Battery charging
jbr79r(at)yahoo.com
PostPosted: Mon Mar 01, 2010 8:54 am    Post subject: Battery charging Reply with quote
Hi Bob
I have been using Panasonic 17AH batteries (2) in my all electric airplane for a few years. I usually change them out at annual time. Someone recommended a 20 AH CSB from m&B battery company. It is the same size and a few dollars cheaper. Any comment?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
skywagon
PostPosted: Mon Mar 01, 2010 9:39 am    Post subject: Battery charging Reply with quote
James,
Curious why you change them out so often.
I'll assume they are fairly expensive batteries.
Do you use a "maintainer" on them on the parked days...? I use Concords and Gill. These get maybe changed out in 5 years, but, they always have a maintainer attached during off flying periods. When I do change them out they are still functioning normally but, like you, there is a period limit that one feels comfortable.
Dave
BobsV35B(at)aol.com
PostPosted: Mon Mar 01, 2010 11:03 am    Post subject: Battery charging Reply with quote
Good Afternoon Dave and James,
I am curious as to whether or not either of you run capacity checks on a regular basis. Isn't that the way the FEDs like us to do it on certified flying machines?
Happy Skies,
Old Bob
AKA
Bob Siegfried
Downers Grove, Illinois
LL22
Piper PA-20-150
In a message dated 3/1/2010 11:41:01 A.M. Central Standard Time, skywagon(at)charter.net writes:
[quote] James,
Dave
BobsV35B(at)aol.com
Happy Skies,
Old Bob
AKA
Bob Siegfried
LL22
Piper PA-20-150
James,
Dave
jbr79r(at)yahoo.com
PostPosted: Mon Mar 01, 2010 1:03 pm    Post subject: Battery charging Reply with quote
In the big scheme of things the battery is a small expense. Especially the ones mentioned. I do not do a capacity check only because it is not something I want to spend the time messing with. I use the removed batteries for other applicatiions.
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Mon, March 1, 2010 11:22:02 AM
Subject: Re: Battery charging
Happy Skies,
Old Bob
AKA
Bob Siegfried
LL22
Piper PA-20-150
James,
Dave
skywagon
PostPosted: Mon Mar 01, 2010 4:02 pm    Post subject: Battery charging Reply with quote
Ol' Bob,
Always enjoy your sage additions to this and other aviation related lists.
To answer your question about "Capacity checking". No, I do not do a formal check annually and probably should. I use other farmer style method.... Example, .. my 185 is fuel injected. Every once in a while, I don't hold my gum and tongue in the right place and miss judge a hot start procedure especially in hot summer time. Next, what comes is probably the hardest application for a battery.
I can misjudge once or twice a year, and the procedure to clear the vapor lock in the injection system, clearing the engine, priming properly and then doing the restart can make an aged battery wheeze. I use that crude rule of thumb to determine if my battery is just not making the juice anymore. I don't recommend it, but, it works for me. In 40 years of flying, I have not been electron deficient.
However, I am a big advocate of using the small Maintainer type devices to keep the float voltage at par.
David
Speedy11(at)aol.com
PostPosted: Tue Mar 02, 2010 7:14 am    Post subject: Battery charging Reply with quote
As is normal for this list, the gentleman's question was not answered and he was instead admonished for using his time-proven techniques (which are not opposed by the list moderator).
I, too, am interested in an answer to James' question.
Please allow me to rephrase James' question.
Are you familiar with the M&B 20 AH CSB battery?
Have you used it in an airplane?
Is it suitable for use in an airplane?
Would you recommend it?
My technique is to change one of my two batteries each year. It is my technique and I'm not asking for comment on my technique.
Any responses to the questions above regarding the M&B 20 AH CSB battery?
Stan Sutterfield
Any comment?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
BobsV35B(at)aol.com
PostPosted: Tue Mar 02, 2010 9:25 am    Post subject: Battery charging Reply with quote
Thank You David and Jim,
Just wondered as I have been using the capacity tests for the last five or six years. I don't think it is imperative to do so, but it is interesting <G>
I find that some batteries do fail the test before I would have normally replaced them. As Jim mentioned. I try to use those batteries in a garden tractor or similar non critical application.
Happy Skies,
Old Bob
In a message dated 3/1/2010 6:04:31 P.M. Central Standard Time, skywagon(at)charter.net writes:
[quote] Ol' Bob,
David
rampil
PostPosted: Tue Mar 02, 2010 3:03 pm    Post subject: Re: Battery charging Reply with quote
Hey Stan,
Possibly the reason no answer was given was because M&B sells lots
of different batteries, but one of us who have to expend some effort to
figure out what kind of battery it is.
I did so, just because of all the chatter.
It is not a M&B battery, it is a CSB sealed Lead Acid battery
Does not say gel vs immobilized in the little ad.
Its probably ok but I have no experience with the CSB brand,
so you will be a test pilot! After you use it a year let us know
what you found. Half price off an Odessey is not bad unless there is
a reason for the cheapness.
As for swapping out batteries every year: what a waste of money!
Driven by FUD, as the IBMers used to say: Fear, Uncertainty, and Doubt.
If you learn a bit about batteries, then maybe you can still use
premium quality Pana batteries and only swap them every other year!
Ira N224XS
jdubner(at)yahoo.com
PostPosted: Tue Mar 02, 2010 4:43 pm    Post subject: Battery charging Reply with quote
BobsV35B(at)aol.com wrote:
[snip]
Me too, Old Bob <g>. (Image of my drill with an external 35AH battery
attached). Seriously, this is a cost-effective substitute for those
expensive replacement NiCad battery packs. I just can't bear to throw
away even a Harbor Freight $20 drill motor and it very useful at times.
The fine print: yes, this is a 12V battery and a 9.6V drill fed with
some 18AWG power cord I had lying around. The drill motor likes it just
fine. The thing should be fused but I consider the entire power cord to
be a "fusible link".
Joe
Independence, OR
http://www.mail2600.com/position
http://www.mail2600.com/cgi-bin/webcam.cgi
 Filesize:  71.43 KB
 Viewed:  18326 Time(s)
flylists(at)dbarrett.net
PostPosted: Tue Mar 02, 2010 6:02 pm    Post subject: Battery charging Reply with quote
This thread piqued my curiosity, so I did a little research. The Panasonic & CSB batteries have similar specs apart from the 17/20 AH rating curve. Their operating range has a lower limit of -15 C (5 F), and an internal resistance of 12-13 mOhms. Internal resistance and temperature range will have a large impact on cold-weather starting. The CSB is limited to a max of 230 A for 5 sec. The Panasonic specs do not provide this information, but I suspect it is similar to CSB due to the internal resistance.
At the other end of the battery spectrum is the Osyssey 680. It has a -40 C (-40 F) lower temperature limit, and 7.5 mOhm internal resistance. They claim a 680 A discharge rate for 5 sec. and 400 A for 30 seconds. The longer time AH capacity is typical for a 16 AH battery. EnerSys (parent company) also produces the Genesis product line at the same plant as Odyssey in Warrensburg, Missouri. The Genesis G12V16EP happens to have the same case design/dimensions, terminals, and electrical specs as the Odyssey 680, but at a somewhat lower price. They may not be identical, but it’s hard to tell any difference. Aviation is on the Genesis application list, so this might be a good value. http://tnrbatteries.com/geg11.html Odyssey and Genesis batteries also have a two year replacement warranty rather than the typical one year.
Spec sheets (note that Odyssey & Genesis have every detail):
Panasonic: http://www.panasonic.com/industrial/includes/pdf/Panasonic_VRLA_LC-PD1217P.pdf
CSB: http://www.csb-battery.com/upfiles/dow01242375277.pdf
Odyssey: http://www.odysseybatteries.com/files/techbook.pdf
Genesis: http://www.enersysreservepower.com/documents/US_GPL_SG_001_0303.pdf
If you’re looking at the Panasonic and/or CSB batteries, there are plenty of other batteries with similar specs that are even lower cost. Among other things, I’d pay close attention to the terminal style. Make sure that vibration won’t weaken the terminal over time. Many of these batteries differ only by the label on top.
If starting current isn’t an issue with you, the lower cost batteries may well be the best value. If you don’t want to be stranded with a dead battery in a cold climate or after a failed hot start, cranking amps will be a large part of your decision process. YMMV
David Barrett
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Speedy11(at)aol.com
Sent: Tuesday, March 02, 2010 10:11 AM
Stan Sutterfield
Any comment?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77 [b]
jbr79r(at)yahoo.com
PostPosted: Tue Mar 02, 2010 9:34 pm    Post subject: Battery charging Reply with quote
Thank you David
This was the type info I was hoping for.  I have used the Panasonic for 4 years with no real problem, however I have dual electronic ignition and I am usually hangered so starts are very easy. However, it is always good to be informed and with alternatives.
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77
Sent: Tue, March 2, 2010 6:39:46 PM
Subject: RE: AeroElectric-List: Re: Battery charging
David Barrett
Stan Sutterfield
Any comment?
Jim
James Robinson
Glasair lll N79R
Spanish Fork UT U77 http========================
PostPosted: Tue Mar 02, 2010 9:46 pm    Post subject: Battery charging Reply with quote
Those who choose to swap out every year should
be doing so precisely because it is NOT a waste of
$time$.
Every new development program I participate in
gets carefully studied to deduce cost-of-ownership.
When it comes to battery maintenance, you
have to decide what YOUR $time$ is worth to do
the extra functions required to guarantee battery
performance. If you're retired and have nothing
better to do than go through the cap-check exercise
periodically, then perhaps a premium battery and
attendant maintenance costs are comfortable to
contemplate.
On the other hand, if you buy the least expensive
battery you can find and simply swap them out
with some logic . . . like new main battery every
year and move main battery to the aux battery slot.
Now for the cost of a new battery you've saved the
$time$ and test equipment to do a cap check and your
confidence level in battery performance is quite
high.
This isn't about fear, uncertainty and doubt.
It's about having no doubts whatsoever based
on an activity that satisfies design goals
and makes economic sense. It doesn't apply to
everyone. For the guy who flies day-vfr to
go rubber-necking, shucks . . . he can run
a battery 'til it croaks. Cost of ownership
is very low. But if you've installed an e-bus
because it offers some capabilities for extended
alternator-out operations, there's a whole
new set of variables and solutions to consider
. . . which may or may not included a new
battery every year.
Speedy11(at)aol.com
PostPosted: Wed Mar 03, 2010 6:58 am    Post subject: Battery charging Reply with quote
Ira,
Good points, all.
If I'm going to ask an opinion of someone on the list, then I certainly must provide accurate information - or expect no answer.
I'm using Odessey and happy with it so far. I have no intention of changing at this time. But, I was interested in the answer to the proposed question. I am always interested in a less expensive, but adequate replacements for equipment.
Perhaps changing a battery each year is a waste of money. And I've been called an old FUDdy before, but it is certainly not out of fear, uncertainty, or doubt.
I change a battery a year because:
1. It is recommended by an expert in the field - Electric Bob
2. My ignorance dictates that I listen to the experts
3. It establishes a reasonable means to avoid failure
4. It is not overly expensive
5. The batteries are used in other equipment and not wasted
6. The oldest battery at any moment in my RV is 2 years.
7. I don't have to bother with capacity checks
I also change my tires before they fail. Anyone who wants the old ones just let me know.
I change my hoses before they fail. Anybody want the old ones?
I don't like being stranded in remote locations because I tried to stretch the life of consumables such as batteries.
Just call me an old fuddy.
Ira, thanks for researching the correct info on the battery and providing your opinion. I appreciate it.
It appears from your comment that you prefer Panasonic batteries.  Which model do you use? Why do you believe that battery is better than an Odessey? Does it have more AH capacity? Does it have faston tabs or screw on terminals?
Your suggestion of replacing a battery every two years seems like a reasonable thing to do - especially if one charges the batteries to capacity periodically.
Stan Sutterfield
Speedy11(at)aol.com
PostPosted: Wed Mar 03, 2010 7:13 am    Post subject: Battery charging Reply with quote
David,
Thanks for your detailed and informative response. Superb info and analysis.
Stan Sutterfield
at a somewhat lower price. They may not be identical, but it's hard to tell
one year.
Panasonic:
df
If you're looking at the Panasonic and/or CSB batteries, there are plenty of
things, I'd pay close attention to the terminal style. Make sure that
vibration won't weaken the terminal over time. Many of these batteries
If starting current isn't an issue with you, the lower cost batteries may
well be the best value. If you don't want to be stranded with a dead
David Barrett
rampil
PostPosted: Wed Mar 03, 2010 8:01 am    Post subject: Re: Battery charging Reply with quote
Hi Stan,
Actually I have always used the Odyssey 680 in my Europa. I trust
Pana in terms of general quality, but the specs for the Odyssey are better
for me in the Northeast.
Just changing batteries annually because you don't choose to learn about
batteries (Not talking about anyone individually here) is a shame. Money
is tight all around and frequent changes ignores the real possibility of
infantile failure which is just as likely in the real world as premature failure
if the products are made in the far, far east.
Sometimes experts disagree. This is Bob's group and I respect that.
I appreciate his public service in dealing with the underending series
of questions. There are also other opinions formed on reasonably
solid foundations of knowledge and experience that may differ
however because some experts place different priorities on different
aspects of a project. Look for example on the scrap between Nuckolls
and Richter a few years ago.
I was once an E.E., I spent 8 years in school and grad school, I
try to keep up with the literature and I hand built my plane and panel.
Ergo, I have opinions and they are not always the same as Bob's.
Is is certainly not a dis at Bob when I think there are better places to
spend money than changing out batteries that should be fairly fresh.
(Of course some people know when they have intentionally abused a battery - that is a different story)
Ira N224XS
Speedy11(at)aol.com
PostPosted: Thu Mar 04, 2010 8:36 am    Post subject: Battery charging Reply with quote
Ira,
I agree on all points.
It is a shame to waste money. But, as Bob reasoned, one can either do capacity checks or replace batteries before they reach their service life. I choose to replace. Laziness on my part, perhaps. For me, it is the better option. On my VFR Pacer, I run the battery until it dies.  On my electrically-dependent IFR RV, I change the batteries every year - although I may switch to 2 year replacements.
I also frequently disagree with Bob - not so much on electric issues, but on philosophy. I still respect and consider his opinions.
It is also nice to have other experts, such as yourself, comment on this forum.
Stan Sutterfield
