Hydraulic brake hose
mau11(at)free.fr
PostPosted: Sat Mar 06, 2010 9:00 am    Post subject: Hydraulic brake hose Reply with quote
Hi all,
I see this picture on web site but I don't remember where!
I am interested to install this hose and banjo on my brake, does anyone know where it is possible to buy this assembly?
mau11
06-03-2010
 Filesize:  85.45 KB
 Viewed:  8613 Time(s)
mikenjulie.parkin(at)btin
PostPosted: Sat Mar 06, 2010 10:01 am    Post subject: Hydraulic brake hose Reply with quote
Hi,
I think that the photograph is one I took of my monowheel brake installation. The hose actually came from France but is readily available from a good hydraulic parts merchant in the UK, as is the banjo coupling.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
Sent: 06 March 2010 16:55
To: europa-list
Subject: Hydraulic brake hose
Hi all,
mau11
06-03-2010
Checked by AVG - www.avg.com
07:39:00
mau11(at)free.fr
PostPosted: Sat Mar 06, 2010 10:23 am    Post subject: Hydraulic brake hose Reply with quote
Hi Mike thanks for this information I live in France do you remember in what shop you purchase it?
Michel AUVRAY
Builder 145
06-03-2010
mau11
De : Mike Parkin
Date/heure : 06-03-2010 19:05:11
A : europa-list(at)matronics.com
Cc :
Sujet : RE: Hydraulic brake hose
Hi,
To: europa-list
Hi all,
mau11
06-03-2010
07:39:00
rlborger(at)mac.com
PostPosted: Sat Mar 06, 2010 10:26 am    Post subject: Hydraulic brake hose Reply with quote
Mike,
You wouldn't happen to have the specs for that fitting would you?
I'm working on my brakes and that fitting would be perfect.
Bob Borger
On Mar 6, 2010, at 11:58, Mike Parkin <mikenjulie.parkin(at)btinternet.com (mikenjulie.parkin(at)btinternet.com)> wrote:
Hi,
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11
To: europa-list
Hi all,
mau11
06-03-2010
07:39:00
PostPosted: Sat Mar 06, 2010 12:57 pm    Post subject: Hydraulic brake hose Reply with quote
Michel,
The hose came from MDO Aircraft when I bought their stick mounted hand brake caliper.  (See attachment)  I think M. Bastien of MDO Aircraft is based in Biarritz.  I do know that some of our colleagues on this site have had trouble contacting him.  A French person in France may have better luck.
I’ll see if I can find the details of the banjo fitting. I might have to go back to the shop on Monday.
Mike.
Do not Archive
100108a-doc_generale_2009-1_BRAKE.pdf
 Filename:  100108a-doc_generale_2009-1_BRAKE.pdf
 Filesize:  159.65 KB
 Downloaded:  766 Time(s)
Gilles.Thesee(at)ac-greno
PostPosted: Sat Mar 06, 2010 2:01 pm    Post subject: Hydraulic brake hose Reply with quote
Mike Parkin a écrit :
*I think M. Bastien of MDO Aircraft is based in Biarritz. I do know
him. A French person in France may have better luck.*
Mike and all,
Although I've never met Mr Bastien, I've had the opportunity to ring him
about his master cylinder.
I get the impression that communication with potential customers would
be better if their initial message was in French, so if some of you
gentlemen were kind enough to provide an example message, I'd be happy
to translate it into French to help facilitate contact with Mr Bastien.
Like with many of my fellow countrymen, the response to a message in
French might prove considerably quicker.
Best regards,
Gilles
http://contrails.free.fr
rlborger(at)mac.com
PostPosted: Sat Mar 06, 2010 4:04 pm    Post subject: Hydraulic brake hose Reply with quote
Mike & Michel,
I'm in the process of converting to the stick mounted hand brake from MDO. The control column mounted master cylinder is beautifully made. Unfortunately, M. Bastien provided a caliper fitting that consisted of an AN9186 Nipple (Flared Tube to Pipe Thread) to replace the existing 90 degree fitting and then put a 90 degree AN hose end fitting on the end of the hose. See pic:
[img]cid:D7C78858-DD83-4315-BC87-79F4676BC0CC[/img]
The AN fitting is NPT (National Pipe Thread), which is a tapered thread. The 90 degree fitting that came off the caliper was a straight thread so the AN fitting only goes in about 2 threads and quits. That's not really acceptable. A banjo hose end like yours, Mike, would be perfect but I can't find one over here on this side of the pond.
Tomorrow, I'll be posting more pics on my build site showing how the hose end of the banjo should be configured as it's not a (U.S.) typical 37 degree AN type fitting.
If there's anyone out there in Europe or the U.K. that can find the correct fitting, I'd sure be glad to pay for it as well as postage to send it to me.
Thanks in advance!
Check six,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/forums/gallery2.php?g2_itemId=60232
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Mar 6, 2010, at 14:53, Mike Parkin wrote:
Michel,
Mike.
Do not Archive
<100108a-doc generale 2009-1 BRAKE.pdf>
 Filesize:  277.74 KB
 Viewed:  8598 Time(s)
kevann(at)gotsky.com
PostPosted: Sat Mar 06, 2010 6:52 pm    Post subject: Hydraulic brake hose Reply with quote
Hi Bob,
You can tap it to pipe thread, as I did after talking to Terry and Dave (N135TD). You cut the tip of tap off so it won't bottom out. So you are cutting the top part of the threads wider to accept "our" pipe thread.
But the banjo fitting looks very nice too...
Kevin
N211KA
 Filesize:  277.74 KB
 Viewed:  8593 Time(s)
martinboyle53(at)bigpond.
PostPosted: Sat Mar 06, 2010 7:24 pm    Post subject: Hydraulic brake hose Reply with quote
I am in Australia and we assemble a simular hosefor use on brakes our hose is swaged {crimped} we can make it for you but will need some info
Thanks Martin
PostPosted: Sat Mar 06, 2010 8:02 pm    Post subject: Hydraulic brake hose Reply with quote
rob(at)hyperion-ef.com
PostPosted: Sun Mar 07, 2010 2:44 pm    Post subject: Hydraulic brake hose Reply with quote
No need to “modify” a tap, just get the correct tap for the job. There are three basic taps, taper (7 to 10 chamfered threads), plug (3 to 5) and bottoming (1 to 2). When tapping into a blind hole the bottoming tap is preferred if you want threads almost to the bottom (duh!). It is not as easy to get a bottoming tap started by hand, and the chips tend to get jammed into the bottom of the hole so it may take a few “ins and outs” to get the job done.
Best regards,
Rob Housman
Irvine, CA
Europa XS Tri-Gear
A070
Airframe complete
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Kevin Klinefelter
Sent: Saturday, March 06, 2010 6:46 PM
Subject: Re: Hydraulic brake hose
Hi Bob,
Kevin
N211KA
----- Original Message -----
Sent: Saturday, March 06, 2010 4:01 PM
Subject: Re: Europa-List: Hydraulic brake hose
Mike & Michel,
Thanks in advance!
Check six,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Michel,
Mike.
Do not Archive
 Filesize:  139.21 KB
 Viewed:  8566 Time(s)
PostPosted: Mon Mar 08, 2010 11:59 am    Post subject: Hydraulic brake hose Reply with quote
Hello Bob and anyone else wanting the monowheel brake info,
I went to the hydraulic store to day, fortunately he had a computer record of what I bought last year.
You need,
<![if !supportLists]>· <![endif]>G-5093-03 Banjo-03 20 deg 10mm.
<![if !supportLists]>· <![endif]>G-1012-03P 1/8” bsp Banjo Bolt Steel.
<![if !supportLists]>· <![endif]>CW-02P 1/8” bsp Plain Copper Washer (2 off)
http://www.merlinmotorsport.co.uk/p2936/LE-BANJO-20-3/8-POUR-ALLER-%C3%80-3/product_info.html
http://www.merlinmotorsport.co.uk/p2083/BANJO-BOLT-1/8-BSP-STEEL/product_info.html
http://www.merlinmotorsport.co.uk/advanced_search_result.php?keywords=1%2F8+bsp+copper+washer
I feel sure you must be able to buy these parts in the USA, if not email me and I will sort it for you.
Do not archive.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert Borger
Sent: 06 March 2010 18:24
Mike,
Bob Borger
Hi,
To: europa-list
Hi all,
mau11
06-03-2010
07:39:00
07:39:00
rlborger(at)mac.com
PostPosted: Mon Mar 08, 2010 3:50 pm    Post subject: Hydraulic brake hose Reply with quote
Mike,
OK, I see what you have there. Yes, the same banjo parts are available here on this side of the pond (http://www.anplumbing.com).
I had hoped that what you used was a banjo hose end. Now that I know what you did, I need to locate a proper female AN flared fitting hose end to replace the 90 degree hose end provided. Perhaps I can go to anplumbing.com and find the hose end as they have the banjo, bolt and washers.
Thanks muchly for your help,
Bob Borger
PS - That also means that I can use the same sort of banjo setup on the bottom of the Europa supplied hand master cylinder.
That provides interesting opportunities.
On Monday, March 08, 2010, at 01:29PM, "Mike Parkin" <mikenjulie.parkin(at)btinternet.com> wrote:
You need,
·         G-5093-03     Banjo-03 20 deg 10mm.
·         G-1012-03P   1/8” bsp Banjo Bolt Steel.
·         CW-02P   1/8” bsp Plain Copper Washer (2 off)
Do not archive.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Robert Borger Sent: 06 March 2010 18:24 To: europa-list(at)matronics.com Subject: Re: Hydraulic brake hose
Mike,
Bob Borger  Sent from my iPhone
Hi,
From: owner-europa-list-server(at)matronics.com (owner-europa-list-server(at)matronics.com) [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of mau11 Sent: 06 March 2010 16:55 To: europa-list Subject: Hydraulic brake hose
Hi all,
mau11
06-03-2010
No virus found in this incoming message. Checked by AVG - www.avg.com 07:39:00
ttp://www.matronics.com/Navigator?Europa-List
ics.com
.matronics.com/contribution
rlborger(at)mac.com
Mike,
Thanks for the information. I have placed an order through Merlin as the same hose-end banjo does not seem to be available here in the U.S.
I have ordered some other bits from a California distributor which may allow me to keep the original Europa hand brake for the co-pilot use should it become necessary. We'll see how it all works out when all the bits have arrived.
Thanks very much,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
You need,
Do not archive.
fklein(at)orcasonline.com
PostPosted: Mon Mar 08, 2010 5:16 pm    Post subject: Hydraulic brake hose Reply with quote
Mike, et al,
After following and just now reviewing this thread, I find I'm not clear as to just what the issues are with the stock Europa XS mono brake, apart from the substitution of a stick-mounted motorcycle-type hand grip for the stock, tunnel-mounted, hand brake/master cylinder.
I do understand the desirability of having 2 right hands during run-up with the stock setup, and consequently, I fashioned a detent for the hand brake as shown in the attached photo. Whether or not the detent will hold the brake full-on during runup is not known, but for the time being I'm hoping it will serve while I progress w/ other more challenging aspects of my build.
So here's a question...If one were to retain the stock XS mono hand brake lever and master cylinder, are there issues with the kit-supplied hydraulic line and its connection to the wheel mounted brake assembly which warrant substitution using the recently posted banjo fittings?
Fred
A194[img]cid:7A4C0453-15EB-4464-82DC-85272B6C3560[/img]
 Filesize:  49.22 KB
 Viewed:  8542 Time(s)
PostPosted: Mon Mar 08, 2010 5:45 pm    Post subject: Hydraulic brake hose Reply with quote
Hi Mike if you try this company in USA they can supply most hoses and fittings in steel and stainless steel fittings and hoses as well as rubber hoses
Martin
http://brakequip.com/tubes.html
Sent: Tuesday, March 09, 2010 9:44 AM
Mike,
Thanks very much,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
You need,
Do not archive.
rlborger(at)mac.com
PostPosted: Mon Mar 08, 2010 6:15 pm    Post subject: Hydraulic brake hose Reply with quote
Hi Fred,
Ya, the stock factory configuration simply requires too many hands for my complete comfort. It works, but the right hand can be quite busy between the throttle and brake.
There's a very fine line on the throttle friction between difficult to operate and having the throttle spring slowly slip the throttle forward. And it isn't the easiest thing to adjust that friction either.
Then there's the lack of a parking brake to hold things during run-up. Hold the stick in your knees, the brake in the right hand and reach across with the left to set the throttle. The one-armed paper hanger comes to mind.
The stick mounted master solves all those problems easily.
There are no issues on the brake end of things if you stick with the stock setup. The issue arises when you want to switch out to the stick mounted brake. All the brake fittings are straight threads not pipe threads so AN816 nipple adaptors from NPT to Flared Tube don't work. But a nice banjo fitting with banjo bolt work just jim dandy.
I'll be posting a few pics from my trials and tribulations as soon as I send this .
Hope this helps,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
On Mar 8, 2010, at 14:57, Fred Klein wrote:
Mike, et al,
Fred
A194<DSCN0079.jpg>
PostPosted: Mon Mar 08, 2010 7:19 pm    Post subject: Hydraulic brake hose Reply with quote
Have you considered the Matco parking brake valve? I was told of it during the build by others, and am very pleased with the way it functions. It holds the brake on for days. I can do a full power runnup and it holds, no hands! I hold the stick between the knees so the left hand can operate the mag switches.
Will you also have the factory brake master which can be operated from the right seat?
Kevin
Hope this helps,
Bob Borger
Aircraft Flying!
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Mike, et al,
Fred
A194<DSCN0079.jpg>
jrgowing(at)bigpond.net.a
PostPosted: Mon Mar 08, 2010 11:34 pm    Post subject: Hydraulic brake hose Reply with quote
It used to be said that you have a tethered wedge to drop into the space vacated when you apply the brake and this will hold the pressure.
JR kit 327 in Oz
PostPosted: Tue Mar 09, 2010 12:46 am    Post subject: Hydraulic brake hose Reply with quote
With regard to fitting the MDO supplied hose to the banjo coupling.  Everything you need to secure the hose to the coupling comes with the coupling.
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Bob Borger
Sent: 08 March 2010 20:43
Subject: RE: Hydraulic brake hose
[quote]Mike,  OK, I see what you have there.  Yes, the same banjo parts are available here on this side of the pond (http://www.anplumbing.com).   I had hoped that what you used was a banjo hose end.  Now that I know what you did, I need to locate a proper female AN flared fitting hose end to replace the 90 degree hose end provided.  Perhaps I can go to anplumbing.com and find the hose end as they have the banjo, bolt and washers.  Thanks muchly for your help, Bob Borger [b]
