rudder question
JHearnsberger
PostPosted: Wed Mar 03, 2010 12:19 pm    Post subject: rudder question Reply with quote
I will find out when I start clecoing the skin on. But, is the second rib/stiffener supposed to be longer than the bottom rib?
 Filesize:  735.83 KB
 Viewed:  6765 Time(s)
AirMike
PostPosted: Wed Mar 03, 2010 1:49 pm    Post subject: rudder question Reply with quote
I am going to guess that it is longer. As I recall that back seam has an aluminum fillet that is pro-sealed in between the skins. The lower frame accepts the fiberglass lower tail piece. I would suggest at this point that you place #6 nutplates on the tailpiece attach holes. You WILL have to remove this piece for maintainence - the screws are much easier to remove than a spinning pop rivet.
See you OSH '18
Q/B - sold.
Phil.Perry(at)netapp.com
PostPosted: Wed Mar 03, 2010 3:04 pm    Post subject: rudder question Reply with quote
IIRC, it is..... If you look at the skin, you'll see how the rivet
lines merge toward the aft-edge.
The second rib from the bottom is angled down so they meet at the
lower-aft edge of the rudder.
Phil
Deems Davis
PostPosted: Wed Mar 03, 2010 4:40 pm    Post subject: rudder question Reply with quote
Does this picture help?
http://deemsrv10.com/album/Sec%207%20Rudder/slides/DSC00762.html
Deems Davis
N519PJ
www.deemsrv10.com
On 3/3/2010 1:19 PM, JHearnsberger wrote: [quote]
--> RV10-List message posted by: "JHearnsberger" <jakehearnsberger(at)gmail.com> (jakehearnsberger(at)gmail.com)
http://forums.matronics.com/viewtopic.php?p=289085#289085
http://forums.matronics.com//files/img_0260_138.jpg
drfred(at)suddenlinkmail.
PostPosted: Wed Mar 03, 2010 4:50 pm    Post subject: rudder question Reply with quote
Jake;
That looks right from the picture. I don't remember specifically, but I
think some of the fiberglass may fill in that little space. compare it
to the plan pics again.
Dr Fred
515Fw.
JHearnsberger
PostPosted: Thu Mar 04, 2010 9:18 am    Post subject: Re: rudder question Reply with quote
I am having trouble getting the bottom rib to lay flush against the skin. I clamped the rib to a straight edge when drilling the two pieces of the rib together. But, the flange on the spar is a good bit higher than the rib. I have tried using fluting pliers and other bending tools to get the two flanges even with each other. This would be on the right side.
PostPosted: Thu Mar 04, 2010 9:58 am    Post subject: rudder question Reply with quote
Jake,
Check that your R-1010A Sheer Clip is oriented correctly. (That is short flange pointed up - not down). If any of the sheer clips are pointed down, it will cause the associated rib/skin holes to be misaligned.
Phil
 Filesize:  5.78 KB
 Viewed:  6687 Time(s)
