rmacpunk(at)netzero.net Guest
Posted: Mon Mar 22, 2010 10:54 am Post subject: VDO fuel gauges (again) |
Is anyone using the Zenith supplied sender and buying VDO gauge 301-020? Can you get your gauges to read from empty to full? I can't get past half way between 3/4 and full. Adjustment screw only regulates lower end. Sender ckecks OK.
jfowler120(at)verizon.net Guest
Posted: Mon Mar 22, 2010 11:33 am Post subject: VDO fuel gauges (again) |
We've never had the gauges work properly. Since everything is all apart it is on my look-at list but not sure what I can do. Any ideas? This appears to be a common problem.
Karl
Sent: Monday, March 22, 2010 9:46 AM
To: zenith601-list(at)matronics.com (zenith601-list(at)matronics.com)
Subject: VDO fuel gauges (again)
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
chuck960
Posted: Mon Mar 22, 2010 1:01 pm Post subject: Re: VDO fuel gauges (again) |
I have the same problem with this sender/gauge combo. Around 7/8 is as far as the needle will go. I bench tested as well. I have decided to scrap the gauges and use the Dynon glass panel which can be calabrated.
Chuck
CH650
