010 2:48 pm    Post subject: Jhp 520 PTT cable Reply with quote
other lines".
Where do you see this 'note'?
PostPosted: Sat Mar 27, 2010 3:17 pm    Post subject: Jhp 520 PTT cable Reply with quote
I get hits on "JRC". The message is below...
Thanks.
- DjD
Match: #16 Message: #19136 Date: Jul 28, 2004 From: Steve Maher <lilabner_45(at)yahoo.com> Subject: Re: handheld and intercom
Some handhelds do, some don't.
I had a JRC JHP-520 handheld navcomm, and found that the owner's manual
stated in big black letters, DO NOT GROUND THE PTT LINE TO TRANSMIT. In
that radio, it says you have to connect the PTT line to another line on
the plug, to transmit.
I now have a Vertex (formerly Yaesu) VXA-210 handheld navcomm. Its
manual doesn't say much about what to do with the PTT line, so I called
their service department and talked to one of their techs who seemed
quite knowledgeable. He checked the schematics and told me that
grounding the PTT line to transmit, is definitely the correct way to
go.
Whatever radio you're contemplating, if I were you I'd call the company
first and ask them about the PTT line. Personally I like the ground-it
types, since they conform to what most intercoms do.
Steve Maher
San Diego, CA
--- On Sat, 3/27/10, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
From: Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com>
Subject: Re: Jhp 520 PTT cable
Date: Saturday, March 27, 2010, 5:46 PM
--> AeroElectric-List message posted by: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com (nuckolls.bob(at)aeroelectric.com)>
rampil
PostPosted: Sun Mar 28, 2010 3:05 pm    Post subject: Re: Jhp 520 PTT cable Reply with quote
As it happens, Japan Radio Corp sold this product to Rexon Tech.
It is now known as the RHP-520. You can find the users manual on the
web and download it as I did.
In a brief scan, I saw nothing about the PTT jack or any detail about
headset operation. The headset adapter cable I have does not split out
a ptt jack
The RHP nee RHP is a great little radio IMHO!
Ira N224XS
PostPosted: Thu Apr 01, 2010 11:15 am    Post subject: Jhp 520 PTT cable Reply with quote
I borrowed a David Clark c 10-15 PTT switch. I moved the wires in the one jack I could get open every way I could think of. No help.
I wonder if I could cut the wire to the internal mike on the radio, and just use it with the headset only and no remote PTT.
- DjD
Date: Sunday, March 28, 2010, 6:05 PM
--> AeroElectric-List message posted by: "rampil" <ira.rampil(at)gmail.com (ira.rampil(at)gmail.com)>
a ptt jack
Ira N224XS
http://forums.matronics.com/viewtopic.php?p=292139#292139
http://www.matronics.com/Navig========================ht
PostPosted: Thu Apr 01, 2010 1:05 pm    Post subject: Jhp 520 PTT cable Reply with quote
I'm not sure the JHP-500 series radios will accept
external PTT. My cord only carries mic audio from
the headset to the radio. I use the hand-held's
built in PTT to transmit. If one can track down
a service manual with a schematic of the radio,
we could easily figure out what it takes.
rampil
PostPosted: Fri Apr 02, 2010 1:44 pm    Post subject: Re: Jhp 520 PTT cable Reply with quote
Hi Bob,
If you do run across a copy of the JHP/RHP service manual, I'd
be interested in having a copy even though I am not much of an SMT
jock.
I am not sure what Dan (DjD) is trying to do with cutting an
internal mike wire, but the internal mike is out of circuit when external
mike is plugged in as is standard. Just the PTT function stays in the box
Ira
Ira N224XS
PostPosted: Mon Apr 05, 2010 3:31 pm    Post subject: Jhp 520 PTT cable Reply with quote
Below is the reply from the good folks at Sam's photofacts... I also sent an email to Rexon. I won't hold my breath for that reply.
I guess this radio will be on ebay shortly.
Thanks to all.
- DjD
Sorry, we cannot locate anything on this.
Jeff Morris
SAMS Technical Publishing, LLC
9850 East 30th Street
Indianapolis, IN 46229
Phone: 1-800-428-7267
Fax: 1-800-552-3910
Email: customercare1(at)samswebsite.com (customercare1(at)samswebsite.com)
--- On Thu, 4/1/10, Robert L. Nuckolls, III <nuckolls.bob(at)aeroelectric.com> wrote:
Subject: Re: Re: Jhp 520 PTT cable
Date: Thursday, April 1, 2010, 4:05 PM
we could easily figure out what it ========================http://www.matroni/forums.matronics.com/" ; -Matt Dralle, List Admin==========
Turbo_Boss
PostPosted: Fri Apr 29, 2011 5:34 pm    Post subject: Re: Jhp 520 PTT cable Reply with quote
I have a JRC 520 and the external PTT work when you ground it.
Here is the HEADSET and PTT schematics
 Filesize:  38.05 KB
 Viewed:  16625 Time(s)
