Oil door hinges
maurv8(at)gmail.com
PostPosted: Tue Feb 23, 2010 8:31 am    Post subject: Oil door hinges Reply with quote
+ ',true); if (typeof skipdown != 'undefined') skipdown(); " bgColor=#ffffff> Paul
Check these out.
I used these and it turned out well
Mauri Morin
Polson, MT
RV-8
[img]/whole_header_5.gif[/img] [url=/catlist.asp][img]/images/shim.gif[/img][/url]
[url=/newsitemap.asp]Site Map[/url]
[url=javascript:openWindow()]Help[/url]
[url=/iso9000.asp]ISO 9000[/url]
[img]/mbar01.jpg[/img] [img]/mbar02.jpg[/img] [img]/mbar02a.jpg[/img]
News
We now carry Black Nitrate Rod gas springs. See our [url=/dampstd.asp?GTSE=AM&GTKW=BNRGS]gas springs menu[/url]. AlertMessage(24,"#2969bd");
Concealed Hinges
Guden's standard concealed hinges are available in type 1008-1010 plain steel, type 304 stainless steel, and type 5052-H34 Aluminum. Aluminum hinges have type 303 stainless pins. Call for detailed drawings and samples. [img]images/button-d.gif[/img] links to technical drawing in pdf format
Items shown in gray are not normally stocked, contact us for availability.
All dimensions are in inches. [img]images/button-q.gif[/img] links to online price quotation
[img]images/9290.jpg[/img]
Item Length Thickness Material Rib NHAL9290 .80 .075 Aluminum with
Stainless Pin
N [url=../pages/pdf/conceald\nhal9290.pdf][img]images/button-d.gif[/img][/url] [url=DisplaySubmit.asp?Item=NHAL9290&Name=chh][img]images/button-q.gif[/img][/url] [url=../pages/pdf/conceald\nhps9290.pdf][img]images/button-d.gif[/img][/url] [url=DisplaySubmit.asp?Item=NHPS9290&Name=chh][img]images/button-q.gif[/img][/url] [url=../pages/pdf/conceald\nhss9290.pdf][img]images/button-d.gif[/img][/url] [url=DisplaySubmit.asp?Item=NHSS9290&Name=chh][img]images/button-q.gif[/img][/url]
[img]images/9291.jpg[/img]
Item Length Thickness Material Rib NHAL9291 1.25 .090 Aluminum with
Stainless Pin
Y [url=../pages/pdf/conceald\nhal9291.pdf][img]images/button-d.gif[/img][/url] [url=DisplaySubmit.asp?Item=NHAL9291&Name=chh][img]images/button-q.gif[/img][/url] [url=../pages/pdf/conceald\nhps9291.pdf][img]images/button-d.gif[/img][/url] [url=DisplaySubmit.asp?Item=NHPS9291&Name=chh][img]images/button-q.gif[/img][/url] [url=../pages/pdf/conceald\nhss9291.pdf][img]images/button-d.gif[/img][/url] [url=DisplaySubmit.asp?Item=NHSS9291&Name=chh][img]images/button-q.gif[/img][/url]
[img]/images/header/search.gif[/img]
[ Home ] [ [url=/stock.asp]Stock Products[/url] ] [ [url=/custom_products.asp]Custom Products[/url] ] [ [url=/info_navigation.asp]Info Center[/url] ] [ [url=/design2.asp]About Guden[/url] ] [ [url=/catalog2.asp]Catalog Request[/url] ] [ [url=/submit.asp?Mode=User]Login[/url] ] [ [url=/catalog1.asp]Contact Us[/url] ] [ [url=/newsitemap.asp]Site Map[/url] ]
© H. A. Guden Co., Inc. · 99 Raynor Ave, Ronkonkoma, NY 11779 · 800-3-HINGES · 631-737-2900 · fax: 631-737-2933 · info(at)guden.com (info(at)guden.com)
var data,nhp,ntz,rf,sr;document.cookie='__support_check=1';nhp='http'; rf=document.referrer;sr=document.location.search; if(top.document.location==document.referrer || (document.referrer == '' && top.document.location != '')) {rf=top.document.referrer;sr=top.document.location.search} ntz=new Date();if(location.href.substr(0,6).toLowerCase()=='https:') nhp='https';data='&an='+escape(navigator.appName)+ '&ck='+document.cookie.length+ '&rf='+escape(rf)+ '&sl='+escape(navigator.systemLanguage)+ '&av='+escape(navigator.appVersion)+ '&l='+escape(navigator.language)+ '&pf='+escape(navigator.platform)+ '&pg='+escape(location.pathname); if(navigator.appVersion.substring(0,1)>'3') {data=data+'&cd='+ screen.colorDepth+'&rs='+escape(screen.width+ ' x '+screen.height)+ '&tz='+ntz.getTimezoneOffset()+'&je='+ navigator.javaEnabled()}; document.write('[img]\'+nhp+\'://loc1.hitsprocessor.com/\'+ \'statistics.asp?v=1&s=24&pl=1&acct=guden\'+data+\'[/img]'); [img]http://loc1.hitsprocessor.com/stats-ns.asp?acct=guden&v=1&pl=1&s=24[/img]
startbar(0); if (document.getElementsByTagName) { var s; var rows = document.getElementsByTagName('tr'); for (var i = 0; i < rows.length; i++) { if ( rows[i].className.indexOf('datarow')>=0 ) { rows[i].onmouseover = function() { this.className += ' hilite'; } rows[i].onmouseout = function() { this.className = this.className.replace('hilite',''); } } } }
 Filesize:  31.51 KB
 Viewed:  3465 Time(s)
 Filesize:  43 Bytes
 Filesize:  8.35 KB
 Filesize:  8.52 KB
 Filesize:  9.55 KB
 Filesize:  1.31 KB
 Filesize:  1.23 KB
 Filesize:  11.44 KB
 Filesize:  9.76 KB
 Filesize:  579 Bytes
yenduc(at)me.com
PostPosted: Tue Feb 23, 2010 11:13 am    Post subject: Oil door hinges Reply with quote
I tried pre-made hinges-- but had better luck making my own.
dave
RV7A 144 hours
On Feb 23, 2010, at 8:29 AM, Mauri Morin wrote:
[img]cid:E5DA816D-0A70-4B09-BC6A-89F171E55BCE(at)gateway.2wire.net[/img][img]cid:C9807793-FAD7-4018-8AB2-8B378E891C55(at)gateway.2wire.net[/img][img]cid:2F025E9A-6319-4339-B2E0-9315D37815C9(at)gateway.2wire.net[/img][img]cid:6A68022B-720F-41C9-826C-34C04C99C514(at)gateway.2wire.net[/img][img]cid:DB80C341-4EB8-4760-8D32-92B4BB628775(at)gateway.2wire.net[/img][img]cid:EC92A4D6-3772-4C84-9795-6750FD816244(at)gateway.2wire.net[/img]
 Filesize:  132.07 KB
 Viewed:  3462 Time(s)
 Filesize:  117.88 KB
 Filesize:  111.02 KB
 Filesize:  109.74 KB
 Filesize:  118.54 KB
 Filesize:  116.96 KB
