Posted: Mon Mar 01, 2010 6:55 pm Post subject: Fuel Reserve and UL's |
At 09:21 AM 3/1/10 -0800, you wrote:
Most Rotax 2-stroke engines run closer to .6 lb/hp/hr BSFC.
Thom,
.6 lb/hp/hr <- shouldn't the units be lb/hr/hp ?
Jack B. Hart FF004
Winchester, IN
Dana
Posted: Mon Mar 01, 2010 7:25 pm Post subject: Fuel Reserve and UL's |
At 09:53 PM 3/1/2010, Jack B. Hart wrote:
| Quote: | | .6 lb/hp/hr <- shouldn't the units be lb/hr/hp ? |
Should be .6 lbs/(hp*hr)
-Dana
Change is inevitable, except from a vending machine. [quote][b]
herbgh(at)nctc.com Guest
Posted: Mon Mar 01, 2010 7:50 pm Post subject: Fuel Reserve and UL's |
lets face it...you are not going to get much more than 12 hp per gal per hour... Herb
-Dana
Checked by AVG - www.avg.com
19:34:00[b]
Thom Riddle
Posted: Tue Mar 02, 2010 4:15 am Post subject: Re: Fuel Reserve and UL's |
. 6 pounds of fuel burnt for each hour spent running your engine at one horsepower output.
.6 pounds of fuel burnt for each horsepower your engine outputs for one hour of running time.
Same-Same to me. I personally don't care which order you put the units in. The resulting HP estimate will be the same.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
mark.shimei(at)gmail.com Guest
Posted: Tue Mar 02, 2010 7:45 am Post subject: Fuel Reserve and UL's |
I cruise my Ultrastar at 4400rpm,burn 2 gph at 50mph. Takeoff max RPM is 6000. EGT is just below 1200,CHT is under 290deg.
Gauges were checked for accuracy,I thought they were off. Mark
by0ung(at)brigham.net Guest
Posted: Tue Mar 02, 2010 7:49 am Post subject: Fuel Reserve and UL's |
This is the fuel consumption chart for the 912 ul
Bottom scale is 3000, 4000, 5000, 6000
Right scale lb/hp.hr from bottom up is .5, .55, .6, .65
So do I interpret this to say the harder you push a 912 the less fuel it burns per HP per hour?
And if I interpolate correctly, is around 4.8 lb/hp.hour
Boyd Young
MkIII
8.83 KB |
11432 Time(s) |
Thom Riddle
Posted: Tue Mar 02, 2010 8:04 am Post subject: Re: Fuel Reserve and UL's |
Boyd,
The image is too small to see. If you have a larger version, please post it. I can't find a BSFC graph for the 912 engines in any recent manuals.
Buffalo, NY (9G0)
- Anonymous |
Posted: Tue Mar 02, 2010 8:44 am Post subject: Fuel Reserve and UL's |
Thom- Lockwood's catalogue has copies of the Rotax fuel comsumption charts. You'll need your glasses to read them.
Bill Sullivan
Windsor Locks, Ct.
FS 447
Thom Riddle
Posted: Tue Mar 02, 2010 8:55 am Post subject: Re: Fuel Reserve and UL's |
Bill,
My 2006-7 Lockwood catalogue shows fuel consumption for the 912 series engines only as a GPH curve. I think the older catalogues showed the BSFC curve like on the 2-stroke engines but I threw them away after I got this "new" one at Lockwood's 912 school around that time.
Buffalo, NY (9G0)
- Anonymous |
Posted: Tue Mar 02, 2010 9:22 am Post subject: Fuel Reserve and UL's |
Thom- I put my glasses on to read the fine print, and you are right. They do use different ways to chart the fuel consumption in Lockwood's 2007-2008 book. I wonder why Rotax uses the two systems?
Bill Sullivan
Windsor Locks, Ct.
FS 447
50 degrees, and nice
lcottrell
Posted: Tue Mar 02, 2010 10:10 am Post subject: Fuel Reserve and UL's |
I guess its been a tough spring every where. You guy's are putting a lot of effort and thought into something that is only going to be a WAG for your individual planes and the way that you fly them. Perhaps I am a bit strange as I have never found any of the charts and info from Rotax to be much more than a generalization. Perhaps it is the result of my altitude. I also doubt that many of you actually fly at 75% of power, I know that I don't, I seem to require more than a hole in the sky to satisfy my apparently jaded outlook. But its much better than having a P match.
Keep up the good work!
Larry
Posted: Tue Mar 02, 2010 12:59 pm Post subject: Fuel Reserve and UL's |
Boyd,
Thom Riddle
This chart is a part of the pdf attachment. I added the numbers so they could be read easily.
Boyd
59.86 KB |
11409 Time(s) |
 Download |
| Filename: |
scan0001.pdf |
813.96 KB |
| Downloaded: |
1041 Time(s) |
Thom Riddle
Posted: Tue Mar 02, 2010 1:05 pm Post subject: Re: Fuel Reserve and UL's |
Now I can read it.
All this says is that the efficiency peaks at about 5500 RPM, with approximately .45-.48 (eye-ball accuracy) lbs of fuel burned per hour per HP being produced. Since the curve goes up at lower speeds it will consume more fuel per HP produced at all slower speeds.
Buffalo, NY (9G0)
- Anonymous |
capedavis(at)yahoo.com Guest
Posted: Sun Mar 07, 2010 5:54 pm Post subject: Fuel Reserve and UL's |
Jack getting to the point in my construction that I am sure I will finish the Firefly. It was designed for the 447 but I am whondering about other engines how about the Kawasaki 440? . What do you know about it?it would be easier for me to go with the 447 but the cost is getting out of hand . thank you for your time and Knowledge. C
Chris Davis
KXP 503 492 hrs
Glider Pilot
Disabled from crash building Firefly
Sent: Mon, March 1, 2010 9:53:51 PM
Subject: Re: Re: Fuel Reserve and UL's
--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net)>
| Quote: | --> Kolb-List message posted by: "Thom Riddle" <riddletr(at)gmail.com (riddletr(at)gmail.com)>
Thom,
Jack B. Hart FF004
Winchester, p; -Matt Drall============
Dana
Posted: Sun Mar 07, 2010 6:41 pm Post subject: Fuel Reserve and UL's |
At 08:51 PM 3/7/2010, chris davis wrote:
| Quote: | | Jack getting to the point in my construction that I am sure I will finish the Firefly. It was designed for the 447 but I am whondering about other engines how about the Kawasaki 440? . What do you know about it?it would be easier for me to go with the 447 but the cost is getting out of hand . thank you for your time and Knowledge. C |
I've heard some good things about the 440A. Less powerful than the 447 but reportedly very smooth running. The higher power versions (440B and C) are supposedly less reliable.
Another low cost alternative is the venerable Cuyuna ULII-02. No longer made but still readily available, and parts are cheap.
-Dana
If one synchronized swimmer drowns, do the rest have to drown too? [quote][b]
Posted: Sun Mar 07, 2010 8:04 pm Post subject: Fuel Reserve and UL's |
Chris
I cannot find any info as to when the last 440 series of Kawasaki engines were built? That would be a kicker with me...I feel that it has been 20 to 30 years or more since the last ones were made? I looked at one snowmobile site and found that the 440 was on snowmobiles in 1980... Seems to me that it would be unusual for an engine design to run for 30 years..
The engines may have come to the surplus market in the early 90's.. Searching for Kawasaki snowmobiles for sale...the last I see is an 1982 model...The engine was used on other brands...Maybe John Deere for one? Herb
telling you this because I believe that anyone who says that they have new 440's for sale are not telling the whole truth...
At 07:51 PM 3/7/2010, you wrote:
[quote]Jack getting to the point in my construction that I am sure I will finish the Firefly. It was designed for the 447 but I am whondering about other engines how about the Kawasaki 440? . What do you know about it?it would be easier for me to go with the 447 but the cost is getting out of hand . thank you for your time and Knowledge. C
Chris Davis
KXP 503 492 hrs
Glider Pilot
--> Kolb-List message posted by: "Jack B. Hart" <jbhart(at)onlyinternet.net (jbhart(at)onlyinternet.net) >
Thom,
Jack B. Hart FF004
Posted: Sun Mar 07, 2010 8:44 pm Post subject: Fuel Reserve and UL's |
herb, Like J-bird?
Chris Davis
KXP 503 492 hrs
Glider Pilot
Sent: Sun, March 7, 2010 11:02:26 PM
Chris
| Quote: | Jack getting to the point in my construction that I am sure I will finish the Firefly. It was designed for the 447 but I am whondering about other engines how about the Kawasaki 440? . What do you know about it?it would be easier for me to go with the 447 but the cost is getting out of hand . thank you for your time and Knowledge. C
Chris Davis
KXP 503 492 hrs
Glider Pilot
Thom,
Jack B. Hart FF004
[b] |
Posted: Sun Mar 07, 2010 10:50 pm Post subject: Fuel Reserve and UL's |
Never heard of them!! Herb
At 10:41 PM 3/7/2010, you wrote:
[quote]herb, Like J-bird?
Chris Davis
KXP 503 492 hrs
Glider Pilot
Chris
Chris Davis
KXP 503 492 hrs
Glider Pilot
Thom,
Jack B. Hart FF004
Posted: Mon Mar 08, 2010 12:03 pm Post subject: Fuel Reserve and UL's |
Date: Sun, 7 Mar 2010 17:51:21 -0800 (PST)
Chris,
I have no direct experience with the Kawasaki 440. When I lived in
southeast Missouri, I was a member of EAA Chapter 453 located at Painton,
MO. There was a fellow chapter member, Brian Williams, who purchased
Kawasaki engines from J-Bird and he seemed very pleased with them. He liked
the engine performance and the low cost relative to a 447. He lives in
Cape Girardeau, MO, so you may be able to find a home telephone number for
him and give him a call.
Brian Williams works as a mechanic at:
World of Honda - Yamaha
1728 N. Kingshighway
Cape Girardeau
Phone: (573)334-4266
E-mail: wohy(at)charterinternet.com
He may be able to help you out.
Jack B. Hart FF004
Winchester, IN
Posted: Wed Mar 10, 2010 10:15 am Post subject: Fuel Reserve and UL's |
