robin1(at)mrmoisture.com Guest
Posted: Wed Mar 03, 2010 5:56 pm Post subject: Electronic Ignition Choice |
I am interested in using 1 Mag and 1 electronic ignition system on my
8A. Does anyone have an opinion on what would be the preferred system
for my second ignition the P-Mag or the Hall Effect Light Speed Plasma
III.
Robin
Neal.George(at)hurlburt.a Guest
Posted: Thu Mar 04, 2010 4:43 am Post subject: Electronic Ignition Choice |
Robin -
I'd recommend a P-Mag. Smaller, self-contained, self-powered, easy set-up
and excellent support.
neal
III.
Robin
 Download |
| Filename: |
smime.p7s |
5.09 KB |
| Downloaded: |
493 Time(s) |
riffelj
Posted: Thu Mar 04, 2010 7:46 am Post subject: Electronic Ignition Choice |
Robin,
I chose putting 2 P-Mags on my RV-7A and couldn't be happier with the choice. The things I considered when I compared ignitions were:
- How durable/reliable are they?
- I knew I didn't want Mags because I'd lived with them on previous planes. They weren't Bad, but they took some care and maintenance.
- There was a lot of chatter about the early E/PMags. But they've been reliable for me and the chatter has quieted down the last couple years. As I understand it, they only have one moving part (a shaft in a bearing) that wears a LONG time.
- How easy is it to mount (orientation and form-factor)?
- The PMags have roughly the same size/shape as Mags and can be mounted in any orientation.
- What about fail-safety?
- I chose two PMags so I didn't need any other power source if I had an alternator failure and battery failure. The down side is that I can not hand-prop it if I have a completely dead battery (but I'm not thrilled about hand-prop'g anyway). So I put a jump start connection under the cowl (highly recommended ... ask me how I know)[img]cid:330(at)goomoji.gmail[/img]
- How easy is it to time?
- The PMags couldn't be easier ... less than 1 minute for BOTH units and no special equipment! A REAL advantage if you've timed mags before!
- What about spark plugs?
- With electronic ignition on both sides, I could use auto sparkplugs (at) $2-3/ea vs aviation plugs (at) $20+. That is quite a savings. No fouling either.
- Tach signal
- Yup, works great w/ my GrandRapids EIS.
- Miscellaneous
- I talked w/ the EMag folks at OSH, liked them, felt I could trust them and they seemed like they'd be in business into the future ... other vendors, not the same.
- Support
- I've had their service bulletin done (There's been only one on mine) and they were quick and fair. They've been Terrific whenever I've called with questions.
- Down sides
- Can't really think of any. The connector is a little strange but has been reliable and seems robust so far. I can not vary the timing from the cockpit - but haven't really wanted/needed to.
I only have experience with PMags and Mags (on previous planes), so I can't compare other systems.
Good luck.
"Jerry" Riffel
N554JR - 125hrs
96 Bytes |
4188 Time(s) |
rv8builder
Posted: Thu Mar 04, 2010 8:36 am Post subject: Electronic Ignition Choice |
If you do go with the P-Mag, check out this E or P Mag monitoring
device marketed by a friend of mine, Bill Repucci, who is flying a
RV-9 out of NC.
His web site is http://www.eicommander.com/
Dale
On Wed, Mar 3, 2010 at 7:20 PM, Robin Marks <robin1(at)mrmoisture.com> wrote:
III.
Robin
_________________ Dale |
