brubakermal(at)yahoo.com Guest
Posted: Wed Feb 17, 2010 7:51 pm Post subject: wheel tracking |
I have worn the OUT side of my tires after I determined if it is towed in or out can I shim the plate that holds the axel ass. on?
Malcolm Brubaker
Michigan Sport
Pilot Repair
LSRM-A, PPC, WS
(989)513-3022
--- On Wed, 2/17/10, fox5flyer <fox5flyer(at)idealwifi.net> wrote:
Subject: Clear tubing
To: "Kitfox List" <kitfox-list(at)matronics.com>
Date: Wednesday, February 17, 2010, 9:04 PM
I'm down for annual and I'm changing out my tubing for the sight gauges and vent lines. I have always used Tygon tubing (1/4"ID) and although it stays flexible, the best I can get from it is 2 years before it yellows so badly that it is no longer easy to see the fuel levels.
Can anyone recommend a tubing for this purpose that can stand up to auto gas and last a little longer than 2 years, or is this the best I'm going to get considering the circumstances?
Any input appreciated.
Deke Morisse
Mikado Michigan
S5/Subaru/CAP 438+ TT
"If you put the federal government in charge of the Sahara
Desert, in five years there'd be a shortage of sand."
-- Nobel prize-winning economist Milton Friedman (1912-2006)
| Quote: | http://www.matronics.ofollow" target="_blank" href="http://forums.matronics.com">http://foru -
PMorel
Joined: 09 Jul 2007 Posts: 62 Location: Locust Grove, GA USA
Posted: Thu Feb 18, 2010 8:17 am Post subject: wheel tracking |
Malcolm
Before you consider attempting to change the tracking of your wheels, consider this. What I'm talking about is the gear leg that uses bungee cords and not the grove gear. With bungee cords, the gear is toe in to keep the bungee cords from extending and wheels spreading outward during taxi and take-off. Naturally, if the wheels were toe out, then the gears would want to spread out and the bungee cords would stretch. The perfect scenario would be to have a straight track, but even with that, I think you may be looking for a potential problem. You need to decide if replacement of the tires and expense outweighs the possibility of bungee cord breaking and more expensive damage and repairs.
Paul Morel
Model IV Speedster
Locust Grove GA
_________________ Paul Morel
912 Speedster
Locust Grove, GA
www.WingsAirPhotos.com |
Float Flyr
Posted: Fri Feb 19, 2010 6:26 am Post subject: wheel tracking |
Whether you want toe in or toe out depends on whether you have conventional gear or tricycle gear.
On conventional gear toe in will make the plane very squirrely while landing. If the tail goes one side or other on landing the main gear will swerve the opposite direction this can lead to a ground loop.
On tricycle gear toe in is not really necessary as the CG of the plane tends to keep things straight. However some planes do have a little toe in to help assist in keeping the plane straight.
Either way toe in or toe out the shift from straight is usually about 1 degree max.
If you are worried about your bungee gear not being able to handle a little toe out then you better stay away from grass strips where it will get far more workout. These are very light planes and if your tires are wearing on the outside it sounds to me like you have way too much toe in.
My plane a model III-A ( That is what it was sold as by Denney) The toe in can only be changes by de-tempering the welds of the legs, using brute force, then re-tempering the joints. If your axel stub is bolted to the leg/s then I assume you do have a spring leg.
Noel
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of PMorel
Sent: February 18, 2010 12:45 PM
To: brubakermal(at)yahoo.com; kitfox-list(at)matronics.com
Subject: re: wheel tracking
Malcolm
Paul Morel
Model IV Speedster
Locust Grove GA
| Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0123456789
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Tom Jones
Posted: Fri Feb 19, 2010 6:52 am Post subject: Re: wheel tracking |
Malcom, from your measurements...3 5/16" between both wheels in six feet... my rough calculation is that each wheel is toed in about 2 degrees if they are toed in equally. That doesn't seem like much if you are happy with how it handles.
_________________ Tom Jones
Classic IV
Ellensburg, WA |
lcfitt(at)sbcglobal.net Guest
Posted: Fri Feb 19, 2010 8:00 am Post subject: wheel tracking |
I put the 3-5/16" over 72" in my drawing program and it comes out to be
2.79°
Lowell
Float Flyr
Posted: Fri Feb 19, 2010 10:34 am Post subject: wheel tracking |
Just out of curiosity Lowell did you use the straight forward distance as
the 72"or the hypotenuse as 72"?
Noel
Kitfox III-A
Lynn Matteson
Posted: Fri Feb 19, 2010 2:19 pm Post subject: wheel tracking |
If the initial measurement was taken after the plane was pushed
backwards, the measurement was done incorrectly. The plane must be
pushed forward 8-10 feet to neutralize the landing gear before any
measurement will make any sense. The plane in question might be
different, however.
Lynn Matteson
Jabiru 2200, #2062, 855 hrs (since 3-27-2006)
Countdown to 1000 hrs~145 to go(157 days to go)
Sensenich 62"x46" Wood (summer)
Sensenich 55.5" x 46" Wood (winter)
Rotec TBI-40 injection
Status: flying (and learning)
On Feb 19, 2010, at 1:26 PM, Noel Loveys wrote:
distance as
Noel
_________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
Posted: Fri Feb 19, 2010 2:28 pm Post subject: wheel tracking |
Noel,
I just drew a 72" line with approximately 2-5/16 offset and had the program
calculate the angle. My guess was that original measurements were eyeballed
and and that is what I did on the computer. It has been over 50 years since
I had trig, so the cosine stuff was way out of my league.
Lowell
Posted: Fri Feb 19, 2010 8:04 pm Post subject: wheel tracking |
i did back the plane in the hanger then took of the tires and rime and used the wheel hubs for the straight edge. should I put the wheels back on and push the plane into the hanger then take the wheels off to take the measurements? and once again was your calculations 1.25 or 2.78deg off and at 1.25 deg will the tires wear badly?
Malcolm Brubaker
Michigan Sport
Pilot Repair
LSRM-A, PPC, WS
(989)513-3022
--- On Fri, 2/19/10, Lowell Fitt <lcfitt(at)sbcglobal.net> wrote:
Subject: Re: re: wheel tracking
Date: Friday, February 19, 2010, 10:24 PM
--> Kitfox-List message posted by: "Lowell Fitt" <[url=/mc/compose?to=lcfitt(at)sbcglobal.net]lcfitt(at)sbcglobal.net[/url]>
Noel,
Lowell
Posted: Fri Feb 19, 2010 9:22 pm Post subject: wheel tracking |
Malcolm,
I calculated total toe in as you gave a measurement that gave total
difference front to back of your rods. I think Noel gave the toe in for
each wheel. His combined would be 2.25°, which is close to my calculation.
I have done several such measurements on different landing gear sets and the
right and left are usually not the same. I have found on occasion that the
total discrepancy is on one gear leg alone.
Regarding your question, I think I would go on the feel of the airplane on
landing - if it doesn't feel squirrely to you, I would ignore it. If you
are concerned with tire wear, you might consider tweaking it, but that
procedure can be a challenge. What you might do is remount the tires so you
will wear the opposite side.
Lowell
Float Flyr
Float Flyr
Posted: Sat Feb 20, 2010 8:32 am Post subject: wheel tracking |
As usual Lowell you are spot on!
Noel
Kitfox III-A
Posted: Sun Feb 21, 2010 11:51 am Post subject: wheel tracking |
well it dos feel squirrelly on landing I will look into taking measurements to decide if one is out of tow moor than the other. and i have already turned the tires around thank you for youre input mal
Malcolm Brubaker
Michigan Sport
Pilot Repair
LSRM-A, PPC, WS
(989)513-3022
--- On Sat, 2/20/10, Noel Loveys <noelloveys(at)yahoo.ca> wrote:
Subject: RE: re: wheel tracking
Date: Saturday, February 20, 2010, 4:31 PM
--> Kitfox-List message posted by: "Noel Loveys" <[url=/mc/compose?to=noelloveys(at)yahoo.ca]noelloveys(at)yahoo.ca[/url]>
Noel
7suds(at)Chartermi.net Guest
Posted: Sun Feb 21, 2010 1:33 pm Post subject: wheel tracking |
Guys,
Not trying to be controversial or say I know better than anyone else how to setup gear legs, just my 2 cents worth on what I did on my last model 4 with bungee gear and I was pleased with the handling results. I set my wheels so they were between straight and slightly toed out. My reasoning was based off some experience I had racing snowmobile ovals. The reason being as you entered a corner and if your weight got shifted hard to the outside of the sled for whatever reason (which sometimes would happen hitting ruts and holes) you did not want that outside ski to dart the sled back to the inside since your weight was already headed in the other direction, it would jettison you from the sled for sure. My thoughts were to apply the same thinking to the tail dragger, if you get a little squirrelly on landing and the plane rocks to the outside and loads that gear, I did not want it darting the plane back the other way. So that is why I set up my gear as such. It worked great for me. I have landed my 4 at a variety of paved strips in cross winds of 15 gusting to 20 (that’s another story) and have never had a problem with ground handling or the plane getting squirrely on me. But as has been stated here before, in the end it is all about what works for you and experimenting with what is not working to get results you are happy with, so with that said, here is something else to consider / ponder as you seek the perfect setup. Also, I have heard it said that setting up the gear slightly toed out would cause your bungee gear to track out and slightly collapse the gear, for me I did not find that to be the case, however, my build was 537 pounds empty.
Lloyd Cudnohufsky
Model 5 912uls IVO IFA
Northern mi. /
A work in progress
Malcolm Brubaker
Michigan Sport
Pilot Repair
LSRM-A, PPC, WS
(989)513-3022
Checked by AVG - www.avg.com
01:34:00
44.4 KB |
17618 Time(s) |
larry huntley
Posted: Sun Feb 21, 2010 2:01 pm Post subject: wheel tracking |
As long as you brought it up. I Agree! I flew an Aeronca Chief for a while that had one main a bit toed in. Every time the weight shifted to that side the wheel wanted to track right under the nose and th opposite wing tip would head for the sky. Was fine in a crosswind as long as it was from the correct side. ;o) Larry Huntley 4-1200 Soob 500hrs+
_________________ Larry Huntley,Dundee,NY
Kitfox 4-1200 N234EE
EA81,AMAX Redrive Warp 3 blade |
Fox5flyer Guest
Posted: Sun Feb 21, 2010 2:10 pm Post subject: wheel tracking |
Nice airplane Lloyd. I agree with your assessment 100 percent and you explained it very well. I personally wouldn't recommend that anyone with a taildragger have any toe-in at all. Zero. Neutral to a little toe-out is best, in my opinion.
Deke
Posted: Sun Feb 21, 2010 4:51 pm Post subject: wheel tracking |
LLoyd,
I couildn't agree more. I also like the illustration with the snowmobiles -
a perfect example. And a very nice looking airplane - I like the scheme.
I am getting ready to paint and all bets are still on the table.
Lowell
Posted: Sun Feb 21, 2010 6:02 pm Post subject: wheel tracking |
Deke,
Thanks for the compliment. That was my Model 4 XL, attached is a pic of my Model 5 I am working on. (Shooting to have it in the air this summer) It is a little bit farther along than the picture. Tail feathers, wheel pants and cowl are on and the cowl painted. I have one wing to finish repairs on and paint and both wingtips to repair. I am currently installing the IVO IFA Prop, I’m changing the brush location for the prop pitch motor so it is transferred through the hollow gearbox main shaft to behind the gearbox.
Lloyd Cudnohufsky
Model 5 912ul IVO IFA
Northern mi. /
A work in progress
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of fox5flyer
Sent: Sunday, February 21, 2010 4:05 PM
Deke
| Quote: | | http://www.matronics.com/Navigator?Kitfox-Listhttp://forums.matronics.comhttp://www.matronics.com/contribution |
01:34:00 | 0123456789 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 0 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 1 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 2 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 3 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 4 | Quote: | | http://www.matronics.com/Navigator?Kitfox-List | 5
01:34:00
675.61 KB |
17607 Time(s) |
Posted: Sun Feb 21, 2010 6:19 pm Post subject: wheel tracking |
Lowell,
Thanks for the compliments, I enjoyed the time I spent designing and
painting the plane and am enjoying designing and applying the paint scheme
to the model 5 I am building now as well. I look forward to seeing what you
come up with, I have seen allot of beautiful and creative designs come off
this list, (and to be honest I have borrowed and built on a few)
Lloyd Cudnohufsky
Northern Mi.
A work in Progress
Don G
Joined: 10 Jan 2006 Posts: 156 Location: Central Illinois
Posted: Sat Mar 13, 2010 9:18 am Post subject: Re: wheel tracking |
Thats a great black and white paint scheme...on N197BR...is that a Model 4 or 5????
_________________ Don G.
Central Illinois
Kitfox IV Speedster
Luscombe 8A
RV9A |
