Posted: Tue Jan 10, 2006 7:03 pm Post subject: battery |
Who’s used the Odyssey PC680 (or two of them) and how did you have to modify your battery shelf?
Rob
#392 tailcone
GenGrumpy(at)aol.com Guest
Posted: Tue Jan 10, 2006 7:23 pm Post subject: battery |
I'm using 2 of these and using Van's battery boxes mounted side by side (with a little mod) aft of the baggage compartment.
In a message dated 1/10/2006 9:05:14 PM Central Standard Time, armywrights(at)adelphia.net writes:
Rob
#392 tailcone
bob.condrey(at)baesystems Guest
Posted: Wed Jan 11, 2006 7:52 am Post subject: battery |
I went with a pair of PC-680s. Tray was modified to increase width a small amount (around an inch). Contactors (one for each battery) are on a bracket that attaches to the standard contactor location. I’ve attached one picture – if you need/want more I can send them offline if you’d like. I’m also aware of another builder that has a pair of PC-680s but they’re rotated 90 degrees from “normal” and the contactors are one on each side.
Bob #40105
97.01 KB |
1082 Time(s) |
Tdawson(at)avidyne.com Guest
Posted: Wed Jan 11, 2006 8:41 am Post subject: battery |
Well, if we're sharing battery pictures, here's our main battery: 12v + 12v = 24v.
Also in view is a real man's contactor . . .
TDT
40025
170.69 KB |
1098 Time(s) |
Posted: Wed Jan 11, 2006 8:47 am Post subject: battery |
Tim - I guess you win the “manly contactor” contest…
jjessen(at)rcn.com Guest
Posted: Wed Jan 11, 2006 9:17 am Post subject: battery |
Ok. I'll look this up in the archives and on Aerolectric later today, but real quick, why 24 volts other than for lighter wiring and that you may have used avionics out of a Cessna?
John Jessen
~328 (still bouncing back and forth between elevators and cone)
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Tim Dawson-Townsend
Sent: Wednesday, January 11, 2006 8:39 AM
To: rv10-list(at)matronics.com; rv10-list(at)matronics.com
Subject: RE: RV10-List: battery
rvbuilder(at)sausen.net Guest
Posted: Wed Jan 11, 2006 9:23 am Post subject: battery |
Geez, expecting to upgrade to a fusion reactor in the future? Hehe
Sent: Wednesday, January 11, 2006 10:39 AM
Subject: RE: battery
deruiteraircraftservices( Guest
Posted: Wed Jan 11, 2006 10:18 am Post subject: battery |
that's the way to go........nuke reactor in the back with a matching bit of electrictrickery in the front! No worries about rising avgas prices and a set of fuel rods is bound to last a lifetime...........you'll be radiant looking after every flight and there's no problem finding your RV in the dark!
[quote] -
