Solid State Contactors -- SuperSwitch?
thorn(at)starflight.aero
PostPosted: Sat Mar 06, 2010 1:13 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
Hello,
Has anyone had experience with the solid state contactors from Lamar Technologies they call a SuperSwitch? See this Aircraft Spruce link for info:
http://www.aircraftspruce.com/catalog/elpages/superSwitch.php
I know they’re expensive – but, we’re already in that category of contactor with the need for 28V high continuous current contactors (100 A alternator, all electric A/C). We already have very nice Blue Sea high capacity contactors that are hermetically sealed (~$150 each). They weigh about a pound each, though, and the significant weight savings with these solid state contactors looks good.
I’d appreciate comments and advice.
Valin Thorn
Legacy
Houston, TX USA
Exerpt of info on web link:
Features
  • Up to 66% lighter weight
  • 99% more reliable
  • 5 to 44 volt operating range
  • Replaces all mechanical contactors
  • Solid state technology
  • No moving parts
  • Up to 600 amps momentary operation
  • Up to 100 amps continuous
  • Negative or positive turn on
Specifications
  • Input: Input control current 5 to 44 volts
  • Output: Operating DC voltage range 0 to 44 volts
  • Maximum continuous current 100 amps
  • Maximum surge current (IDM) - .1mS: 1200
  • Ambient operating temperature range: -40 C to 85 C
  • Weight: Uni-directional .3 lbs
  • Bi-directional .5 lbs
  • Encapsulation: Potting or conformal coating
 Filesize:  28.06 KB
 Viewed:  14125 Time(s)
PostPosted: Sat Mar 06, 2010 3:40 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
At 03:04 PM 3/6/2010, you wrote:
Hello,
This same question came up a few years ago
http://www.matronics.com/forums/viewtopic.php?t=26571
I'd not heard of them at that time. I did write to Lamar
asking for an engineering data package that would help
me evaluate the potential for incorporation onto TC
aircraft. As I recall, I got an answer from somebody
in sales who promised to forward my request to the
right individual.
Never heard back and I guess it slipped my mind.
I just did an advanced search on "superswitch"
limited to http://www.lamartech.com/ and the
search engines did not return a hit. Did anohter
search on "07-01283" and "lamar". Got hits on
Aircraft Spruce and Skyshop in Australia.
Searched the whole constellation of matronics forums
and got two hits . . . THIS thread and the one I
cited above from some years ago. So I guess
the short answer is, haven't got a clue as to
how good the product is (although Lamar is
usually a low risk choice for other things).
It doesn't appear that they've made much of
a splash in the marketplace.
Bob . . . [quote][b]
PostPosted: Sun Mar 07, 2010 5:34 am    Post subject: Re: Solid State Contactors -- SuperSwitch? Reply with quote
Solid state contactors might have a small leakage current when they are off.
Joe
Joe Gores
jonlaury
PostPosted: Sun Mar 07, 2010 2:47 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
Haven't used these, but they look identical to Teledyne's. $$ to donuts that the manufacturer is the same.
http://www.futurlec.com/RelSS.shtml
mrspudandcompany(at)veriz
PostPosted: Sun Mar 07, 2010 3:51 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
[quote] If you are planning on using one of these devices in your airplane, make sure you purchase the ones for a DC load. Some of the ones for AC load, require a zero crossing to switch and will not work for DC. Roger [b]
PostPosted: Sun Mar 07, 2010 6:11 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
If you are
DC.[/b]
The device being discussed is offered by an aviation
equipment specialty house as a replacement for contactors
(where bi-directional current flow is needed) and another
version (relay) where uni-directional current flow will
suffice. They are expected to function in a DC power system.
jbr79r(at)yahoo.com
PostPosted: Mon Mar 08, 2010 7:49 am    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
good morning Bob
I was hoping you would offer some comment on these devises. Pros / cons / etc
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Sun, March 7, 2010 6:02:40 PM
Subject: RE: Solid State Contactors -- SuperSwitch?
If you areplanning on using one of these devices in your airplane, make sure youpurchase the ones for a DC load. Some of the ones for AC load,require a zero crossing to switch and will not work forDC.
Bob . . . [quote]
PostPosted: Mon Mar 08, 2010 9:28 am    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
At 09:41 AM 3/8/2010, you wrote:
good morning Bob
I've not seen detailed engineering data on any such
products to date. Certainly, the technology exists
to fabricate solid stage contactors. I think the
race car hobby/industry has been flirting with them
for some years.
My personal knowledge as to the performance of
products currently offered for sale is zero. I
would be interested seeing the detail data sheets
and/or doing lab tests on a device to look at
things like on-resistance, off leakage, transient
immunities, conducted noise, performance at temperature
extremes.
We KNOW that hard-metal contactors have VERY good
OFF and ON switching characteristics. Further, they're
simple, rugged and offer good value (service life and
performance vs. acquisition costs).
So the short answer is that pending further enlightenment
on my part, I'm not able to offer any insight.
PostPosted: Mon Mar 08, 2010 4:03 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
If you are
make sure you
load,
DC.
system.
One of the devices referenced previously on
this website http://www.futurlec.com/RelSS.shtml pictured an AC device
JGX-1505FB. I seem to recall way back in a previous life that some of these
similar devices required that the output go to zero before it would shut
off. I may be wrong, since it has been many moons since I have worked with
this device. This is why I mentioned above to be careful when selecting
your solid state relay.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  4.38 KB
 Downloaded:  749 Time(s)
PostPosted: Wed Mar 10, 2010 7:50 pm    Post subject: Solid State Contactors -- SuperSwitch? Reply with quote
Thank you everyone for the feedback.
Bob, I talked with Lamar Technologies’ Jim Errington, their Sales & Marketing Manager. I let him know that you are interested in examining and testing their solid state contactor relays. He’s also very interested in providing you some of their contactors for testing and to get familiar with them. I gave him the phone number on the AeroElectric home page (620-886-3403) for you so you may have already heard from him. If you have not, Jim’s contact info is jime(at)lamartech.com (jime(at)lamartech.com), phone: 360-651-6666.
Their technical support guy, Alan Saldecki, provided a couple pdf files with a bit more information on their SuperSwitches – I’ve attached only one of them to keep this file size small. One thing that’s different in their spec file vs. the Aircraft Spruce page is that it’s rated for 80 A continuous rather than 100A and that various with ambient temperature.
They have a bunch of the SuperSwitches flying in a Cessna Corvalis for certification testing, or something like that. They also report they have a number of experimentals flying with them without problems.
If you are still interested in looking into them, I’ll wait to see what you think when you open one up and test it before deciding to use them in our power system. Note that with my 28V, high current demand system (electric A/C, live in Houston) I’m already stuck with contactor relays in their price range – so, cost isn’t a factor so much as reliability and weight.
Valin Thorn
Lancair Legacy project
Houston, TX USA
From: Valin & Allyson Thorn [mailto:thorn(at)starflight.aero]
Sent: Saturday, March 06, 2010 3:05 PM
To: 'aeroelectric-list(at)matronics.com'
Subject: Solid State Contactors -- SuperSwitch?
Hello,
Valin Thorn
Legacy
Houston, TX USA
 Filesize:  28.06 KB
 Viewed:  14030 Time(s)
SS2-EXP.C.PDF
 Filename:  SS2-EXP.C.PDF
 Filesize:  291.48 KB
 Downloaded:  773 Time(s)
