Louie928
Joined: 15 Nov 2009 Posts: 32 Location: Mosier, OR USA
Posted: Wed Mar 10, 2010 4:34 pm Post subject: Re: Aileron balance weights |
Tire shops have used wheel weights that can be melted. It isn't pure lead and has a few % of antimony in it to increase hardness.
_________________ Louis W. Ott
601XL-B Corvair |
John Bolding
Posted: Wed Mar 10, 2010 4:49 pm Post subject: Aileron balance weights |
Another spot is a plumbing supply outlet
LO&SLO John
601RX
Posted: Wed Mar 10, 2010 6:05 pm Post subject: Re: Aileron balance weights |
I thought that lead could cause corrosion on aluminum?
________
MFLB
Louie928
Posted: Wed Mar 10, 2010 9:08 pm Post subject: Re: Aileron balance weights |
| 601RX wrote: | | I thought that lead could cause corrosion on aluminum? |
I don't think lead and aluminum together directly corrode, but contaminants and water could get between the lead and bare aluminum and cause a problem.
601XL-B Corvair |
dalemed
Posted: Thu Mar 11, 2010 6:19 am Post subject: Re: Aileron balance weights |
What's used to plug the tubing before pouring the molten lead in?
_________________ Dale
Zenith Zodiac CH650 |
pbaker4(at)windstream.net Guest
Posted: Fri Mar 12, 2010 7:34 am Post subject: Aileron balance weights |
my A&P used a mold made from aluminum. he pluged the end of the mold with clay.after it cooled , he used a file to
make it fit in the tube. He then drilled through the holes in
the tubing and added the weights.. I only gained 21lbs with
the upgrade. the weight a balance was in the center of gravity. I made two flights tuesday and am happy with the results. before ,in a turn, i could see the outer panel of the wing flexing a little bit, but not now. very solid..I feel much
more confident in the airplane now. After 60 years of flying,
you need to feel confident,and now I do.
paul baker 601 "T" model.. ha ha
dalemed
Posted: Fri Mar 12, 2010 10:22 am Post subject: Re: Aileron balance weights |
| pbaker4(at)windstream.net wrote: | my A&P used a mold made from aluminum. he pluged the end of the mold with clay.after it cooled , he used a file to
paul baker 601 "T" model.. ha ha |
Thanks. That makes sense. I was thinking you poured the molten lead into the balance tube.
Dale
Building CH650B
ggower_99(at)yahoo.com Guest
Posted: Fri Mar 12, 2010 5:41 pm Post subject: Aileron balance weights |
Yes, probably your great grand children will need to repaint the part... If gasoline is still available to fly your airplane
Gary Gower.
n4546v(at)mindspring.com Guest
Posted: Fri Mar 12, 2010 5:59 pm Post subject: Aileron balance weights |
mhubel
Posted: Thu Mar 25, 2010 4:52 am Post subject: Aileron balance weights |
Paul
Do you have any idea how long the led weight was? My calculation
shows that it would need to be about 10 inches long to fit inside the
tubes that Zenith supplied. This puts the CG of the weight closer to the
hinge and thus increases the total amount of weight required slightly.
Not a big deal but if you could find out how about long the led slug was
it would help in doing the same thing again.
_________________ Mark Hubelbank
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
Sensenich ground adj prop.
240 hr TAF
Pictures at photo.hubbles.com |
Posted: Fri Mar 26, 2010 4:30 am Post subject: Aileron balance weights |
Mark
the lead in the tube only goes in about 6'.We added a few weights then on the out side. The hole in the rear spar was enlarged just enough to clear the weights on the outside.This is at the end of the wing and does not carry much weight so it is not weakened .In the future if I need to
service the balance or remove the alerion"excuse the spelling" .
paul baker -601 flying again and enjoying every minute
mhubel
Posted: Sat Mar 27, 2010 6:02 pm Post subject: Aileron balance weights |
Paul,
Given your experience, I think I may increase the length of the led section a little and I may avoid the need for external side weights.
On 3/26/2010 8:29 AM, paul baker wrote: [quote] Mark
href="http://www.matronics.com/Navigator?Zenith601-List">http://www.matronics.com/Navigator?Zenith601-List
Mark Hubelbank
NorthEast Monitoring
2 Clock Tower Place
Suite 555
Maynard, MA, 01754 - USA
mhubel(at)nemon.com (mhubel(at)nemon.com)
978-443-3955[b]
N708HU
CH601XL
Jabiru 3300
Rotec TBI 40-3 carb
240 hr TAF
