lcottrell
Posted: Sat Feb 13, 2010 6:11 pm Post subject: test flight with the spot. |
Today I could find no reason to not fly. Weather was 50 degrees on the ground, wind was not blowing on the ground as well. I did have a 10 mile an hour tail wind on the way out once I got out of the hill shadow.
Things have been pretty quiet, the weather has been a bit too unsettled to do much more than catch up on my reading. Now my eye strain is bad enough to make an effort to get out and do something, anything!
I have always been very aware of the worry that Karen goes through every time that I go flying by myself. The country here is the least populated in all of Oregon, I am sure that it ranks up there with some other parts of the US as well. I installed a base aircraft radio to help and while the range is as much as 60 miles it requires one to be pretty high to accomplish that kind of range. I prefer to be within a hundred feet of the ground, so it means that if I decided to do something other than what I told her before leaving, I need to climb up high enough to talk to her. Wastes gas something awful.
I bought a Spot Messenger last year, but I did not get the tracking feature. Too cheap! It seemed to work somewhat, but the lack of a permanent placement in the plane caused it to be of limited use. I decided to purchase the tracking feature this year. I could say that it was for Karen, but some of the places that I go are really hard to get there from here, and I don't like walking all that much. We will just say that it seems like a good deal for both of us.
There is a "Gap Seal" between the wings of "Dart" that is made of Lexan, so I made a holder that would keep its antenna pointed to the sky. It worked sitting in front of the hanger, but it needed a flight to really give it a good test.
Today the weather seemed to invite flying so I rolled her out, dressed warm and took off for Arock. It was apparent that the wind was blowing at about 10 MPH from the West when I got up out of the wind shadow that shades the airstrip. The temps at 5000 feet was 40 degrees, so I wasn't sorry that I had put on my warm clothes. The plane and engine preformed flawlessly although I will put some tape on the oil cooler the next time I fly. The oil temps never got over 130 degrees, a bit cool for proper operation. I stayed at 1000 feet agl and checked some of the ponds and rabbit spots that we hunted Jessie and Peg (the hawk and falcon) on this fall.
In all the trip took 74 minutes and I burned 3.5 gallons of gas. I covered a bit more than 60 miles and even though I was down to 50 MPH coming back, I still averaged 60 MPH.
The wind was right for the short cross wind strip and I had drug it and rolled it, so I was interested in how it would feel. My landings are sometimes a thing of wonder. (wonder how anyone who has the hours that I have, can land so crappy. ) Except the first ones after a long lay off. My Golf games are like that too, the longer I play or fly the worse my game and the landing get. I can't explain it, unless I just get careless. Any way I started letting down about a mile from the strip, did just like my instructor had told me so many times and depending on my position either gave it gas, or allowed it to bleed off altitude, and made one of those landings that no one ever sees, a perfect three point landing with so little roll out that I had to give it gas to get to the turn off to the hanger. It is only 320 feet from the fence to the hanger. Oh well, someday I will be able to do that every time. Yeah, right!
I was pleased with the results of the test, I had nine tracking points, that should make life or life flight easier.
http://share.findmespot.com/shared/faces/viewspots.jsp?glId=0siAoTNYTZD6KPbiDncNLfKZruRqx5nUO
This is the link to the shared page, I prefer to use the hybrid map since it shows the sat picture and roads as well.
Larry C,Oregon Firestar II
9.34 KB |
12673 Time(s) |
9.26 KB |
12673 Time(s) |
8.45 KB |
12673 Time(s) |
5.49 KB |
12673 Time(s) |
7.59 KB |
12673 Time(s) |
5.06 KB |
12673 Time(s) |
11.69 KB |
12673 Time(s) |
Posted: Sat Feb 13, 2010 6:29 pm Post subject: test flight with the spot. |
Larry,
What did that little SPOT critter set you back? How much does the service run you, and what do you get for your money?
Mike Welch
MkIII
Hotmail: Trusted email with Microsoft’s direct/01/' target='_new'>Sign up now. [quote][b]
lcottrell
Posted: Sat Feb 13, 2010 7:19 pm Post subject: test flight with the spot. |
Goggle "Spot" and it will take you to their home page. There was even an article in AOPA's mag this month. I think I paid $97 bucks for the main service and 48 for the tracking. What the hell, its only money, but it does keep the little lady happier, and will me as well if I ever manage to ball things up. I do not fly what is considered safe as there are generally no roads where I want to go. Most of the GA guys would crap their pants in the places where the little Firestar takes me. I have done all that I can to stack the odds on my side, and the spot is one way to do that.
If you go to the link on the previous email you can see the track that I flew. If you click on one of the little balloons you will have the Lat and Long of the area that I was when the spot transmitted. At my speed it narrows the search area to about 6 miles if I should crash 9 minutes from the last send. It sends every 10 minutes. It will allow you to send an "OK", a request for "help" (this one is a non panic request) and a "911" as well as the tracking feature. You can specify who gets any of the three messages. It is about the cheapest insurance available for me. A flight plan for me to tool around the area is not feasible.
Larry
frank.goodnight(at)att.ne Guest
Posted: Sun Feb 14, 2010 5:39 am Post subject: test flight with the spot. |
Hi mike,
For what it worth .I got a spot for xmas. when I went on line to activate it , the factory told me to return it, that they had some problems and that at some unspecified time they would
send me a replacement. Haven't received one yet and they won't tell me when to expect one .
Frank Goodnight
Firestar 2
Brownsville , TX
On Feb 13, 2010, at 8:28 PM, Mike Welch wrote:
[quote] Larry,
Mike Welch
MkIII
Hotmail: Trusted email with Microsoft’s direct/01/' target='_new'>Sign up now. | Quote: |
Posted: Sun Feb 14, 2010 6:46 am Post subject: test flight with the spot. |
>Frank Goodnight
>Firestar 2
>Brownsville , TX
Larry,
Thanks for the detailed info on the Spot. This little gadget ought to be required equipment for people that fly in not-so-distant terrain, not to mention the boonies!! The fact that your rescue team can come directly to where you are (or at least close to where you are) would be a huge safety factor, especially if a guy was injured!! I'll definitely get one, when the time is right.
(On a side note; many of you may recall there were 3 hikers that went missing, around Christmas, on some Oregon mountain. I think they found one of them after a couple of days looking. He was dead. They looked for a few more days for the other two. As far as I know, they never found the other two. They are dead, too.
In this day and age of technology, it seems utter nonsense to not have this kind of locater beacon. You save hundreds of hours of people looking for you. You allow your loved ones to know exactly where you are....and in what condition you're in. You may, in fact, save your own life, by being found relatively quickly.
Although ELT's are required in Experimental aircraft, their success at locating you has been reported as low.
For guys that fly, a Spot is a great idea. Even if the only reason is to keep the sweetie at home happy.
I'd bet those three hikers wish they had a Spot.)
Frank,
I recall you mentioned you sent in your Spot for servicing. I hope they get it back to you soon. I would imagine it will be a year or so before I'm in the market for a Spot. Hopefully they will get the bugs out it by then.
Happy Valentine's Day to all. Give your loved ones a squeeze.
Mike Welch
MkIII
central Missouri
Hotmail: Powerful Free email with security by Microsoft. [quote][b]
herbgh(at)nctc.com Guest
Posted: Sun Feb 14, 2010 6:52 am Post subject: test flight with the spot. |
plus ....there is a big rescue bill awaiting if one lives... Herb
At 08:46 AM 2/14/2010, you wrote:
[quote]> Haven't received one yet and they won't tell me when to expect one .
>Frank Goodnight
>Firestar 2
>Brownsville , TX
Larry,
Frank,
Mike Welch
MkIII
central Missouri
russkinne(at)mac.com Guest
Posted: Sun Feb 14, 2010 7:12 am Post subject: test flight with the spot. |
Good point, but frankly: bill, schmill! Sometimes I illegal carry an aircraft radio when sailing well offshore, out of VHF range. Can always raise an airliner 5-6 miles up, on the airline freq's.
My feeling is, if I'm alive, they can jail me. If dead, no way. I'd prefer alive & in jail.
SPOT sounds like the best of both worlds.
Russ K
On Feb 14, 2010, at 9:52 AM, Herb wrote:
| Quote: | plus ....there is a big rescue bill awaiting if one lives... Herb
| Quote: | > Haven't received one yet and they won't tell me when to expect one .
>Frank Goodnight
>Firestar 2
>Brownsville , TX
Larry,
Frank,
Mike Welch
MkIII
central Missouri
Posted: Sun Feb 14, 2010 7:18 am Post subject: test flight with the spot. |
A large rescue bill...should be a behavior modifier!! Guess the estate can pay it...?? Herb
At 09:11 AM 2/14/2010, you wrote:
[quote]Good point, but frankly: bill, schmill!
Russ K
>Frank Goodnight
>Firestar 2
>Brownsville , TX
Larry,
Frank,
Mike Welch
MkIII
central Missouri
href="
">http://www.matronics.com/Navigator?Kolb-List
href="
http://forums.matronics.com">http://forums.matronics.com
href="
">http://www.matronics.com/contribution
[/b] |
Checked by AVG - www.avg.com
07:35:00[b]
Posted: Sun Feb 14, 2010 7:45 am Post subject: test flight with the spot. |
Mike:
I have this Personal Locator Beacon:
http://www.acrelectronics.com/microfix/microfix.htm
I fly with it, and also use it when I am riding my dirt bike, ATV, or mountain bike.
Initial purchase is much more than the SPOt, but a one time purchase and no annual fees.
The PLB works with NOAA SARSAT:
http://www.sarsat.noaa.gov/
john hauck
woodville, florida
[quote] Although ELT's are required in Experimental aircraft, their success at locating you has been reported as low.
Mike Welch
_________________ John Hauck
Titus, Alabama |
Thom Riddle
Posted: Sun Feb 14, 2010 7:51 am Post subject: Re: test flight with the spot. |
Per Russ
...Sometimes I illegal carry an aircraft radio when sailing well offshore, out of VHF range....
I never heard that one before. What makes carrying an aircraft radio when sailing well offshore "illegal"?
_________________ Thom Riddle
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Feb 14, 2010 9:36 am Post subject: test flight with the spot. |
If you are well enough offshore NOTHING is illegal.
On 14, Feb 2010, at 10:51 AM, Thom Riddle wrote:
Per Russ
Thom Riddle
Buffalo, NY
Kolb Slingshot SS-021
Jabiru 2200A #1574
Tennessee Prop 64x32
Consistency requires you to be as ignorant today as you were a year ago.
 - Bernard Berenson
http://forums.matronics.com/viewtopic.php?p=286388#286388
Posted: Sun Feb 14, 2010 9:37 am Post subject: test flight with the spot. |
>john hauck
>mkIII
>woodville, florida
John,
I DO like not having an annual fee. I'd prefer a one-time purchase. How much did your ELB unit cost?
I didn't realize there were more than one brand of these ELBs. Although I wouldn't hesitate to get the Spot brand, if that was all that was out there, the one-time purchase price of this model would likely push me in this one's direction.
Thanks, Mike Welch
Hotmail: Free, trusted and rich email service. [quote][b]
Thom Riddle
Posted: Sun Feb 14, 2010 10:02 am Post subject: Re: test flight with the spot. |
FWIW,
I was wondering about location accuracy on these 406 PLBs and found the following excerpt on the NOAA.gov site:
....or a standard 406 MHz PLB the location accuracy is around two to three miles. Generally, this equates to a search time of around an hour for a search team on scene — depending on the terrain. Some beacons, however, take advantage of GPS technology and are able to generate a position with even greater accuracy. Those PLBs which have GPS receivers, attached either internally or externally, are able to produce a position smaller than a football field. For SAR teams, that means they can go directly to your location without having to conduct much of a search. With time always the critical element in a distress case, this can sometimes mean the difference between life and death...
Looks to me like the more expensive ones with an internal GPS would be worth the price if you actually come to need one at all.
Buffalo, NY (9G0)
- Anonymous |
Posted: Sun Feb 14, 2010 11:13 am Post subject: test flight with the spot. |
I have a PLB (personal locator beacon with internal GPS), not an ELB.
The urls I included with my last msg will give you all you need to know about PLBs, cost, capability, etc.
john hauck
Woodville, FL
| Quote: | I have this Personal Locator Beacon:
>john hauck
Mike Welch
Titus, Alabama |
death...
Thom Riddle
Thom R/Gang:
That is why I opted for a PLB with internal GPS. Spot was not available
when I bought my ACR PLB. Not sure if I would have gone with the SPOT or
not, had it been available. I think I like the capability of the PLB and
the NOAA system better.
100 meters is worse case. The grid coordinates the PLB transmits to NOAA
SARSAT will be typical of what your nav gps probable error is, which in my
case, down to a couple two or three meters..
Time will probably be critical in most rescues.
john hauck
Woodville, Florida
Titus, Alabama |
lcottrell
Posted: Sun Feb 14, 2010 11:23 am Post subject: test flight with the spot. |
While I agree totally with all that is said about the PLB's, the reason that I have the spot, is not so much for precise location of a 911 call for help, although the spot will do that as well. My main requirement of the spot is the fact that I really do not have to hit a button, or for that matter be physically able to hit a button for it to keep accurate locations of where I am and have been. If you are capable of initiating a 911 call it will be within 20 to 50 feet of your actual location, if not then depending on how long into your flight from the last check in, with the Firestar, a mile each minute up to the 10 minutes between check in's should enable a quick and efficient search depending of course on terrain.
Now, a disclaimer for Spot. The web site and tools that are installed in it seem to my thoughts to be a royal pain in the ass, however all that is not enough to overcome the usefulness that the spot can deliver.
There are many ways to safeguard your flights and safety, from the way that your plane is set up for the terrain that one flies. ( tires, steel gear legs, survival items in the plane, etc. ) To the way that you fly. I personally do not choose to fly as though my plane is trying to kill me. I know full well that if that does happen it will be because I was not up to surviving due to carelessness or inattention. Yeah, crap happens all the time, some of it is more serious than others, and I cannot deny that I can occasionally be dumb enough to soil my shorts after the excitement has cooled down, but it isn't going to rule my life or the things that I like to do. I accept the full responsibility for the things that I do and am fully aware that someday I may not be up to the task. So be it! That attitude will not stop me from doing all I can to ensure that I die peacefully of old, satisfied age.
Larry C
Posted: Sun Feb 14, 2010 12:11 pm Post subject: test flight with the spot. |
I echo Larry C's sentiments exactly.
If I didn't feel comfortable flying the way I do, I would spend my old age typing and sharing stuff I heard from others and had never experienced and enjoyed myself.
Aviation has always been exciting to me, since the day I soloed a TH-55 at Fort Wolters, TX, at the ripe old age of 29. That was Sep 1968. I was a late bloomer, but I have made up for it in my senior years. If I can not keep aviation exciting, I have a lot of other things to do I enjoy just as much and produce just as much adrenalin as the little Kolb. All of these activities are conducive to having a PLB to save my bacon if necessary.
PLB is a lot like a parachute. When you need it, it is worth every penny you spent for it.
john hauck
Woodville, Florida
Larry C
Titus, Alabama |
