fklein(at)orcasonline.com Guest
Posted: Sat Mar 13, 2010 8:49 am Post subject: Question about Ground Adj. Props |
FWIW, Sensenich does offer a 3 blade composite ground adjustable prop
for the 9XX designated 3BOR5R68C, weight 10 lbs., min. diameter of 64".
Alas, the shanks of the 2 blade prop they make for the Jab 3300 relies
on a different hub design and do not fit in the 3 blade-hub.
Fred
 Download |
| Filename: |
show_brochure_english.pdf |
236.03 KB |
| Downloaded: |
309 Time(s) |
Posted: Sat Mar 13, 2010 9:05 am Post subject: Question about Ground Adj. props |
64"...max. rpm of 2700.
I have a pdf which apparently won't post to the list...happy to send
it to anyone who'd like to see it...the Powersweep 3 blade is indeed a
thing of beauty.
Fred
Posted: Sat Mar 13, 2010 9:37 am Post subject: Question about Ground Adj. Props |
Fred
that does look beautiful! Is the rear face of the section slightly concave? That would really convince me.
Graham
Sent: Saturday, 13 March, 2010 16:04:42
Subject: Question about Ground Adj. Props
FWIW, Sensenich does offer a 3 blade composite ground adjustable prop for the 9XX designated 3BOR5R68C, weight 10 lbs., min. diameter of 64".
Alas, the shanks of the 2 blade prop they make for the Jab 3300 relies on a different hub design and do not fit in the 3 blade-hub.
Fred
