Flap Tape Peeling
hurd(at)gvtc.com
PostPosted: Thu Mar 04, 2010 2:10 am    Post subject: Flap Tape Peeling Reply with quote
The clear UHMW flap tape on my always-hangared ten year old 6A is yellowing and peeling at the edges. Can this tape be removed without also taking off the aircraft-specific paint? Sorry, I don't remember the brand of paint.
I pulled it back in a couple of areas and it seemed to separate fine but I would like to hear from someone who "has been there" before attempting to remove it all.
The present tape came from Vans and I would like to replace it with their reasonably-priced clear UHMW. Otherwise I'll go shopping for white UHMW.   TIA
Jim RV6A O360/CS flying 550 hours
kboatright1(at)comcast.ne
PostPosted: Thu Mar 04, 2010 4:21 am    Post subject: Flap Tape Peeling Reply with quote
I'm in the same situation. I figure I'll try and soften the adhesive with a blow drier and see if I can remove the tape that way. After that, I'll use WD-40 or one of the citrus based cleaners to remove the rest of the adhesive.
But I'd appreciate it if someone else has done this and can offer a proven solution....
Kyle Boatright
2001 RV-6
Neal.George(at)hurlburt.a
PostPosted: Thu Mar 04, 2010 4:55 am    Post subject: Flap Tape Peeling Reply with quote
Mineral spirits will soften the adhesive without attacking the paint.
remove it all.
TIA
smime.p7s
 Filename:  smime.p7s
 Filesize:  5.09 KB
 Downloaded:  393 Time(s)
n621tm(at)tx.rr.com
PostPosted: Thu Mar 04, 2010 6:02 am    Post subject: Flap Tape Peeling Reply with quote
Jim, I went through this a couple of months ago. My tape didn't last near
that long as yours did. I was able to get the old tape off by heating it
and pulling it up slowly without doing any damage to the paint. I then had
to use something to dissolve some small patches of adhesive that remained
behind. I think I used "Goo Be Gone" without any problems. Tom
yenduc(at)me.com
PostPosted: Thu Mar 04, 2010 10:01 am    Post subject: Flap Tape Peeling Reply with quote
One thing you might wish to consider:
After you remove the tape from the flap, you might consider putting
the tape on the lower surface of the wing where it rubs on the flap.
That way the tape is out of sight and still protects the flap. One
point though you must keep the flap surface clean so it will not get
scraped by bugs or grit.
dave
RV 7A
145 hours
On Mar 4, 2010, at 4:53 AM, George, Neal E Capt USAF ACC 505 TRS/DOJ
yellowing
taking off
paint.
but I
attempting to
remove it all.
their
UHMW.
TIA
Vanremog(at)aol.com
PostPosted: Thu Mar 04, 2010 10:14 am    Post subject: Flap Tape Peeling Reply with quote
Hit it lightly with a heat gun just ahead of the area you are peeling off and it should come off much easier. Clean the area with mineral spirits or Coleman Lantern Fluid (Naphtha) and reapply new tape.  All of the natural UHMW is milky (translucent) white. There are some other protective tapes that could be used that are more transparent. Check out 3M website.
-GV
In a message dated 3/4/2010 10:04:32 A.M. Pacific Standard Time, yenduc(at)me.com writes:
[quote]I pulled it back in a couple of areas and it seemed to separate fine
but I
attempting to
remove it all.
their
UHMW.
