aerosport1
Posted: Mon Jan 25, 2010 1:21 pm Post subject: All dressed up |
Finally after 3 months since my first flight I got my gear legs and wheel pants painted and installed. I thought I would share these photos and help
inspire everyone still banging rivets or working on the fiberglass that it is worth every hour. Also included a picture of my panel with my
AFS 4500 SV's.
More photos available at http://combsfamily.phanfare.com
Geoff
121.19 KB |
10935 Time(s) |
107.12 KB |
10935 Time(s) |
_________________ Geoff Combs
RV-10 QB N829GW
Flying 500 hrs
40033
jeff(at)westcottpress.com Guest
Posted: Mon Jan 25, 2010 1:52 pm Post subject: All dressed up |
absolutely beautiful
On Jan 25, 2010, at 1:21 PM, aerosport1 wrote:
Posted: Mon Jan 25, 2010 7:40 pm Post subject: All dressed up |
Beautiful job and great design.
Do Not Arhcive
[quote] Subject: All dressed up
Date: Mon C 25 Jan 2010 13:21:43 -0800
Jim Combs
Joined: 24 Jan 2010 Posts: 141 Location: Lexington, Ky
Posted: Tue Jan 26, 2010 4:26 am Post subject: All dressed up |
Geoff,
VERY NICE!
Jim Combs (N312F)
On Mon, Jan 25, 2010 at 4:21 PM, aerosport1 <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)> wrote:
[quote]--> RV10-List message posted by: "aerosport1" <g.combs(at)aerosportmodeling.com (g.combs(at)aerosportmodeling.com)>
AFS 4500 SV's.
More photos available at http://combsfamily.phanpare.com
Geoff
Geoff Combs
RV-10 QB N829GW
Flying
40033
http://forums.matronics.com/viewtopic.php?p=283424#283424
http://forums.matronics.com//files/img_0337_283.jpg
http://forums.matronics.com//files/img_0325_153.jpg
le, List Admin.
_________________ RV-10 -> N312F - Flying as of 12/2008 |
MauleDriver(at)nc.rr.com Guest
Posted: Tue Jan 26, 2010 5:11 am Post subject: All dressed up |
Definitely inspired here - Really nice!
Bill "finishing up a morning session in the shop" Watson
aerosport1 wrote:
AFS 4500 SV's.
Geoff
Geoff Combs
RV-10 QB N829GW
Flying
40033
coop85(at)verizon.net Guest
Posted: Tue Jan 26, 2010 9:15 am Post subject: All dressed up |
Absolutely gorgeous!!! Well done Geoff!
Marcus
40286
msausen
Joined: 25 Oct 2007 Posts: 559 Location: Appleton, WI USA
partner14
Posted: Tue Jan 26, 2010 10:25 am Post subject: All dressed up |
All I can say about your 10 is "NICE JOB". All I can say about my plane is "it flies". What I was told was that at altitude they'll look identical!
Great job Geoff!
Don McDonald
--- On Mon, 1/25/10, aerosport1 <g.combs(at)aerosportmodeling.com> wrote:
40636 |
jcumins(at)jcis.net Guest
Posted: Tue Jan 26, 2010 11:29 am Post subject: All dressed up |
Don
Don’t think you did not do a nice job on yours. Yours is as nice as a lot of them out there you should be very proud how it turned out.
Just my 2 cents.
John G. Cumins
President
JC'S Interactive Systems
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Your Total Technology Solution Provider
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Don McDonald
Sent: Tuesday, January 26, 2010 10:25 AM
Subject: Re: All dressed up
Great job Geoff!
Don McDonald
partner14
Posted: Tue Jan 26, 2010 7:22 pm Post subject: All dressed up |
Thanks John.... of course I'm proud. In some areas I am just REALLY proud, and then in some others, just content.
Don
--- On Tue, 1/26/10, John Cumins <jcumins(at)jcis.net> wrote:
Subject: RE: All dressed up
Date: Tuesday, January 26, 2010, 11:23 AM
Don
Just my 2 cents.
John G. Cumins
President
2499 B1 Martin Rd
Fairfield Ca 94533
707-425-7100
707-425-7576 Fax
Great job Geoff!
Don McDonald
get=_blank rel=nofollow>http://www.matronics.com/Navigator?RV10-List
=nofollow>http://forums.matronics.com
blank rel=nofollow>http://www.matronics.com/contribution
40636 |
robin1(at)mrmoisture.com Guest
Posted: Tue Jan 26, 2010 8:56 pm Post subject: All dressed up |
Geoff, I was particularly fascinated by this shot in your album. Because the leg fairings are not on you can visualize what the -10 would look like as a retract, or just in flight, straight & level at 12,500’, maybe a little XM music in the background. Beautiful work on the 9GW. Looks better than certified to me.
Robin
http://combsfamily.phanfare.com/3161550_4830915#imageID=84783324
83.37 KB |
10807 Time(s) |
John Kirkland
Joined: 13 Jan 2006 Posts: 19 Location: South Weber, UT
Posted: Thu Jan 28, 2010 9:23 am Post subject: Re: All dressed up |
Geoff,
What stick grips are those?
DO NOT ARCHIVE
_________________ RV-10 #40333
N540XP (reserved) |
aerosport1
Posted: Thu Jan 28, 2010 9:49 am Post subject: All dressed up |
John those are the infinity grips
Geoff
Sent from my iPhone Geoff
On Jan 28, 2010, at 12:23 PM, "John Kirkland" <jskirkland(at)webpipe.net>
RV-10 QB N829GW
Flying 500 hrs
40033 |
rene(at)felker.com Guest
Posted: Thu Jan 28, 2010 10:31 am Post subject: All dressed up |
John, that is what I have in mine and Scott also. Scott has some pictures
on his site on what you need to do with the stick to make it fit. Next time
we run into each other out at the airport, you can do the check it out
thing. My annual is due in March and I will have the airplane apart
then......
Rene
801-721-6080
Posted: Thu Jan 28, 2010 5:40 pm Post subject: All dressed up |
You may want to take a look at what Robin Marks posted (with photos)
under this subject line:
RE: Elevator travel vs. stick grip clearance
A hydraulic press was used. I took the same route and it seems to have
worked great. No cutting required. Thanks Robin!
You may also want to check out the Tosten/CH stick here:
http://tostenmanufacturing.com/catalog/aircraft-grips/cs-8-aircraft-grip.html
I liked the Infinity but it had 1 or 2 more switches more than I
wanted. I checked out the Tosten and liked it a bit more. The photo on
the site gives the impression that it may looks a bit 'chintzy' with
center seam and all. But in fact it has a quite nice look and feel. A
bit more subdued than the Infinity but equally robust. Enough buttons
for everything plus 1 in my thinking. It appears that the grip can be
mounted so that it freely rotates while firmly mounted (Think about
switching hands on a 'handed' molded grip). Anyway, I have it, I've
shortened the stick and wired it up. Haven't flown it yet.
Bill "90% done, 90% to go" Watson
then......
Rene
801-721-6080
nukeflyboy
Joined: 05 Jan 2008 Posts: 162 Location: Granbury, TX
Posted: Sun Jan 31, 2010 7:06 pm Post subject: Re: All dressed up |
Beautiful job Geoff! Thanks for the inspiration.
(Back to the fiberglass ........)
_________________ Dave Moore
RV-6 built and sold
RV-10 built and flying |
