Troy Maynor
Posted: Sat Jan 30, 2010 12:46 pm Post subject: Lifting the Europa |
Hey Guys and Gals,
When folks talk about lifting a Europa by the engine mount are they referring to the mount forward of the lord mounts or aft of the lord mounts? I need to lift my Classic monowheel for maintenance in the garage without the wings on it. I am thinking about having a welded stand with the hydraulic jack added like someone on the forum made for lifting, but the exhaust pipe is in the way on the port side. I need to get the weight off the tire to fiddle with the brace for the landing gear handle mod. It was too stiff laterally as I remember from last I did it. I made too fancy of a brace than the angle stock I had on earlier. That was before the engine was installed and things were easier then. Thoughts, ideas anyone?
Troy Maynor
Monowheel Classic UK120
Passed inspection, first flight soon.
Posted: Sat Jan 30, 2010 1:42 pm Post subject: Lifting the Europa |
If you still have the dummy spar, perhaps you could make/get made a steel tube with the correct spacing to replicate the main spar setup, and jack from there
craig
[quote] --
jrgowing(at)bigpond.net.a Guest
Posted: Sat Jan 30, 2010 10:49 pm Post subject: Lifting the Europa |
craig
I think you could lift from just about any part of the engine mount
At the moment my fuselage is more or less hangine from the propeller boss with a little stabilisation
JR Bob Gowing UK Kit 327 in Oz..
Posted: Sat Jan 30, 2010 11:13 pm Post subject: Lifting the Europa |
I just had concerns about asymetric loading of the mount itself, given the mount is designed for a "tension" load pulling forward under normal
flight conditions, but given it has to support the weight of the engine at 8G ultimate load which is about 600kg depending on engine choice, you
are probably correct.
craig
[quote] --
Posted: Sun Jan 31, 2010 3:53 am Post subject: Lifting the Europa |
YOu have given it more thought than I
JR
stephan(at)scassel.se Guest
Posted: Sun Jan 31, 2010 4:49 am Post subject: Lifting the Europa |
Hi Troy,
Another approach is the "mini dolly":
http://www.scassel.se/europa/dolly1.jpg
http://www.scassel.se/europa/dolly2.jpg (aircraft level)
The dolly is attached on one of the strongest part of the fuselage, i.e. where the cockpit-module, fuselage and firewall are bound together.
It is important to create/mould the support blocks on the fuselage in order to fit perfect.
Between the support block and fuselage is quite hard rubber. Each support block has 5 mm bolt through the fuselage, just in case.
After 5 years of use (also during the finishing of the kit ) the fuselage has not moved a fraction of mm from the dolly.
The dolly should be made with full tank (max load) and a piece of wood 2" under the wheel, see picture otherwise you can not operate the landing gear
properly in level, see pic
You also need a tail wheel support, see pic
I use my "mini-dolly" one every service. Even 50 hours service. I can check flaps/landing gear/outrigger ++ very easy.
Please feel free if you need any offline info.
Best regards
Stephan Cassel
LN-STE 230 hours - third year
fklein(at)orcasonline.com Guest
Posted: Sun Jan 31, 2010 8:51 am Post subject: Lifting the Europa |
On Jan 31, 2010, at 3:58 AM, Stephan Cassel wrote:
Outstanding Stephen !!
Could you please describe your procedure for getting your dolly in place on your XS?
It's not clear to me how you raise the aircraft to get the dolly under it.
Fred
carl(at)flyers.freeserve. Guest
Posted: Sun Jan 31, 2010 11:05 am Post subject: Lifting the Europa |
Safest option is to invest in a hydraulic engine hoist and lift using the engine mounting frame (secure with rope aft of the lord mounts).
I recently purchased one for £125 on Ebay. Sounds expensive but once flying you will need to lift the aircraft every year (fully rigged) for the annual inspection so over the years it will prove to be a worthwhile investment.
Heres one like I bought - I expect they are cheaper in the USA.
http://cgi.ebay.co.uk/1-TON-FOLDING-HYDRAULIC-ENGINE-CRANE-HOIST-LIFT_W0QQitemZ110465901864QQcmdZViewItemQQptZUK_Lifting_Moving_Equipment?hash=item19b847e528
Its folding so can be stored in the corner of the garage.
Anything that relies on jacks needs to be pretty secure or you risk getting squashed.
Rowland_Carson
Joined: 04 Jul 2008 Posts: 155 Location: Cheltenham, England
Posted: Mon Feb 01, 2010 1:13 am Post subject: Lifting the Europa |
At 2010-01-30 15:43 -0500 Troy Maynor wrote:
| Quote: | When folks talk about lifting a Europa by the engine mount are they
mounts
Troy - I'd advise aft of the mounts. This will give a more stable
lifting position and will not stress the mounts unnecessarily. You
can see how we did it last year on Tim Houlihan's G-BZTH in my Picasa
album at:
http://picasaweb.google.com/rowlandcarson/EuropaMiscellaneous
I needed to extend the jib fully to reach aft of the mounts, and some
care was required in choosing the strop attach point to avoid
damaging pipes, wires etc.
regards
Rowland
| <rowil(at)clara.net> http://home.clara.net/rowil/
| pictures: http://picasaweb.google.com/rowlandcarson
klaus.dietrich(at)oracle. Guest
Posted: Mon Feb 01, 2010 2:30 am Post subject: Lifting the Europa |
some years back there was a description in the "Europa Flyer" of a cradle for the Europa; I built it several years ago and it served me well!
With it you can easily change the wheel and operate the flaps etc.
However once the plane is lifted I support it under the wings with two cradles.
http://picasaweb.google.at/kdietric1/EuropaCraddle?authkey=Gv1sRgCLqKkOzD1c9l&feat=directlink
Klaus (OE-CKD)
raimo.toivio(at)rwm.fi Guest
Posted: Mon Feb 01, 2010 3:29 am Post subject: Lifting the Europa |
Like this? This is how I have done it and will do.
I use four lifting straps all capable for +200 kgs.
Notice 1: the wings are supported only just to keep the plane stable sideways, not to take weight.
Notice 2: what more you lift that more you stress the tail wheel (if the tail is not supported /lifted).
Raimo OH-XRT
64.85 KB |
8224 Time(s) |
Troy Maynor
Posted: Sun Feb 07, 2010 6:50 pm Post subject: Lifting the Europa |
Folks,
I just wanted to thank everyone that replied on the above subject. In the short term I used an engine hoist and nylon webbing lashed around the two upper members of the landing gear/engine mount frame that protrude through the firewall. I worked fine. Long term though I want one of the jacks like the one Bob Borger has on his build page. I think I can adapt it for my Classic. Thanks again for this great forum.
Troy
Plane finished, waiting better weather and a bit more stick time for first flight.
