Harvey Richards
Posted: Wed Feb 10, 2010 3:00 am Post subject: Pitch control rod length |
When setting up the pitch control rod,have you used the length in the plans,685mm which would put the horizontal tail bellcrank at approx 75 degrees when the stick is at 90, or are they both at 90 degrees then the length should be approx 625mm. Thanks.
_________________ CH 701 |
dougsnash
Posted: Wed Feb 10, 2010 5:02 am Post subject: Pitch control rod length |
Harvey, attached is a document that I got From Jon Croke. It originally came from Caleb (at the factory) I believe. It might help clear up your issues.
By the way, this did not help me at all and I ended up cutting the belcrank off of the torque tube and solidly mounting it to the airframe. Sorry guys, I'm not going to share any pictures of that because I'm not happy with it yet.
Doug MacDonald
CH-701 scratch builder
Final details
NW Ontario, Canada
--- On Wed, 2/10/10, Harvey Richards <lisa.richards(at)ns.sympatico.ca> wrote:
| Quote: | From: Harvey Richards <lisa.richards(at)ns.sympatico.ca>
Subject: Pitch control rod length
To: zenith701801-list(at)matronics.com
Received: Wednesday, February 10, 2010, 5:00 AM
--> Zenith701801-List message
posted by: "Harvey Richards" <lisa.richards(at)ns.sympatico.ca>
CH 701
__________________________________________________________________
Connect with friends from any web browser - no download required. Try the new Yahoo! Canada Messenger for the Web BETA at http://ca.messenger.yahoo.com/webmessengerpromo.php
 Download |
| Filename: |
Rigging_Elevator_Controls.pdf |
23.55 KB |
| Downloaded: |
610 Time(s) |
Harvey Richards
Posted: Wed Feb 10, 2010 5:51 am Post subject: Re: Pitch control rod length |
Thanks Doug. That makes more sense than having both at 90 degrees as the cables have to go to the top of the fuse ans should be equal lengths as I see it.
Tommy Walker
Joined: 12 Jan 2006 Posts: 442 Location: Anniston, AL 36207
Posted: Thu Feb 11, 2010 7:22 am Post subject: Re: Pitch control rod length |
I tried to follow Caleb's suggestion too. And for the most part it worked. Just be sure to fit the pitch control rod last. I think I had to cut about 15 mm of the end to get the 30 mm slot right.
I still get elevator cable tension of 30 lbs when I move the stick to the side. I am going to try 10 lbs and see if that helps.
Tommy Walker in Alabama
N8701T
Taxi Test: http://www.youtube.com/watch?v=zcm9jtX2Mrg
| Harvey Richards wrote: | | When setting up the pitch control rod,have you used the length in the plans,685mm which would put the horizontal tail bellcrank at approx 75 degrees when the stick is at 90, or are they both at 90 degrees then the length should be approx 625mm. Thanks. |
_________________ Tommy Walker
N25A - Anniston, AL |
dougsnash
Posted: Thu Feb 11, 2010 7:54 am Post subject: Pitch control rod length |
Tommy, does your top elevator cable clear the top of the channel that supports the back end of the torque tube? The main reason that I went with a separate bell crank was that my cable was seriously rubbing on the channel. I now have a good inch of clearance.
Doug MacDonald
CH-701 Scratch builder
NW Ontario, Canada
--- On Thu, 2/11/10, Tommy Walker <twalker(at)cableone.net> wrote:
| Quote: | From: Tommy Walker <twalker(at)cableone.net>
Subject: Re: Pitch control rod length
Received: Thursday, February 11, 2010, 9:22 AM
posted by: "Tommy Walker" <twalker(at)cableone.net>
see if that helps.
N8701T
Tommy Walker
N8701 - Anniston, AL
http://forums.matronics.com/viewtopic.php?p 85944#285944
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
Make your browsing faster, safer, and easier with the new Internet Explorer® 8. Optimized for Yahoo! Get it Now for Free! at http://downloads.yahoo.com/ca/internetexplorer/
Tommy Walker
Posted: Thu Feb 11, 2010 7:26 pm Post subject: Re: Pitch control rod length |
Doug,
I responded to this, but I must have done something wrong as my comments do not appear.
Yes, we have clearance of the top cable over the back of the channel. Not much, but it does clear.
I like your idea of the separate control.
| dougsnash wrote: | Tommy, does your top elevator cable clear the top of the channel that supports the back end of the torque tube? The main reason that I went with a separate bell crank was that my cable was seriously rubbing on the channel. I now have a good inch of clearance.
Doug MacDonald
NW Ontario, Canada
