sealing trailing edge
JHearnsberger
PostPosted: Sat Mar 06, 2010 2:46 pm    Post subject: sealing trailing edge Reply with quote
Can I use any of these products or do I need to order something special? I am ready to seal up the rudder.
permatex aviation form-a-gasket
 Filesize:  514.74 KB
 Viewed:  11014 Time(s)
permatex gasket sealant
 Filesize:  647.4 KB
versa hem prime seal
 Filesize:  689.04 KB
pitts_pilot(at)bellsouth.
PostPosted: Sat Mar 06, 2010 2:56 pm    Post subject: sealing trailing edge Reply with quote
The pictures are of Permetex gasket products, used in engine assembly.
They're not made to seal up the rudder.
What you need is called 'proseal' and is found here:
http://www.vansaircraft.com/cgi-bin/catalog.cgi?ident=1267916071-182-15&browse=misc&product=proseal.
Same stuff used for the fuel tanks.
Linn
http://forums.matronics.com/viewtopic.php?p=289401#289401
http://forums.matronics.com//files/img_0283_281.jpg
http://forums.matronics.com//files/img_0282_493.jpg
http://forums.matronics.com//files/img_0281_189.jpg
davidsoutpost(at)comcast.
PostPosted: Sat Mar 06, 2010 3:03 pm    Post subject: sealing trailing edge Reply with quote
I would recommend that you buy a 3 oz kit of the Flame Master tank sealant from Vans for this. It is what they recommend and it will give you some experience using it before you get to your tanks. The sealant will hold the edge of the rudder straight as an arrow and I don't know if what you are looking at would work as well. It is also used building the wings on the trailing edges of the aileron's and flaps.
David Clifford
RV-10 In Progress
Empennage Done
Engine Overhauled & Pickled
Closing up The Wings
JHearnsberger
PostPosted: Sat Mar 06, 2010 3:32 pm    Post subject: Re: sealing trailing edge Reply with quote
OK, thanks. I was hoping I would not have to wait before finishing up the rudder. I wanted to take advantage of this beautiful Saturday while I can.
Kelly McMullen
PostPosted: Sat Mar 06, 2010 3:44 pm    Post subject: sealing trailing edge Reply with quote
Get 2 or 3 of the 1 oz kits. One for rudder, one for trim tabs and one
for horizontal stab, if I recall correctly. You don't need more than 1
oz at a time until you get to fuel tanks.
On Sat, Mar 6, 2010 at 4:03 PM, <davidsoutpost(at)comcast.net> wrote:
[quote] I would recommend that you buy a 3 oz kit of the Flame Master tank sealant
David Clifford
RV-10 In Progress
Empennage Done
Kelly McMullen
A&P/IA, EAA Tech Counselor
KCHD
Ron B.
PostPosted: Sat Mar 06, 2010 3:58 pm    Post subject: Re: sealing trailing edge Reply with quote
Get use to waiting for product, it's part of the build process. You will never know what you need until you need it. But it's all fun anyway>
Ron
Kelly McMullen
PostPosted: Sat Mar 06, 2010 4:56 pm    Post subject: sealing trailing edge Reply with quote
You can probably get a pt of CS3204 B2 from Sacramento Sky Ranch
faster than from Vans, and less money.
http://tinyurl.com/yas9een
Ron
http://forums.matronics.com/viewtopic.php?p=289411#289411
Kelly McMullen
KCHD
Phil.Perry(at)netapp.com
PostPosted: Sat Mar 06, 2010 6:54 pm    Post subject: sealing trailing edge Reply with quote
I didn't use anything to hold the rudder TE together while riveting. Instead, I clecoed every other hole down to a piece of heavy angle iron (to keep it perfectly straight) and back riveted between the clecos.  This formed a straight TE, then I could back rivet the holes that originally held clecos.
Checking the TE with a straight edge shows less than a 1/16" deviation from perfectly straight. I'll bet its closer to 1/32".
Phil
Kelly McMullen
PostPosted: Sat Mar 06, 2010 7:16 pm    Post subject: sealing trailing edge Reply with quote
But what did you use for primer? Wink)
On Sat, Mar 6, 2010 at 7:49 PM, Perry, Phil <Phil.Perry(at)netapp.com> wrote:
clecos.
Phil
Kelly McMullen
KCHD
rv10builder(at)verizon.ne
PostPosted: Sat Mar 06, 2010 7:25 pm    Post subject: sealing trailing edge Reply with quote
go to home depot or lowes and get PL-2000 works for this. It was really easy
to use using a caulk gun and cost like $3.96. no need to wait for something
like this.
AS far as the comments about the flamemaster (proseal) talk sealant, the
stuff smells and is really sticky, use a ziplock or something else to
squeeze it, I didn't< I used Q-tips and less than a can to do all the tanks.
No leaks from using only what is needed. Practice is good advice but I might
suggest doing it before doing the tanks not way before and along the way,
although it can't hurt. Oh and if it gets on any of your clothes don't waste
time trying to clean up with MEK again really smelly and toxic to the skin.
Another reason to avoid using tank sealant for anything but the tanks.
Best of success with the trailing edge- use a L bracket clecoed to keep it
straight as an arrow. Check out the archives, everything I mentioned for
doing the trainling edges was covered by Les Kearney a couple of years ago.
From: "JHearnsberger" <jakehearnsberger(at)gmail.com>
Sent: Saturday, March 06, 2010 3:32 PM
Subject: Re: sealing trailing edge
can.
http://forums.matronics.com/viewtopic.php?p=289406#289406
40950(at)rv10.net
PostPosted: Sat Mar 06, 2010 7:49 pm    Post subject: sealing trailing edge Reply with quote
Same as Phil, I did not use anything to hold the rudder TE. Rolled the edges with Cleaveland edge forming tool before and back riveted on flat iron. Came out straight.
Phil
Lew Gallagher
PostPosted: Sat Mar 06, 2010 8:06 pm    Post subject: Re: sealing trailing edge Reply with quote
Hey Jake,
A search for "PL-2000" turned up nothing ... probably meant PL-200 ?
Party on.
Later, - Lew
non-pilot
crazy about building
NOW OFICIALLY BUILDER #40549
Fly off completed !
PostPosted: Sun Mar 07, 2010 10:49 am    Post subject: sealing trailing edge Reply with quote
you have me to blame for that. Yes, I meant PL200 although I used a
polyurethane adhesive
http://www.stickwithpl.com/Products.aspx?ID=fef65cc9-47bf-4802-aaa9-a343f2ef9458
and it worked great for all sorts of bonding.
Pascal
Sent: Saturday, March 06, 2010 8:06 PM
Hey Jake,
Party on.
Later, - Lew
non-pilot
Avionics in, engine started!
http://forums.matronics.com/viewtopic.php?p=289453#289453
