lhaggerty(at)tampabay.rr. Guest
Posted: Wed Mar 03, 2010 12:39 am Post subject: 447 |
How can I tell if I am looking at a point breaker 447 or a SDI 447 engine. Pete
herbgh(at)nctc.com Guest
Posted: Wed Mar 03, 2010 9:55 am Post subject: 447 |
Points ignition has ignition coils stacked at the pull start end of the engine...Herb
At 02:39 AM 3/3/2010, you wrote:
[quote]How can I tell if I am looking at a point breaker 447 or a SDI 447 engine. Pete
WhiskeyVictor36(at)aol.co Guest
Posted: Wed Mar 03, 2010 3:00 pm Post subject: 447 |
Pete,
The points 447 has two separate external ignition coils mounted on the side of the engine and also has an ignition damping box mounted onto the pull start assembly housing. The CDI Ducati ignition 447 only has one external ignition coil feeding both plugs.
Bill Varnes
Original Kolb FireStar
Audubon NJ
In a message dated 3/3/2010 3:39:08 A.M. Eastern Standard Time, lhaggerty(at)tampabay.rr.com writes:
| Quote: | How can I tell if I am looking at a point breaker 447 or a SDI 447 engine. Pete
-List href="http://www.matronics.com/Navigator?Kolb-List">http://www.matronics.com/Navigator?Kolb-List
tp://forums.matronics.com/">http://forums.matronics.com
[/b] |
ulflyer(at)verizon.net Guest
Posted: Wed Mar 03, 2010 3:02 pm Post subject: 447 |
Herb, stacked at one end compared to what?
At 09:52 AM 3/3/2010, you wrote:
[quote]Points ignition has ignition coils stacked at the pull start end of the engine...Herb
henry.voris
Joined: 02 Mar 2007 Posts: 116 Location: Pueo Field, Kula, Maui
Posted: Wed Mar 03, 2010 3:54 pm Post subject: Re: 447 |
03feb10
Pete,
Attached is a photo of my thundering 447 w/ Ducatti electrics...
Aloha,
35.14 KB |
9359 Time(s) |
_________________ Henry
Firefly Five-Charlie-Bravo
Do Not Archive |
Posted: Wed Mar 03, 2010 6:11 pm Post subject: 447 |
Compared to a single ign coil with both wires coming out that is below the carb area ...Herb
At 03:14 PM 3/3/2010, you wrote:
[quote]Herb, stacked at one end compared to what?
Checked by AVG - www.avg.com
07:34:00[b]
nla1(at)comcast.net Guest
Posted: Wed Mar 03, 2010 6:53 pm Post subject: 447 |
Henry,
Your picture is a CDI (SDI) ignition system. Here is what a point ignition system looks like
Aloha
henry.voris wrote:
92.31 KB |
9348 Time(s) |
Posted: Thu Mar 04, 2010 9:44 pm Post subject: 447 |
I can't get spark to my electronic ingnition plugs any suggestions before I spend big bucks hireing someone to look at it? Pete
rickofudall
Posted: Fri Mar 05, 2010 5:23 am Post subject: 447 |
What happened and what have you done so far? What are you using determine there's no spark?
Rick Girard
On Thu, Mar 4, 2010 at 11:43 PM, lhaggerty <lhaggerty(at)tampabay.rr.com (lhaggerty(at)tampabay.rr.com)> wrote:
[quote] I can't get spark to my electronic ingnition plugs any suggestions before I spend big bucks hireing someone to look at it? Pete
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Fri Mar 05, 2010 2:57 pm Post subject: 447 |
We removed the plugs, they were wet with fuel, we grounded them and pulled the engine thru several times and could not see spark. Then we checked the kill switch to make sure is was working, checks out good. I am trying to get info on how to check out the cdi coil. Pete
www.avg.com
Version: 8.5.435 / Virus Database: 271.1.1/2724 - Release Date: 03/05/10 13:26:00
elleryweld(at)aol.com Guest
Posted: Fri Mar 05, 2010 10:03 pm Post subject: 447 |
Use a new set of plugs when you are trying to see if it is firing and do it in a dark area so you really can tell if it is firing the old plugs may have gotten fouled
Ellery Batchelder Jr.
