Scotsman
Joined: 27 Aug 2007 Posts: 89 Location: Johannesburg, South Africa
Posted: Sat Mar 20, 2010 4:16 am Post subject: Cabin fittings |
Hi Listers,
What is your preferred way of attached whatever material (leather etc) you have choose to, for example, the sides of the cabin? And for those who have been flying with it for a while any comments on how that lasted against the usual amount of abuse that the cabin receives?
Any photos would be appreciated.
Cheers
James
_________________ Cell +27 83 675 0815 |
psm(at)att.net Guest
Posted: Sat Mar 20, 2010 4:35 am Post subject: Cabin fittings |
Hi James,
My plan is to leave bare metal on cabin sides and similar areas. Any extra
materials in those places serves two purposes - changing the natural
appearance and reducing noise. These extra materials also add weight which
is very costly in terms of utility of our craft which are severely limited
in maximum gross weight.
I am happy to live with bare metal apparence, and I have learned that the
new ANL headsets do an incredibly good job at eliminating noise of all
sorts. I'm quite sure the weight penalty for use of a fancy headset is
trivial compared to a bunch of upholstery on the cabin walls.
Paul
XL - installing upgrade kit
jaybannist(at)cs.com Guest
Posted: Sat Mar 20, 2010 6:19 am Post subject: Cabin fittings |
James,
I made upholstery panels with an aircraft grade plastic corrugated board covered with a thin aircraft grade foam sheet and fabric, all from Airtex (Airtexinteriors.com). I added vertical strips of L angle to the fuselage upright angles and placed strips of Velcro on those angles and horizontal strips of Velcro on the panels. It was very easy to install and they are easily removable for access to "stuff" that is behind them. On the forward panels, I placed the Velcro directly on the inside of the fuselage skin and filled in between the angles with fabric panels. Questions?
Jay Bannister
189.47 KB |
9019 Time(s) |
1.56 MB |
9019 Time(s) |
205.93 KB |
9019 Time(s) |
floyd wilkes
Joined: 11 Jun 2007 Posts: 39 Location: spring branch, tx
Posted: Sat Mar 20, 2010 8:18 am Post subject: Cabin fittings |
James,
I cut several pieces of 1X2 lumber about 2 inches long and glued them to the
skins. Then a small wood screw thru the panels into the wood.
Floyd wilkes
_________________ Floyd Wilkes |
Z601c(at)anemicaardvark.c Guest
Posted: Sat Mar 20, 2010 8:24 am Post subject: Cabin fittings |
On Saturday 20 March 2010 08:57:23 you wrote:
| Quote: | James,
For those who never plan to remove the panels (although I don't necessarily
recommend that), Airtex also sells an adhesive that can be used to bond the
panels directly to the aircraft. That's pretty much the standard way it's done
for certificated aircraft, when using their panels.
I've used it a number of times, with good results. I'm a little surprised
Airtex hasn't offered Zenith panels.
Jim B. Belcher
BS,MS Physics
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
Semi-proficient Househusband
naumuk(at)windstream.net Guest
Posted: Sat Mar 20, 2010 3:09 pm Post subject: Cabin fittings |
James-
I used V+S 1081 Spray Trim Adhesive available from ACS to attach sound
insulation. I don't think it looks too bad (Picture attached) and you kill
two birds with one stone.
bill
84.81 KB |
9005 Time(s) |
jeffrey_davidson(at)earth Guest
Posted: Sat Mar 20, 2010 4:34 pm Post subject: Cabin fittings |
Here is another idea. I used some extra 6061 to make the side panels. Then
I glued Naugahyde to the aluminum. The panels are held on with Velcro for
easy removal and tucked up under the upper longeron cap. Picture attached.
Jeff Davidson
180.15 KB |
9004 Time(s) |
gregw(at)aeromarket.com.a Guest
Posted: Sun Mar 21, 2010 3:34 am Post subject: Cabin fittings |
I wanted a fabric so I got hold of an old corrugated plastic real estate
sign and cut peices to fit. I then used spray on contact adhesive to
attach the material to the plastic with 1 inch wrapping around to the back
surface on all sides.
The upholstered cards can then be either glued in place with contact
adhesive or attached to velcro strips stuck on to the inside panels of the
fuselage.
It gives a very professional finsih with little cost and minimal weight.
| Quote: | Here is another idea. I used some extra 6061 to make the side panels.
Then
attached.
Jeff Davidson
carlossa52(at)gmail.com Guest
Posted: Sun Mar 21, 2010 5:35 am Post subject: Cabin fittings |
I thought about using corrugated plastic too, but I would prefer something not flammable.
I believe I have seen pink rigid board of something that looks like fiberglass, about 1 - 1.5 cm thick somewhere. (Inside a car or in the aviation department of Home Depot?)
Did anyone use or consider this?
Carlos
CH601-HD, plans
On 21 March 2010 07:33, Greg Wilson <gregw(at)aeromarket.com.au (gregw(at)aeromarket.com.au)> wrote:
[quote]--> Zenith601-List message posted by: "Greg Wilson" <gregw(at)aeromarket.com.au (gregw(at)aeromarket.com.au)>
fuselage.
Posted: Sun Mar 21, 2010 5:53 am Post subject: Cabin fittings |
On Sunday 21 March 2010 08:34:37 you wrote:
| Quote: | I thought about using corrugated plastic too, but I would prefer something
not flammable.
I suspect a lot of the corrugated plastic burns entirely too well. The stuff
one can get from Airtex meets the flame retardant requirements of the FARs,
although as an experimental, we obviously don't need to meet those unless we
care about burning up or something.
Another consideration is that the adhesive needs to be something that is non-
corrosive, and doesn't trap moisture. I'm sure there are many adhesives that
meet this requirement, but the one I know of for sure is the stuff Airtex
peddles.
No, I don't own stock in Airtex. Their stuff just has a good track record, and
its a known entity.
Jim B. Belcher
BS,MS Physics
A&P/IA
rsteele(at)rjsit.com Guest
Posted: Sun Mar 21, 2010 5:55 am Post subject: Cabin fittings |
I'm a long way from worrying about it, but anything going into my plane, fabric, soundproofing, etc. will have a sample exposed to a propane torch to test for flammability and, probably more important, smoke production. It's my understanding that's roughly how fabrics and foams are tested to be certified aircraft grade.
Ron
On Mar 21, 2010, at 9:34 AM, Carlos Sa wrote:
[quote]I thought about using corrugated plastic too, but I would prefer something not flammable.
Carlos
CH601-HD, plans
| Quote: | --> Zenith601-List message posted by: "Greg Wilson" <gregw(at)aeromarket.com.au (gregw(at)aeromarket.com.au)>
fuselage.
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
| [b]
Scotsman
Posted: Mon Mar 22, 2010 9:59 am Post subject: Re: Cabin fittings |
Thanks for the all the responses. It is nice to see the list back to doing what it is best at.
In terms of the weight penalty I accept this but some of the proposed solutions do not appear to have a massive weight penalty. My personal preference is to do the interior up nicely and use the Jabi 3300 which will contribute a few extra hp to pull the interior along.
I think that a half decent interior will also add extra value to the aircraft if eventually I decide to ever sell it.
I was concerned about the effect of some types of adhesive on the side skins etc so I think I will go with the more expensive safe bet of the products that are "certified". I don't want to have an issue years down the line.
If anyone else has any different forms of installation or suggestions please add your bit and a photo if you can.
Cheers
James
