Adding Thinned Resin To INSIDE Of Cowling...
Site Admin
PostPosted: Mon Feb 22, 2010 3:01 pm    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Greetings fellow builders,
In the manual, Van's describes a procedure of mixing some resin 1:1 with acetone to form a thin coating for the OUTSIDE of the cowling to make a filler for the pin holes and other surface imperfections. Seems straightforward enough.
But what about the INSIDE of the cowling? That open weave seems like its going to soak up any oil and whatnot that runs out of these leaky 'ol Lycomings.
Thoughts?
RV-8 #82880 N998RV
http://www.mattsrv8.com Matt's RV-8 Building Blog
Finishing up...
n801bh(at)netzero.com
PostPosted: Mon Feb 22, 2010 3:30 pm    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Matt. On my experimental I had the same thoughts but went ahead and layed two thick coats of paint on the inside.... You can barely see the weaving of the substrate but it will wick up oil, and any other liquid that drips on it.. if I had to do it over again I would skim coat it with something to make that surface alot smoother.. Now's the time to do it, not after it gets impregnated with oil.
Ben Haas
N801BH
www.haaspowerair.com
rleffler
PostPosted: Mon Feb 22, 2010 3:48 pm    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Just a coincidence, but I was reading an article from "27 Years of RVator"
this morning that described just that. It talked about when they transition
to the current honeycomb cowls in which the top skins were thinner than the
original cowls. The article recommended thinning the epoxy for fuel/oil and
adding a thin piece of insulation material for heat.
bob
Bob Leffler
N410BL - Phase I
http://mykitlog.com/rleffler
Rick Galati
PostPosted: Tue Feb 23, 2010 3:42 am    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Many builders including me, coat the inside of the cowls over a period of time using epoxy left over from other jobs. By using epoxy that might otherwise be wasted, the inside cowl surfaces can be sealed in phases over a period of time. Some guys thin the epoxy, others don't. Occasionally I did thin it, most times I did not. The result is a smooth sealed surface that is easily wiped clean of inevitable dirt and oils that are certain to accumulate while at the same time providing an excellent bonding surface for the sticky adhesive found on heat resistant foil that you probably will have to install anyway.
Rick Galati
RV-6A N307R
RV-8 N308R
rv6n(at)optonline.net
PostPosted: Tue Feb 23, 2010 4:22 am    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Matt,
I did the thinned epoxy smear and also made an aluminum heat shield with and air pocket under it for where I felt the exhaust was a bit too close for comfort. I also painted the inside and applied the self adhesive foil for added protection. I have attached a photo.
Bob Bales
RV6
 Filesize:  1.37 MB
 Viewed:  7005 Time(s)
JohnInReno
PostPosted: Tue Feb 23, 2010 5:53 am    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Is the self adhesive foil insulated or just reflective?
John Morgensen
RV4 - Purchased flying
RV9A - wiring
rv6n(at)optonline.net (rv6n(at)optonline.net) wrote: [quote] Matt,
Bob Bales
RV6
John Morgensen
RV-9A - Born on July 3, 2013
RV4 - for sale
Paul Valovich
PostPosted: Tue Feb 23, 2010 6:51 am    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
I am just finishing-finishing my -8A cowl and have assembled a list of somewhat obvious and some “life is harder when you’re stupid” lessons learned.
<![if !supportLists]>1.  <![endif]>Fitting – pretty straight forward – but remember the firewall is not straight, it has a horizontal bend in it – a bend that is hidden when the cowl is first taped in place to mark for cutting. One might forget that bend and mark and cut with a straight line. Ask me how I know! Ended up with a gap, but used epoxy/micro on the fus to fill in.
<![if !supportLists]>2.  <![endif]>Gear leg attach – mine didn’t fit. Had to bend and cut the bracket to get it to work.
<![if !supportLists]>3.  <![endif]>I hate piano hinges not so much hate, but really have difficulty getting the pins to slide in and out – so I went came up with the $$ and went with Skybolt fasteners. No regrets.
<![if !supportLists]>4.  <![endif]>If using Skybolts, pay attention and understand the fitting of the attachment strips to avoid visible gaps.
<![if !supportLists]>5.  <![endif]>Skyboltss – really understand how to adjust the receptacle depth. Another one of those things where the RV gremlins seem to appear overnight to change what you thought was a perfect adjustment.
<![if !supportLists]>6.  <![endif]>I installed the Skybolts, hung the cowl(s) then had to depart for couple months on business travel. During that time some preservative oil from the engine leaked and was absorbed by the lower cowl. Painting with epoxy/acetone is a good idea.
<![if !supportLists]>7.  <![endif]>Pinholes – friggin’ randomly appearing pinholes. Tried Vans recommended 50/50 acetone/epoxy on the outside. Looked ok with some pinholes – but when I covered with primer, it was obvious that many pinholes were still here. Ended up with multi-coats of smoothprime, second coat of epoxy, more smoothprime, hours of sanding and finally a couple coats of dark grey primer. No pinholes – but a high minutes/pinhole ratio.
<![if !supportLists]>8.  <![endif]>Now on to the oil door – anyone know why Wicks charges around $11 for a Hartwell hinge, but ACS charges $80+? Obviously a difference in quality / durability – but does it matter? Anyone know of other good sources?
Paul Valovich
N192NM Reserved
Doug Gray
PostPosted: Tue Feb 23, 2010 10:48 am    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Mat,
Do not thin West Systems Epoxy with acetone! I found it turns the epoxy into a chewing gum like mass that never sets up.
Use it as mixed with slow hardener and brush it on thin. Thinning was unnecessary but it can be warmed slightly to help it to flow. It is more akin to squeegee-ing with the side of the brush. This works very well in my opinion.
I'm sure I added less than 1:1 in acetone - or perhaps the West systems product is different in this country, I don't understand why this happened with mine. Fortunately I experimented before using it on the cowling.
Doug
On Mon, 2010-02-22 at 14:57 -0800, Matt Dralle wrote:
[quote] --> RV-List message posted by: Matt Dralle <dralle(at)matronics.com (dralle(at)matronics.com)>
Thoughts? [b]
HCRV6(at)comcast.net
PostPosted: Tue Feb 23, 2010 11:13 am    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Same thing happened for me when I tried to thin Tap brand epoxy with acetone. Took me days to scrape the mess out. I wound up doing it the same way Doug describes below.
Harry Crosby
RV-6 N16CX, 662 hours
chuck(at)chuckdirect.com
PostPosted: Tue Feb 23, 2010 1:05 pm    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
Mix plain epoxy resin/hardner. Lightly sand inside of cowling. Wipe with
clean cloth soaked in alcohol. Paint on epoxy resin mix.
Worked beautifully on both my Ten and Nine. Move on to next step in the
building process.
Chuck
Hi Matt,
In practical terms the fibreglass is pretty impervious to oil leaks. I just
use a bit of degreaser to wash the inside of the cowls at 100hr inspection
times and everything stays pretty clean. The extra weight of all that
additional fibreglass just isn't worth it in the long run.
If it really worries you buy an English Wheel and a TIG welder and make a
set of new cowls out of aluminium. Smile
Good luck
John Morrissey
Lycomings.
Thoughts?
RV-8 #82880 N998RV
Finishing up...
PostPosted: Tue Feb 23, 2010 2:05 pm    Post subject: Adding Thinned Resin To INSIDE Of Cowling... Reply with quote
