RV6 for sale,
rv6160hp(at)aol.com
PostPosted: Tue Feb 02, 2010 5:49 pm    Post subject: RV6 for sale, Reply with quote
Coming to grips that I probably can not afford my baby... this is very difficult ....
but I digress.... I thought it best to start here with my very 1st post ...pdf description attached.
Any sincere interest I can send you more photos, email me at NYFlapjack2(at)aol.com and info ask away...
Barnstormers next place to post an ad and ???? open to suggestions and your insight.
Asking $60,000...and I am not in a hurry...but will be open to reasonable offers too...
May leave in the WX blue tooth receiver, and the 2 Pilot ANR's rechargeable head sets......
To the attached document I can there is 1 error...the plane has (at) 285 hours, the 375 listed is my TT as a pilot, not this plane.
Also that used engine that has never missed a beat since installation & 1st flight, has all the tags, certified rebuild data, yellow tags & receipts. I got it from Wentworth & an insurance salvage from a hanger collapse parked plane, it now has (at) 1785SMOH.
While the plane is not Grand champion Oshkosh material ....this thing goes, runs up with my CS prop 180 RV pals.
And I can give references with EAA Tech Counselor, other RV pilots, RV builders etc....if you want builder opinions.
PDF file attached....If you've been to KFZY at its home base, EAA 486 in Oswego NY at our RV forums you probably have seen this plane.
Regards David McManmon
FJ2_RV6.pdf
 Filename:  FJ2_RV6.pdf
 Filesize:  225.5 KB
 Downloaded:  695 Time(s)
rhdudley1(at)bellsouth.ne
PostPosted: Tue Feb 02, 2010 7:19 pm    Post subject: RV6 for sale, Reply with quote
Hi David,
Just to refer to my experience in selling my 6A a bit over a year ago. I share your pain.
Two good places to advertise after this list are Van's Airforce (which is free) and Barnstormers (which is very reasonable). I had good responses from both but finally sold through Barnstormers. Both have good circulation.Though I subscribed, I did not use TAP. It seemed more cumbersome than the other two.
Your PDF has good photos and description and can be used in either or both VAF or Barnstormers.
Good luck,
Richard Dudley
Charles Heathco
PostPosted: Wed Feb 03, 2010 4:53 am    Post subject: RV6 for sale, Reply with quote
re adv, after I bought my 6a, I waited till early spring to adv my cherokee, got no action from barnstormers an ended up spending some cash on TAP, sold it soon after. Could be dif with selling a vans. Best of luck. Charlie H
