This switch OK?
johngoodman
PostPosted: Mon Mar 01, 2010 7:24 pm    Post subject: This switch OK? Reply with quote
I'm looking at using this switch - will it work in a 14v system?
 Filesize:  135.77 KB
 Viewed:  34303 Time(s)
PostPosted: Tue Mar 02, 2010 6:55 pm    Post subject: Re: This switch OK? Reply with quote
John,
Yes, it will work. Voltage is not an issue for this switch in your airplane. Current is the issue. The picture does not specify 250V AC or DC. I will assume that it is AC. I think it should be safe to use this switch to handle up to 5 amps at 14VDC. A switch will not immediately self-destruct if operated slightly above its rating. But its life will be shortened. How much current do you want to control with this switch and what type of load is it?
Joe
Joe Gores
johngoodman
PostPosted: Wed Mar 03, 2010 5:05 am    Post subject: Re: This switch OK? Reply with quote
Joe
I want to use it for Coil Power for a GearedDrives LS1 V8 engine in an RV-10. I'm not sure what the Coil actually draws but the wire is protected by a 15 amp fuse. The wire from the engine looks like a 14 or 16awg. I'll have to look into the actual draw, but this switch will probably not work since I need reliability. Thanks for the reply,
ulflyer(at)verizon.net
PostPosted: Wed Mar 03, 2010 3:28 pm    Post subject: This switch OK? Reply with quote
John,
Reading your reply to other folks replies I am concerned of your
using this switch for your intended application.
First off, the switch information you provided in the attachment does
not designate if it is rated for AC or DC current. Note, an AC rated
switch if used in an DC current application, the DC current capacity
will normally be only a fraction of it's AC current rating. Second,
I would point out that the reply by Joe saying that you could
probably run 5 amps of current exceeds the switches current rating,
if it turns out to be an AC application switch, you would be further
outside the switches safe operating limits. Neither would be
acceptable solution.
I strongly recommend you determine your current needs for the circuit
your controlling. Then determine if the switch your considering is
AC or DC rated. If the switch is AC rated, find another switch
appropriate for your application. Do it right the first time, you
might not get the second chance to do it over again.
jerryb
http://forums.matronics.com//files/picture_1_380.png
PostPosted: Wed Mar 03, 2010 4:55 pm    Post subject: This switch OK? Reply with quote
What coil? Ignition? The picture I saw appears to
be a momentary push button. If it has 3 terminals,
then I suspect it's a single-pole, double-throw
device. Further, push-buttons of this style are
slow-make, slow-break (no fast acting over-center
mechanism). VERY poor technology for switching
reactive DC loads.
PostPosted: Wed Mar 03, 2010 6:21 pm    Post subject: Re: This switch OK? Reply with quote
Looking at the picture of this switch (made in UK), the first thing that came to mind is that it was going to be used for a starter switch. It turns out that John intends to use it for a more critical application where a high quality switch should be used. So I take back what I said about the switch being ok to use.
As a general rule, a 125VAC rated switch can handle the same current at 14VDC, even if the manufacturer does not publish the DC rating. Every AC switch has a DC ampacity. That ampacity might not have been determined by testing and thus is unknown.
Jerry B. said,
"the DC current capacity will normally be only a fraction of it's AC current rating."
That is true if the voltage remains the same: 250V in this case. But, generally speaking, a 125VAC rated switch can carry as much DC current at 14V as it can carry AC current at 125V. An example of this can be seen by reading the data sheet for another switch. http://www.nkkswitches.com/pdf/stoggleslowcap.pdf
Notice that 125VAC rating is identical to the 30VDC rating. At 14VDC, this switch can handle even more. Also notice that this switch can handle 2 1/2 times the current at 30VDC than it can at 250VAC. Most good quality snap action AC switches are suitable for use in homebuilt aircraft as long as the 14VDC current does not exceed the 125VAC rating of the switch.
Comments are welcome.
Joe
Joe Gores
fvalarm(at)rapidnet.net
PostPosted: Wed Mar 03, 2010 9:47 pm    Post subject: This switch OK? Reply with quote
Remember...
Switches manufactured in the UK will not work in any north American aircraft
(certified or amateur built) as the current flow requirement is OPPOSITE to
what we consider normal. This is why many switch configurations in the UK
call for switch orientation to be up to be OFF and down to be ON. Smile
Just trying to help. We're all in this together. Keep yur sticks on the
ice.
Bevan Smile
tomcostanza
PostPosted: Thu Mar 04, 2010 3:27 am    Post subject: Re: This switch OK? Reply with quote
Remember...
Is this because of that Coriolis thingy? I thought things only went backwards in the southern hemisphere.
Clear Skies,
Tom Costanza
-- in year 17 of a 3 year project
bakerocb
PostPosted: Thu Mar 04, 2010 5:24 am    Post subject: This switch OK? Reply with quote
3/4/2010
Hello Bevan, You wrote:
1) "......as the current flow requirement is OPPOSITE to what we consider
normal."
{Response} Yes, it is those perverse European electrons that cause this
problem. You can imagine what a nuisance it is for all those airplanes
flying across the Atlantic ocean to have to reposition all of their switches
when they go from one electron area to the other.
2) " This is why many switch configurations in the UK call for switch
orientation to be up to be OFF and down to be ON."
{Response} Some recalcitrant European homebuilders have even been known to
install their switches up side down to avoid this problem. Please don't
alert the European homebuilder police to this pernicious activity.
3) "Keep yur sticks on the ice."
{Response} Strange advice. All of my girl friends and even some of my wives
have insisted that I keep my stick in my pants.
'OC' Says: "The best investment we can make is the effort to gather and
understand knowledge."
DO NOT ARCHIVE
Time: 09:47:14 PM PST US
Subject: RE: Re: This switch OK?
Remember...
ice.
Bevan Smile
johngoodman
PostPosted: Thu Mar 04, 2010 6:45 am    Post subject: Re: This switch OK? Reply with quote
I'd like to thank everybody for the interest - I've learned a lot about switches (g).
I've moved on from that switch to possibly this one, but I still need to find out the actual amps on the Coil first:
Included:
1 x Clear Illuminated Button
1 x Protector Cover
1 x Label Sheet (Water Spray, Wipers, Lights, Nitrous, Fan, etc.)
Specifications:
Switch Acutation Style: Push Button
Circuit Activation: Constant
Lighted: Yes (White)
Amp Rating: 10A
Volt Rating: 30VDC
Terminal Type: Blade
Material: Plastic
Quantity: Sold Individually
Mounting Size: 16mm or 5/8"
 Filesize:  206.11 KB
 Viewed:  34211 Time(s)
PostPosted: Thu Mar 04, 2010 7:23 am    Post subject: This switch OK? Reply with quote
At 08:46 AM 3/4/2010, you wrote:
<johngoodman(at)earthlink.net>
about switches (g).
It would sure help if we understood exactly what
this switch is supposed to do. Do you need
push-on, push-off (alternate action) or simply
push-on (momentary but spring loaded to off).
Exactly how does the switch under study integrate
into your airplane . . . and is there a reason
it shouldn't be but one of several switches that
accomplish different tasks? Like one of a row
of switches that control DC power, landing lights,
nav lights, etc.
In other words, why this decidedly odd
device in a machine that will undoubtedly have
several other switches?
johngoodman
PostPosted: Thu Mar 04, 2010 8:42 am    Post subject: Re: This switch OK? Reply with quote
nav lights, etc.
I guess some explanation is in order, sorry about that. I'm looking for a unique switch for Coil Power for my GearedDrives LS1 engine. The panel has a VP200 and no other switches except two battery switches that look just like the VP200 switches (autopilot does have a couple of micros).
The reason for a Coil switch is that I need a quick way to kill the engine. There is no key, and the VP takes care of starting. Otherwise I would have to remove power from the battery busses to stop the engine at the end of the flight. This would kill everything at once, unless I did some power isolation first.
So, I'm looking for a Latching Pushbutton, preferably lit when on. It needs to be obvious to the passengers that it powers the engine. In reality, I think it only draws about 3 amps, 5 at most. Think of it as the "run" position of your keyed ignition.
Hope this helps.
PostPosted: Thu Mar 04, 2010 9:10 am    Post subject: This switch OK? Reply with quote
ignition.
What do your other switches look like? Are
they all the same kind of switch? Are there
other switches that go to control of engine
accessories? Fuel pumps? Why not an identical
switch that says "IGNITION ON" when up and
"OFF" when down?
The device you're considering has a much more
complex internal mechanism than the plain-vanilla
toggle switch. You speak to "removing power from the
battery busses to stop the engine". What devices
feed from battery busses and how are they controlled
to disconnect while the airplane is parked? Is any
single feed from the battery bus required for
the engine to function . . . does that feed power
a device has a backup? You speak to "busses" . . .
so I presume you have dual batteries with 1/2 of
engine-critical loads powered from each battery . . .
how is the change-over from "primary" to "secondary"
hardware accomplished?
PostPosted: Thu Mar 04, 2010 10:16 am    Post subject: Re: This switch OK? Reply with quote
John,
If this switch is going to kill the engine, what will happen if the switch fails while flying? Assuming that you have two ignition systems, there should be one switch for each. Is that what you have planned?
Joe
Joe Gores
klehman(at)albedo.net
PostPosted: Thu Mar 04, 2010 11:49 am    Post subject: This switch OK? Reply with quote
If like many of us here you looking for more than just a yes or no
answer, you might consider that most of us running EFI
systems do not cut ignition power to kill the engine. (I'm assuming you
have EFI) That leaves fuel in the cylinders and (same as a Lycoming) can
be a safety hazard if someone moves the prop on a hot engine. Most EFI
computers will kill the fuel before the ignition.
The next preferred shutdown method would likely be to kill power to the
electric fuel pump(s). That is what I do when I taxi in on my backup EFI
system. Anything other than a normal system shutdown can set engine
codes on some computers though.
I do control power to my secondary ignition coils through a toggle
switch but I never shutdown the engine that way.
Ken
a couple of micros). The reason for a Coil switch is that I need a
everything at once, unless I did some power isolation first. So, I'm
as the "run" position of your keyed ignition. Hope this helps. John
-------- #40572 QB. Engine on, wing attach coming soon. Panel
delivery soon. N711JG reserved
PostPosted: Thu Mar 04, 2010 6:47 pm    Post subject: This switch OK? Reply with quote
Whoa there Joe,
Wow! Can't believe your saying using use AC rated switches for DC
applications at near the full AC current rating is OK. No way.
AC switches take advantage of the AC zero crossing for reducing
contact arcing and welding. (The reason DC switches amp for amp
typically cost more than AC switches, there made different to reduce
and eliminate contact arcing and welding.) And suddenly you say
using the switch the gentlemen asked about is OK and justify your
recommendation upon the spec's of a totally different switch. Use
the right type of switch for your application. Maybe you can
convince the folks that select the switches used for DC powered
landing gear applications to use AC designated switches. Just don't
think you'll quite sell them on your method.
jerb
Jerry B. said,
AC current rating."
Joe
Joe Gores
johngoodman
PostPosted: Thu Mar 04, 2010 6:53 pm    Post subject: Re: This switch OK? Reply with quote
Sorry that I've got everybody wondering; I'll try to explain.
The GearedDrives LS1 Corvette engine is just like a car. In a traditional car, the key has several positions, the last rotation is "start", and it is spring loaded to come out of start to "run." The "run" position is Coil power. It is not actual Coil power which is a lot of juice, just a relay out "under the hood." When you turn off a car, you don't starve it of fuel like airplanes normally do, you kill the coil power.
As far as my switches, The VP200 does everything with soft switches and it's switch panel. The Master Battery and Aux Battery switches are positioned next to the switch panel and are the same brand of switches. The two fuel pumps and the Engine Crosstie will be on three guarded switches on the console, under the panel, that will be normally on. See Z-19 but add a crosstie between the two batteries, put the engine battery bus on the "on" side, but leave the Keep Alive power for the ECU on the engine battery hot side.
There shouldn't be fuel in the cylinders because the ECU won't inject any and the fuel rail regulator is closed. The prop is not connected to the engine because the clutch has released around 700 rpm. You can spin the prop all you want. Fuel is still pumping but isn't getting past the Filter/Regulator which returns all the fuel to the tanks. Fuel can be stopped by turning off the batteries or opening the guarded pump switches.
I'm sure a lot of you think this is wrong, but I'm really not asking. I'm only trying to find a good Kill Switch that is so obvious that even a Cave Man Can Do It.
I'm still amazed that a guy steered a stuck pedal Toyota for 6 miles without ever thinking about the shift stick or the key....
PostPosted: Thu Mar 04, 2010 6:54 pm    Post subject: This switch OK? Reply with quote
At 03:27 AM 3/4/2010, you wrote:
<Tom(at)CostanzaAndAssociates.com>
> Remember...
American aircraft
OPPOSITE to
They do go backwards which is why some toilets (aka water closets)
designed to work in one hemisphere will not work or not nearly as
well if put into service in the opposite hemisphere for which they
were designed to operate which leads me to conclude this thread is
headed for the crapper. Smile
jerb
Clear Skies,
Tom Costanza
http://forums.matronics.com/viewtopic.php?p=289167#289167
PostPosted: Thu Mar 04, 2010 8:36 pm    Post subject: Re: This switch OK? Reply with quote
Wow! Can't believe your saying using use AC rated switches for DC applications at near the full AC current rating is OK. No way.
JERB,
I am not the only one who thinks that it is OK to use AC rated switches in airplanes. Read the last paragraph on Page 2 and page 3 of this document written by a well respected electrical guru,
http://www.aeroelectric.com/articles/Switch_Ratings.pdf
Here is a quote from that article:"
In a nutshell, 125 VAC ratings equate favorably and conservatively to 14 VDC ratings - as long as the switch has a healthy "snap" action . . .The switches we stock sell for $5.00 in a single-pole device and carry no markings for DC ratings. They are rated at 7 amps or better at 115 AC and will work just fine in virtually every slot on an airplane panel."
Joe Gores
PostPosted: Thu Mar 04, 2010 9:41 pm    Post subject: This switch OK? Reply with quote
All switches have ac and dc capabilities at some level.
Just because the ratings on the printed on the side of
the switch are given at 120 or 240 VAC simply speaks
to the largest market into which they are sold. It
doesn't mean that they don't have useful and quite
rational application in DC systems. The comparative
ratings charts for switches in any well written
switch catalog will confirm this assertion.
The voltage rating of a switch is driven mostly by
it's ability to break a circuit . . . spread the
contacts fast enough so that the fire goes out
before damage is done. The intensity of that fire
is proportional to the current in the circuit at
the time the contacts open.
So a switch with contacts that don't overheat at
7A will CARRY that much current at any voltage but
the current may have to be de-rated at the higher
DC voltages . . . because it's harder to put the
BREAK the circuit without generating a lot of heat.
