AW: Full Panel
uvtreith(at)t-online.de
PostPosted: Wed Mar 24, 2010 2:49 am    Post subject: AW: Full Panel Reply with quote
Hi Tony,
Europa Aircraft is selling some different pre-cut panels, also for EFIS
installation.
Please see the attached drawings.
All the Best from Germany
Bruno Reith
-----Ursprüngliche Nachricht-----
Von: owner-europa-list-server(at)matronics.com
[mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Tony Renshaw
Gesendet: Dienstag, 23. März 2010 23:53
An: europa-list(at)matronics.com
Betreff: Full Panel
<tonyrenshaw268(at)optusnet.com.au>
Gidday,
I am all over the shop, to coin a phrase, but in the mean time I am trying
to gather thoughts on a panel. Now I have seen Bob Borger's full width panel
on EuropaOwners, and others, but am unsure if these have all been
individually made, or whether Europa now sells them. There is a Tri Gear
Instrument which I reckon still has the parcel shelf, and then there is a
Blank Panel Full Depth Avionics Panel. I reckon neither of these are
probably full "width" panels, so what I really want is some pictures
somewhere of how guys have done this mod, or in fact whether someone sells a
completed full "width" panel?
Reg
Tony Renshaw
Sydney Aussie
 Filesize:  235.67 KB
 Viewed:  2018 Time(s)
 Filesize:  211.97 KB
 Filesize:  237.75 KB
 Filesize:  205.84 KB
 Filesize:  124.45 KB
XS_Panel.doc
 Filename:  XS_Panel.doc
 Filesize:  460 KB
 Downloaded:  277 Time(s)
rampil
PostPosted: Wed Mar 24, 2010 4:18 am    Post subject: Re: AW: Full Panel Reply with quote
The full width panels, like the one I use, were made for
FlightCrafters in Zephyrhills, FL. Try calling Russ Lepre
to see if he can still have them made, or you can try one
your self. It basically just requires a big foam plug for the
laminating over on the right side.
Ira N224XS
