peterz(at)zutrasoft.com Guest
Posted: Tue Jan 26, 2010 9:40 am Post subject: Prop-axis height: Jabiru vs Rotax |
Does the prop sit lower in the fuse on a Jab 3300 installation than on a Rotax? (I suspect soafter a cursory look at the drawings)
If so, by how much?
Thx,
Pete
A239
fklein(at)orcasonline.com Guest
Posted: Tue Jan 26, 2010 10:45 am Post subject: Prop-axis height: Jabiru vs Rotax |
On Jan 26, 2010, at 9:38 AM, Peter Zutrauen wrote:
| Quote: | Does the prop sit lower in the fuse on a Jab 3300 installation than
on a Rotax?
Peter,
I received this from John Wheeler sometime back:
| Quote: | The thrust line on the XS runs parallel to the fuselage datum line,
one and a half (1.5") inches above it.
Is not the fuselage datum line at the door sill? If you study the
attached photo of a Jab installation from Suncoast, it would appear
that the Jab thrust centerline is about the same.
Fred
48.27 KB |
1862 Time(s) |
