z601c(at)anemicaardvark.c Guest
Posted: Thu Jan 28, 2010 8:18 am Post subject: Recommended Letter-writing campaign, follow-up |
Here is the email I sent AOPA. I encourage everyone to express their concerns
to them, whether they specifically agree with me or not.
I was both surprised and disappointed when I read the article on the Zenith
601XL. Filled with misinformation, the story makes a bad situation worse.
First, Zenith does not offer an E-LSA version of the 601XL. It offers a factory-
built LSA version, or a kit for an experimental, amateur-built version (EAB).
An EAB is not an E-LSA; there are significant differences.
Second, although the 601XL has had more than its share of accidents, I am not
aware of any knowledgeable witnesses to any of them. The witnesses have been
well-meaning people of the same caliber that think an engine stall and a wing
stall are the same thing. That has been one of the problems: aircraft which
fail in flight, yet without a single common thread that defines the exact
problem, and no reliable witnesses.
Your article implies that flutter is at fault. That should be discernible with
ground vibration testing (GVT). Yet when Zenith had GVT done by an independent
authority, a properly rigged aircraft showed no resonance. Flutter seems
pretty unlikely.
A second GVT was conducted by the LAA in England. Examination of the
methodology of that test raises significant questions about the validity of the
test. However, the only resonance it indicated was the aircraft swaying from
side to side on its gear. Despite the fact that it did not indicate flutter as
the problem, it was used as the justification to require UK 601XLs to install
aileron balances.
Zenith's demonstrator aircraft has well over 1,000 hours on it, but has shown
no problems. Numerous privately built aircraft have also amassed significant
hours without difficulty. The individual in the hangar next to me, who has a
Czech factory built version, put over 300 hours on the aircraft last year
without problems.
Since aircraft built by individuals, Zenith's facility in Georgia, and one
aircraft built under license in eastern Europe have all experienced breakups,
it may be the problem is how the aircraft is flown. A search on YouTube has
shown 601XLs performing acrobatic maneuvers, suggesting some may have
overstressed their aircraft.
Despite the lack of a definite cause, Zenith has, in good faith, released a
modification kit that essentially fixes everything that might be wrong. Whether
or not this targets whatever the actual problem may be is open to question,
because that remains unknown.
I normally depend on AOPA to at least get the facts straight. Please, do a
better investigation, get the facts, and THEN publish a revision to the
article. AOPA is supposed to be promoting general aviation, not publishing
negative articles that are short on facts.
Jim B. Belcher
BS,MS Physics
A&P/IA
General Radio Telephone Certificate
Instrument Rated Pilot
Retired Aerospace Technical Manager
601XL Builder
robert watson
Posted: Fri Jan 29, 2010 3:24 pm Post subject: Re: Recommended Letter-writing campaign, follow-up |
Mr Belcher you ask everyone to write to AOPA expressing their concerns as to their article regarding the Zenith 601XL. particuarly in relation to the " misinformation "
Before anyone does this, may I suggest that you check and research your own article as it is full of misinformation!.
Over and above your inaccurate article I am attonished that you seem to imply that this aircraft is as safe as any other type.
You accept that it has had its fair share of accidents -but many aircraft have accidents - but it is almost unheard of in modern times for an aircraft to lose its wings.
Of coarse you may say that these accidents are due to poor Pilot handling does that mean that only pilots of inferior ability are attracted to 601xl,s? -and the many other experimental types available attract the sensible pilots, I do not see any of them loseing their wings!!.
I am a owner/builder /Pilot of a 601xl currently self grounded till Mod complete.
sabrina
Posted: Fri Jan 29, 2010 6:23 pm Post subject: Re: Recommended Letter-writing campaign, follow-up |
Posted: Sat Jan 30, 2010 7:34 am Post subject: Recommended Letter-writing campaign, follow-up |
I suspect our perspectives differ too greatly for an exchange of ideas to have
much of a positive result. As you appear to feel strongly about your position,
in the spirit of freedom of speech, I respectfully suggest you communicate it
to the AOPA.
On Friday 29 January 2010 17:24:05 you wrote:
<robert.warson12(at)tiscali.co.uk>
the " misinformation " Before anyone does this, may I suggest that you
complete.
Jim B. Belcher
BS,MS Physics
A&P/IA
601XL Builder
carlossa52(at)gmail.com Guest
Posted: Sat Jan 30, 2010 8:05 am Post subject: Recommended Letter-writing campaign, follow-up |
.and this, folks, is how one stops a flame-throwing war.
A rare skill indeed.
Carlos
CH601-HD, plans
On 30 January 2010 10:34, Jim Belcher <z601c(at)anemicaardvark.com (z601c(at)anemicaardvark.com)> wrote:
[quote]--> Zenith-List message posted by: Jim Belcher <z601c(at)anemicaardvark.com (z601c(at)anemicaardvark.com)>
to the AOPA.
goodings(at)yorku.ca Guest
Posted: Sat Jan 30, 2010 9:08 am Post subject: Recommended Letter-writing campaign, follow-up |
Personally, I thought that Mr. Belcher's letter was well-written, helpful,
low-key, and exhibited good common sense.
John Goodings, C-FGPJ, CH601HD with R912S, Carp/Ottawa/Toronto.
vayuwings
Posted: Thu Feb 04, 2010 1:30 pm Post subject: Re: Recommended Letter-writing campaign, follow-up |
Well said, accurate and reasonable, Jim. I'll send one to AOPA also. Their article to me was simply not researched well and sources not checked.
Dave Miller
601X2 O-200
waiting on the upgrade pkg
Posted: Thu Feb 04, 2010 1:53 pm Post subject: Recommended Letter-writing campaign, follow-up |
On Thursday 04 February 2010 15:30:56 you wrote:
Dave Miller
601X2 O-200
Thanks, Dave! I believe it's important for those who feel that AOPA was
somewhat less than objective in their reporting to say so - even if they don't
happen to agree with my views.
Jim B. Belcher
BS,MS Physics
A&P/IA
601XL Builder
sabrina
Posted: Thu Feb 04, 2010 2:16 pm Post subject: Re: Recommended Letter-writing campaign, follow-up |
psm(at)att.net Guest
Posted: Thu Feb 04, 2010 4:13 pm Post subject: Recommended Letter-writing campaign, follow-up |
Hi Sabrina,
I am optimistic the current changes for the Zodiac XL will work just fine.
We should see elimination of the unexplained structure failures or at least
a huge reduction in the rate of failures.
I should be entering Phase I flight testing on my Zodiac this Spring. I
expect to spend the Summer completing the test program. After that I will
review the state of affairs regarding in-flight failures and decide whether
or not to go into phase II.
If, indeed, the accidents continue through this year I will turn my XL into
a flower planter for my front yard and move all the expensive parts to my
current project - a scratch built Wittman Buttercup.
Paul
Camas, WA
Awaiting delivery of upgrade kit.
There had to be a reason for those 10mm doublers... maybe if others ask, the
ASF/Piper will help us just in case the Zenith upgrade does not work out as
planned...
Juan Vega Jr
Posted: Sat Feb 06, 2010 8:03 am Post subject: Recommended Letter-writing campaign, follow-up |
There is a great article on the taining with regard to the MU -2 accidents years back. every one looked at the plane, yet when training went up, accidents went down. I believe this will be a perfect example of the 601's situation, light sport pilots and pilots transitioning to a lighter wing load, need to be trained to fly a very light wing loaded aircraft. They are currently focusing their ire on an aircraft that is now "overbuilt". If accidents continue to some extent, maybe they will finally focus on the needed items, pilot awareness, and good building practices. Only then will this very well designed, overbuilt aircraft find some peace.
Juan
jmaynard
Joined: 27 Feb 2008 Posts: 394 Location: Fairmont, MN (FRM)
Posted: Sat Feb 06, 2010 8:19 am Post subject: Recommended Letter-writing campaign, follow-up |
On Sat, Feb 06, 2010 at 11:01:01AM -0500, Juan Vega wrote:
| Quote: | There is a great article on the taining with regard to the MU -2
find some peace.
If you keep wading in denial, the crodociles will get you.
By now, the only people denying ther'es a problem are pilots like you who
can't understand that it is indeed possible for an aircraft to have design
flaws.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
sabrina
Posted: Sat Feb 06, 2010 10:04 am Post subject: Re: Recommended Letter-writing campaign, follow-up |
dwilde(at)clearwire.net Guest
Posted: Sat Feb 06, 2010 10:51 am Post subject: Recommended Letter-writing campaign, follow-up |
Sabrina wrote:
Trained, even over trained on this issue, might be a good thing.
I just read an article in a recent EAA newsletter that may pertain to
this issue. The study found that the less you know about something, the
more you think you know. The article was relating to UL pilots who
would take just enough training to learn how to land and then stop
taking lessons because they felt they knew enough to fly on their own.
As a former UL pilot I saw this attitude more than once and also saw the
tragic results.
Knowledge and training are good things and not to be avoided.
Dan Wilde
Juan Vega Jr
Posted: Sat Feb 06, 2010 11:56 am Post subject: Recommended Letter-writing campaign, follow-up |
SAbrina and all,
Don't missenterpret what I say, what I said was people need to get used to a lite wing load plane, NOT "Juan's concern with the pitch sensitivity", , that is dispositive of the issue. Any aircraft that has a cruise of 138 mph and a manauvering speed of 103 mph needs to be treated and flown with a sense of complete mental awareness. And trainig needs to be constant. Case and point, when I brought up the manuavering speed a year ago, peoples' response was " manuavering speed? whats that?" The plane is safe, if flown properly within specs, and built correctly, that is what I said, and over time when the mods are done, this statement will be less ignored and not as debated.
before you email me some opinion, read the MU-2 articles and the articles on training equals safe pilot.
Juan
Juan Vega Jr
Posted: Sat Feb 06, 2010 12:00 pm Post subject: Recommended Letter-writing campaign, follow-up |
Tron Boy, show me on the tests conducted where the flaw is on the aircraft.
Juan
jmaynard
Posted: Sat Feb 06, 2010 12:46 pm Post subject: Recommended Letter-writing campaign, follow-up |
On Sat, Feb 06, 2010 at 02:56:16PM -0500, Juan Vega wrote:
| Quote: | Tron Boy, show me on the tests conducted where the flaw is on the aircraft.
The FAA cited structural strength deficiencies when it issued its grounding
order.
jmaynard
Posted: Sat Feb 06, 2010 12:51 pm Post subject: Recommended Letter-writing campaign, follow-up |
On Sat, Feb 06, 2010 at 10:04:24AM -0800, Sabrina wrote:
| Quote: | I think Juan is worried, as am I, that the upgrade did not address the
airframe's unique sensitivity during max gross weight, max aft CG
loadings.
Juan's been denying there's a problem with the airframe from the very
beginning. He hasn't changed his tune at all.
| Quote: | I am lucky enough to have been trained by a skilled 601XL pilot, someone
who knows the airplane like the back of their hand, someone who has the
ability to impart that knowledge onto their student in an effective
way--many other pilots are not so lucky.
Thank you, Sabrina. I do appreciate that.
I certainly won't disagree that training on the Zodiac's peculiarities is a
good thing. Any pilot transitioning to a new type should get a complete,
thorough checkout from an instructor familiar with the type. That's just
good safe flying, be it a Zodiac, another LSA, or another airplane entirely.
I just don't think that the problems are completely addressed by calling
them lack of training. If it were, then either Zodiac pilots are getting
less training than pilots of other LSAs, or else the training is less
effective - and both are less likely than there being a problem with the
aircraft design itself.
rpf(at)wi.rr.com Guest
Posted: Sat Feb 06, 2010 3:11 pm Post subject: Recommended Letter-writing campaign, follow-up |
"Tron Boy" now that's funny...
Jay, there are a number of people who don't think there is anything wrong
with the plane, if it's flown properly, including Chris Heintz.
Randy
Posted: Sat Feb 06, 2010 3:30 pm Post subject: Recommended Letter-writing campaign, follow-up |
Hi Randy,
What you say is true. It is also true that a number of people believe there is a design flaw. That includes minor players like Jay and myself, the NTSB, and the FAA. Alas, this is not a question where the majority rules.
I think this kind of problem is very difficult to understand. It is a latent flaw that doesn't show up except under very unusual circumstances. The airframe passes static and ground vibration tests, but still the wings come off in flight. While some of the failures are easy to explain away (like the one where the newly minted Sport Pilot decided to take off in hard IMC), I find it impossible to believe there is no weakness that causes this to be the only LSA - indeed the only light plane of any type - where the structure fails so often.
It is even worse because nobody can point their finger at the exact flaw. There have been several full NTSB investigations and yet no smoking gun was found.
The only consistency in the failures is they all seem to fail at the same general place - the place where the wings and fuselage come together.
The upgrade beefs up this area of the design along with doing the things the NTSB asked for a year ago. I am truly optimistic, but not convinced, that once the planes are upgraded the failures will go away. If so I will enjoy my Zodiac as much as possible. If not, I will scrap it. My life and especially the lives of my passengers deserve more than a plane with a fatal design flaw.
Paul
XL awaiting upgrade kit.
