Dick Maddux
Posted: Sat Feb 20, 2010 5:34 am Post subject: Clear tubing |
Deke
I found the Tygon SE-200 tubing at McMaster-Carr. Go online and you will find it for about $2.56 per ft (plus shipping of course)
Dick Maddux
Milton,Fl
Fox5flyer Guest
Posted: Sat Feb 20, 2010 8:22 am Post subject: Clear tubing |
Thanks, Dick. I'll check it out.
Deke
Fox5flyer Guest
Posted: Sun Feb 21, 2010 7:01 am Post subject: Clear tubing |
Found it, Dick. Thanks. However, the price has gone up a bit to $3.29 a foot. Is this the same stuff you're talking about?
http://www.mcmaster.com/#5046k13/=5wxi8w
Deke
Fox5flyer Guest
Posted: Sun Feb 21, 2010 1:52 pm Post subject: Clear tubing |
I decided to go with Tygon clear and just figure on changing it out every couple of years. Might be best that was anyhow. I found 25 feet of 1/4" ID online for $30 including shipping so I figure that it will last me for a lot of annuals.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
Previously Model 2 400 hours #606
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
[quote] Found it, Dick. Thanks. However, the price has gone up a bit to $3.29 a foot. Is this the same stuff you're talking about?
Deke
Dick Maddux
Posted: Mon Feb 22, 2010 5:34 am Post subject: Clear tubing |
Deke,
That is the tubing I am using. Order enough so that if you snag the internal liner putting it over the barbed fitting, you can replace the piece of tubing. I snagged the liner on the first piece I used but was able to successfully get the others on by polishing the barb and using a silicone grease product (very sparingly) to lubricate the barb.
Dick Maddux
Milton,Fl
