naca duct
chris Sinfield
PostPosted: Fri Feb 19, 2010 2:19 am    Post subject: naca duct Reply with quote
Ok Ask twice measure twice cut once..
on the FWD NACA ducts in the cabin, is the rear face (straight part) supposed to run at 90 deg to the flat top longeron?
I have the older plans and the new plastic NACA duct. At the moment it is sitting nicely between the L angles but they run at an angle and so the rear of the cut out would not be 90 deg to the horizontal.
chris..
jaybannist(at)cs.com
PostPosted: Fri Feb 19, 2010 4:49 am    Post subject: naca duct Reply with quote
Chris,
The photo shows where I placed mine. I put it in that location and attached the eyeball outlet directly to the plastic duct outlet.
Jay Bannister
--> Zenith601-List message posted by: "chris Sinfield" <chris_sinfield(at)yahoo.com.au (chris_sinfield(at)yahoo.com.au)>
 Filesize:  141.76 KB
 Viewed:  4005 Time(s)
 Filesize:  102.98 KB
tigerrick(at)mindspring.c
PostPosted: Fri Feb 19, 2010 5:53 am    Post subject: naca duct Reply with quote
Hi, Chris!
My favorite solution is to used the aluminum Aveo Ball Vent with a 1.75" rear sleeve, popped right into the outlet of the NACA vent. A couple of wraps of tape around the sleeve makes for an airtight fit between the vent and the duct, and you're done!
Here are a couple of shots of my installation, one with the sleeve only installed, and another with the vent part threaded in. Easy peasy.
Rick Lindstrom
N42KP
 Filesize:  1.25 MB
 Viewed:  4001 Time(s)
 Filesize:  1.18 MB
