lhaggerty(at)tampabay.rr. Guest
Posted: Fri Feb 26, 2010 4:52 pm Post subject: check list |
I am a new Fire Fly owner. Can some other Fire Fly pilots send me examples of the check lists they use for before taxi/take off and before landing/ shutdown. Thanks Pete lhaggerty(at)tampabay.rr.com
cristalclear13
Joined: 19 Sep 2007 Posts: 363 Location: Southeast Georgia
Posted: Tue Mar 02, 2010 12:45 pm Post subject: Re: check list |
A friend helped me with the following lists. Something to start with anyways:
START
1. Seat belts – FASTENED
2. Fuel Prime / Choke – ON
3. Master Switch – ON
4. Clear Prop Area
5. Ignition Switch – START
6. Choke – OFF
7. Intercom Switch – ON
8. Radio – ON, EMER channel, AWOS, airport freq
TAXI / BEFORE TAKEOFF
1. Brakes – CHECK
2. Instruments – CHECK
a. ELT – STANDBY
b. Altimeter – set to airport altitude
3. Flight controls – CHECK
4. Doors – closed and secure
5. CHT – within range
BEFORE LANDING
1. Fuel level – CHECK
2. Undercarriage – CHECK
3. Instruments/switches – CHECK
4. Seatbelts – Fastened
AFTER LANDING
1. ELT – check EMER channel to verify NOT activated
2. ELT - OFF
SHUT DOWN
1. Radio – OFF
2. Intercom Switch – OFF
3. Master Switch – OFF
4. Ignition Switch – OFF and Key OUT
_________________ Cristal Waters
Private Pilot Aug 2008
Rotax 2 stroke maintenance April 2009 |
Thom Riddle
Posted: Wed Mar 03, 2010 5:04 am Post subject: Re: check list |
Sometimes folks get really religious about check lists. As long as you are checking everything before flight that could get you killed if not right, then you are doing a good check list.
That said, I would add the following comments about your list.
1) Checking the fuel level before flight is more important than checking it before landing.
2) I didn't see a mag check in the pre-take-off check.
3) During your take-off roll make sure you are developing normal RPM, if not ABORT. Do not get airborne if your engine is not developing normal RPM.
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
brett(at)xtc-paragliding. Guest
Posted: Wed Mar 03, 2010 5:39 am Post subject: check list |
Here is the list I use. it is a good size when printed for on my knee board;
There is also a 2nd sheet where I jot the basics of each flight down as
i do them.
It is in Excel so you can modify it for your own use.
Brett
On 03/03/2010 14:04, Thom Riddle wrote:
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
An ounce of action is worth a ton of theory.
- Friedrich Engels
http://forums.matronics.com/viewtopic.php?p=289033#289033
 Download |
| Filename: |
CheckList.xls |
18.5 KB |
| Downloaded: |
394 Time(s) |
cristalclear13
Posted: Wed Mar 03, 2010 7:08 am Post subject: Re: check list |
| Thom Riddle wrote: | Sometimes folks get really religious about check lists. As long as you are checking everything before flight that could get you killed if not right, then you are doing a good check list.
3) During your take-off roll make sure you are developing normal RPM, if not ABORT. Do not get airborne if your engine is not developing normal RPM. |
1.) That is in my pre-flight checklist which I didn't include here because I didn't think Pete was asking for that, but do follow religiously because the one time I didn't use it I got lucky but sure learned my lesson.
I haven't used this checklist I attached very much because my plane is so simple this is really in my head. But I will probably start using it because there are times when I forget about my ELT and one time I left the master on and my battery was dead next time I came out.
2.) I don't do a mag check because I have single ignition.
3.) That would be in a takeoff checklist which I also did not include here. If anything is not normal I would abort takeoff. I've only aborted one time when my ASI wasn't reading anything. Oh ya, and another time when my controls felt "funny", but it ended up being a good crosswind had kicked up.
russkinne(at)mac.com Guest
Posted: Wed Mar 03, 2010 7:55 am Post subject: check list |
Seen on a few checklists, but not all, is "check controls for freedom
of movement"
Good idea.
When lined up on the runway for takeoff, the last thing I do is to
push the stick to all four corners to make sure it moves freely and
isn't hung up somewhere.
There was a fatal DC-9 crash once, when a rock blew up into the
elevator hinge, during engine runup, and jammed them full up.
On Mar 3, 2010, at 8:38 AM, Brett Janaway wrote:
knee board;
down as i do them.
Brett
> Thom Riddle
> Buffalo, NY
> Jabiru 2200A #1574
> - Friedrich Engels
<CheckList.xls>
Posted: Wed Mar 03, 2010 8:10 am Post subject: check list |
Yep, that's on that list. About half way down. Pretty much the most
important one to me. I can fly without an engine, but if the control
jams in the corner you're stuffed. Eeeeek
In case people didn't spot it, when you open the Excel sheet you need to
switch to Sheet 1 for the list
On 03/03/2010 16:54, russ kinne wrote:
of movement"
Good idea.
> board;
> as i do them.
> Brett
>> Thom Riddle
>> Buffalo, NY
>> Jabiru 2200A #1574
>> - Friedrich Engels
> <CheckList.xls>
