Material for Instrument Panel
david steade
PostPosted: Sun Jan 24, 2010 3:41 pm    Post subject: Material for Instrument Panel Reply with quote
I'm just about ready to order the material for the sub panels to carry the instruments in the panel molding. Any guidance on material specification and thickness would be helpful
David
David Steade
topglock(at)cox.net
PostPosted: Sun Jan 24, 2010 3:52 pm    Post subject: Material for Instrument Panel Reply with quote
My panel is built from .063" aluminum. Very ridged and light weight.
Available at sign suppliers.
Jeff - Baby Blue
David
Checked by AVG - www.avg.com
houlihan(at)blueyonder.co
PostPosted: Mon Jan 25, 2010 1:45 am    Post subject: Material for Instrument Panel Reply with quote
Don't forget that pre shaped panels are available on the Europa factory
web site.
Richard Wheelwright
PostPosted: Mon Jan 25, 2010 3:53 am    Post subject: Re: Material for Instrument Panel Reply with quote
What about Carbon fiber sheeting. You will have a ready made finish if you like the carbon fiber look.
Richard Wheelwright
DanBish
PostPosted: Mon Jan 25, 2010 7:26 am    Post subject: Re: Material for Instrument Panel Reply with quote
This might not help if you're in the UK, but for US or Canadian builders it might be helpful.
I got my aluminum sheet at
http://www.onlinemetals.com/merchant.cfm?id=239&step=2&top_cat=60
I plan to cover it in the carbon fiber vinyl wrap material, forget what it's called but it gives a CF look and comes in lots of colors.
Dan
bmoorhouse
PostPosted: Tue Jan 26, 2010 1:34 am    Post subject: Re: Material for Instrument Panel Reply with quote
Richard Wheelwright
Mine is carbon fibre sheet - as a "sub panel" that holds all the instruments and can be removed without taking the whole panel assembly off. Looks very good with its almost holographic weave effect, is very light and very strong. Also have carbon fibre sheet on the panel cover between the seats (I do not have finger brakes).
I would recommend it if you can get some with a good polished finish.
Carbon Fibre sub-panel
 Filesize:  12.51 KB
 Viewed:  18562 Time(s)
Carbon fibre sub-panel
 Filesize:  10.9 KB
 Viewed:  18560 Time(s)
_______________
Barry Moorhouse
G-JHYS Trigear XS
Rotax 914 UL
david steade
PostPosted: Tue Jan 26, 2010 7:26 am    Post subject: Material for Instrument Panel Reply with quote
Hi
Thanks for all the information regarding the instrument panel and brake fluid. Not finally made my mind up which way to go yet but a least I am better informed.
David Steade
David Steade
