Finger Brakes
david steade
PostPosted: Mon Jan 25, 2010 9:08 am    Post subject: Finger Brakes Reply with quote
Hi
I'm a bit more advanced with my finger brake problem now but what has come up is the quality of the original Jamar part and its suitability for the Europa particularly if silicone based brake fluid has to be used.
It seems some owners have changed the Jamar products to modified toe brake cylinders and then used standard red brake fluid.
Any information on this subject would be helpful.
David Steade
David Steade
riddon(at)sent.com
PostPosted: Mon Jan 25, 2010 10:45 am    Post subject: Finger Brakes Reply with quote
I had endless problems with my Jaymar cylinders, problems bleeding air, sticking pistons etc. and eventually threw them away and replaced them with a pair of Matco ones from the factory. I used the standard red brake fluid in them and haven’t had any problems since. Would not recommend using the Jaymar based on my experience.
Richard Iddon. G-RIXS
-----Original Message-----
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Steade
Sent: 25 January 2010 16:22
Subject: Europa-List: Finger Brakes
Hi
David Steade
Checked by AVG - www.avg.com
07:36:00
jimpuglise(at)comcast.net
PostPosted: Mon Jan 25, 2010 11:07 am    Post subject: Finger Brakes Reply with quote
David-
I am in the build stage yet so have not yet selected a fluid. I hope you disassembled and cleaned the inside of the cylinders and the hole that goes through the middle. I disasssembled mine and found all sorts of crap in it before cleaning. There is an allen screw in each side. Remove them and pass a wire through it. You should be able to see from one side to the other.
Jim Puglise A-283
Jeff(at)rmmm.net
PostPosted: Mon Jan 25, 2010 11:31 am    Post subject: Finger Brakes Reply with quote
Guy's,Unless you want to spend extra money I would do as others have done. Take the Jaymar cylinders completely apart. Get some carb or choke cleaner and a small soft round brush and clean all the crap out of them, put them back together and they'll work fine. It seems there was a bad batch of these. There was a thread on this a few years back, but as soon as I cleaned mine they have been working perfectly ever since. I used a matco emergency brake also with the dot 5 and it works great. The small bleeder screws leaked a bit letting air in the system but a little gasket seal on the threads fixed that. Working great for 3 years now.
Jeff R. N128LJ Gold Rush
On Jan 25, 2010, at 12:43 PM, Richard Iddon wrote:
[quote]I had endless problems with my Jaymar cylinders, problems bleeding air, sticking pistons etc. and eventually threw them away and replaced them with a pair of Matco ones from the factory. I used the standard red brake fluid in them and haven’t had any problems since. Would not recommend using the Jaymar based on my experience.
gholland(at)content-strea
PostPosted: Mon Jan 25, 2010 11:50 am    Post subject: Finger Brakes Reply with quote
David Hi!
I fitted the original Matco Foot Brake cylinders to Trigear G-FIZY I built. I fabricated a bracket, ensured there was a removable panel above the bleed screws and it worked well. My only recommendation would be to ensure levers are long enough, probably about 9” but just as important is to ensure knob or handle ends are big enough for a good grip or action. There was a requirement to ensure correct rubber seals were used for different brake fluids. I used the ‘red’ Dot 5....I think! Europa supplied the rubbers. Photos attached. The Brake Levers in photo proved too short (action difficult) so were extended by about 4”.
Gerry
Gerry Holland
07808 402404
[url=gholland(at)content-stream.co.uk]gholland(at)content-stream.co.uk[/url]
Based at White Ox Mead, Near Bath
[img]cid:3347293613_6445232[/img]
 Filesize:  20.27 KB
 Viewed:  7346 Time(s)
 Filesize:  234.42 KB
 Filesize:  249.21 KB
PostPosted: Mon Jan 25, 2010 11:54 am    Post subject: Finger Brakes Reply with quote
David Hi!
Gerry
Gerry Holland
07808 402404
[img]cid:3347293843_6463606[/img]
 Filesize:  20.27 KB
 Viewed:  7340 Time(s)
 Filesize:  234.42 KB
 Filesize:  249.21 KB
PostPosted: Mon Jan 25, 2010 12:09 pm    Post subject: Finger Brakes Reply with quote
Sorry to everyone for receiving an earlier message 3 times!
The List rejected twice so I resent twice....Doh!
Again Sorry!
Gerry
Do not archive [quote][b]
craigb(at)onthenet.com.au
PostPosted: Mon Jan 25, 2010 5:45 pm    Post subject: Finger Brakes Reply with quote
gerry,
is that a parking brake valve you have there, mounted next to the cylinders, if so would you mind sharing the source,
Like you i used the matco cylinders and the original mounts inverted and mounted in the tunnel. I then added another bracket
to either side to take the throttle and IFA levers.
craig
duanefamly(at)aol.com
PostPosted: Mon Jan 25, 2010 6:16 pm    Post subject: Finger Brakes Reply with quote
Craig,
Check out AC Spruce.
http://www.aircraftspruce.com/catalog/lgpages/matcoPBVALVE.php
This has been used by many.
Mike Duane
Redding, CA
XS Conventional Gear
Jab3300
PostPosted: Mon Jan 25, 2010 9:29 pm    Post subject: Finger Brakes Reply with quote
Craig Hi!
That is a Parking Brake fitted beside the two Brake Levers.
The idea was to allow one handed ON or Off operation. When the levers were short it worked OK but once they were extended the reach required from one hand didn’t allow it. The Park Brake Unit was a 06-17200-MATCO BRAKE PARKING VALVE-$113.95 from Aircraft Spruce.
The Hand operated Brakes take a little getting used to initially but after a short time it works out. The brake discs seem to need to be worn in pretty well as well.
After that you can establish safe taxi speed and use the rudder for many fine adjustments in direction.
Gerry
PostPosted: Wed Jan 27, 2010 2:31 am    Post subject: Finger Brakes Reply with quote
thanks for that Gerry
