Goodone
Posted: Sun Jan 31, 2010 11:03 am Post subject: HOSE FOR ROTAX 912 |
With spring somewhere in the future (I hope) I am thinking of replacing the hoses on my Rotax 912. The oil hose is almost 8 years old and the fuel hose about 4 years old. I burn auto gas containing alcohol and wanted some advice from folks on what fuel and oil hose to use.
JOE RONCO
Joined: 04 Aug 2007 Posts: 31 Location: CENTENNIAL COLORADO
Posted: Sun Jan 31, 2010 11:52 am Post subject: HOSE FOR ROTAX 912 |
You should consider SAE30R7 for low pressure especially for gasohol. If the
fuel is pressurized then SAE30R9 is recommended. These can also be used for
oil I believe. See attached Goodyear cut sheets.
Hope this helps.
Joe R
 Download |
| Filename: |
GOODYEAR_SAE_30R7.doc |
98.5 KB |
| Downloaded: |
740 Time(s) |
 Download |
| Filename: |
GOODYEAR_SAE_30R9.doc |
106 KB |
| Downloaded: |
681 Time(s) |
lgold(at)quantum-associat Guest
Posted: Sun Jan 31, 2010 12:46 pm Post subject: HOSE FOR ROTAX 912 |
JOE,
These Goodyear hoses are all English sizes and are not metric. Do you see
any problems trying to fit them to a Rotax engine??
Les
JOE RONCO
rickofudall
Posted: Sun Jan 31, 2010 4:34 pm Post subject: HOSE FOR ROTAX 912 |
Why don't you go to a Chevy dealer and see what they're using for fuel line in the Flex fuel cars? If it will stand up to E 85 in the engine compartment of a car it should work fine in a plane. As for metric conversion there's most likely something close enough to work just fine even though it's measured in inches.
Rick Girard
On Sun, Jan 31, 2010 at 3:46 PM, Joe Ronco <joe(at)halzel.com (joe(at)halzel.com)> wrote:
[quote] --> RotaxEngines-List message posted by: "Joe Ronco" <joe(at)halzel.com (joe(at)halzel.com)>
LES: I don't know how they would fit as I have not used this hose. I just
did some research on material compatibility with gasohol and found the
SAE/Goodyear products. I guess it would depend if you are pushing the hose
over a barb and using a clamp or have a threaded hose end fitting. The later
may be available with an English dimension to fit onto the hose and a metric
thread to connect to the engine.
Sorry I can't be of more help with this.
Joe R
PS: Also be careful what material you use for fittings with gasohol. See the
following link for some information on material compatibility with gasohol
(Pages 37 & 3
http://tinyurl.com/yz3d9fm
Dick Maddux
Posted: Mon Feb 01, 2010 4:48 am Post subject: HOSE FOR ROTAX 912 |
I am starting the Rotax 912 course this morning at S Miss Light aircraft. (refresher course- two stroke, last week) I too am in the process of replacing all the water hoses as they are even older than yours. The first ones removed were in pretty good shape. I ended up buying a 2 meter length of 17mm hose from Lockwood ( EXPENSIVE !) . I did not want to stretch available 5/8 heater hose over the nipples although Ronnie,our instructor,says you can do it. I have a thing about the proper parts. The fuel hoses I replaced were the best Gates fuel injection hoses I could find,the oil hoses came from CPS. This water hose replacement is going to be a real pain! Lots of stuff to remove,corrosion to clean,etc but it has to be done.
Dick Maddux
912 UL
Milton,Fl
rickofudall
Posted: Mon Feb 01, 2010 5:53 am Post subject: HOSE FOR ROTAX 912 |
Dick, I used silicone radiator hose from Sport Hoses in the UK when I replumbed my 582.
http://www.sporthoses.com/parts/
[url=http://www.sporthoses.com/parts/][/url]To save weight and money, I only used short lengths of hose and beaded tubes between.
Rick Girard
On Mon, Feb 1, 2010 at 6:47 AM, <Catz631(at)aol.com (Catz631(at)aol.com)> wrote:
[quote] I am starting the Rotax 912 course this morning at S Miss Light aircraft. (refresher course- two stroke, last week) I too am in the process of replacing all the water hoses as they are even older than yours. The first ones removed were in pretty good shape. I ended up buying a 2 meter length of 17mm hose from Lockwood ( EXPENSIVE !) . I did not want to stretch available 5/8 heater hose over the nipples although Ronnie,our instructor,says you can do it. I have a thing about the proper parts. The fuel hoses I replaced were the best Gates fuel injection hoses I could find,the oil hoses came from CPS. This water hose replacement is going to be a real pain! Lots of stuff to remove,corrosion to clean,etc but it has to be done.
Dick Maddux
912 UL
Milton,Fl
ist" target="_blank">http://www.matronics.com/Navigator?RotaxEngines-List
tp://forums.matronics.com
rampil
Posted: Mon Feb 01, 2010 12:02 pm Post subject: Re: HOSE FOR ROTAX 912 |
The standard kit supplied hose was Gates SAE30R7 hose. The R9
is hose with better specs for pressure and generally high endurance in
an engine compartment. FWF I am using stainless braided R9 hose, actually back to the tank selector valve, and further back, just uncovered R9. The stainless braided hose is also covered with firesleeve.
The kit was supplied with 5/16" and 1/4" hose, not metric, at least not in my kit. Diameter adjustment is via hose clamp!
For oil lines I have switched to Aeroquip blue socketless hose, it has
superior specs to the R9.
Dick Maddux
Posted: Tue Feb 02, 2010 3:57 am Post subject: HOSE FOR ROTAX 912 |
Ira,
That is the correct sizes for the fuel hoses but not the water coolant hoses,they are 17 mm.
I also went with the blue oil hose(from CPS)
Dick Maddux
Milton,Fl
rampil
Posted: Tue Feb 02, 2010 7:04 am Post subject: Re: HOSE FOR ROTAX 912 |
Hi Dick,
You are absolutely correct, the coolant hose is 17 mm and should be
available from any hose shop.
I bought mine locally and just had to tell the clerk that it was for a marine
inboard engine since they don't sell to aircraft! Same deal when I had
to originally buy inner tubes for the nose gear - the local tire shops will
only sell the tubes if they are for a go-kart, not an aircraft!
Ira
Goodone
Posted: Wed Feb 03, 2010 9:11 am Post subject: Re: HOSE FOR ROTAX 912 |
I have just be told of a fuel line hose called Barricade Fuel Hose. This is supposed to be a new product (at NAPA anyway) made by Gates and safe for use with fuel containing alcohol. Evidently it costs less than $2 per foot. Anyone using it?
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Wed Feb 03, 2010 11:29 am Post subject: Re: HOSE FOR ROTAX 912 |
| rampil wrote: | Hi Dick,
Ira |
May I ask what shop that was and where?
I havn't been able to locate 17mm heater hose anywhere in America except for Rotax dealers, so naturally I'm highly interested in where you obtained it?...
LS
_________________ LS
Titan II SS |
Goodone
Posted: Wed Feb 03, 2010 12:47 pm Post subject: Re: HOSE FOR ROTAX 912 |
Please note that I am talking about fuel line. I was told that the product is new and that NAPA stores are stalking it.
Float Flyr
Posted: Wed Feb 03, 2010 4:05 pm Post subject: HOSE FOR ROTAX 912 |
Anything using a synthetic butyrate rubber should be ok.
Noel
_________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
Float Flyr
Posted: Wed Feb 03, 2010 4:56 pm Post subject: HOSE FOR ROTAX 912 |
Try any Japanese car dealership or PWC outlet.
Noel
Kitfox III-A
Dick Maddux
Posted: Thu Feb 04, 2010 5:58 am Post subject: HOSE FOR ROTAX 912 |
dealers, so naturally I'm highly interested in where you obtained it?...<
I am also in the process of replacing my hoses but I also could not find any 17mm hose in the US . I finally bit the bullet and paid the money to Lockwood and bought a 6 meter piece.
Today I am going to try and find the formed hose that goes from the spyder to number three cylinder. That little jewell is almost $50 from Rotax. If I can find this formed piece in 5/8 heater at NAPA, then 5/8 it will be.
I was able to find some CT wide band clamps at Grainger. It was about $6 for 10 of them vs $6 a piece at the Rotax dealer. These will replace my old screw type which really chewed up the hoses
I am sure glad I started the hose replacement as they were real bad. This job will certainly take awhile
Dick Maddux
912 UL
Milton,Fl
Goodone
Posted: Thu Feb 04, 2010 11:52 am Post subject: Re: HOSE FOR ROTAX 912 |
From the information I have been reading on this site it seems to me that Barricade Fuel Hose is a good material to use on the 912. Still not sure if there is reasonable alternative to the high cost 13mm oil hose available at aviation supply websites, but hope that there is.
rampil
Posted: Thu Feb 04, 2010 1:06 pm Post subject: Re: HOSE FOR ROTAX 912 |
Barricade is a couple of years old and is promoted as a "green"
product because it has low permeance to fuel vapor. Otherwise
it seems to be the same spec as the standard gate 30R7 hose.
The Gates website did not mention any special resistance to abrasion,
heat, wear, etc. Like other Gates hose it is fine for E10. I don't
think we will be seeing anyone using E85 in aircraft now or in the
future due to the low energy density and the high vapor pressure.
sdemeyer
Posted: Thu Feb 18, 2010 12:57 pm Post subject: Re: HOSE FOR ROTAX 912 |
| Dick Maddux wrote: | >
� � � � � Dick Maddux
� � � � � 912 UL
� � � � � Milton,Fl
Dick, just curious if you were able to find the formed hose. I'm in the same predicament.
Scott
Dick Maddux
Posted: Fri Feb 19, 2010 5:52 am Post subject: HOSE FOR ROTAX 912 |
Scott,
I did find the 5/8 "formed hose, however, I had to insert an internal spring to keep it from collapsing as the bend in the hose was not quite enough. I actually used the spring that was in the old hose. The prior owner had used a straight piece of 5/8 , inserted springs, and bent it to shape. This lasted about 15 years so hopefully it should work for me. I don't know what material the spring was made of.
The NAPA store did tell me that they have hoses that include an internal spring and you can bend them to shape.
I used the old hoses as a pattern for the new hoses. The clearances were quite close to the exhaust pipes on my plane so I wrapped the exhaust pipes with 1' wrap and used ss tie wraps to secure them. They look nice so hopefully it should cut down on the heat on those hoses.
Dick Maddux
Milton,Fl
