Z-13/20 questions
jonlaury
PostPosted: Wed Jan 20, 2010 10:53 am    Post subject: Z-13/20 questions Reply with quote
I've decided that Z13/20 works best for my all electric ship and I have a couple of questions:
For aesthetic and robustness reasons, I'm married to the Honeywell AML 34 15A switches. But they only come in DPST.
So for the Ebus-Alt and Master Power switches, could I use one pole for the respective VR Bus terminal and one for the respective contactor? I see the reason for the DPDT switch in the drawing is to allow shutting down the respective alternator without disconnecting the respective bus from the remaining alternator. But couldn't that be accomplished by placing the Alt Field breaker between the DPST switch and the VR to use as a 'switch' to shutdown the offending alternator without opening the respective contactor?
In the drawing, why is the VR bus circuit both fuselinked AND CB'd?
Why fuselink the battery bus-Ebus wire if it's (*) 6" or less?
PostPosted: Wed Jan 20, 2010 2:37 pm    Post subject: Z-13/20 questions Reply with quote
We've had a number of conversations about Z-13/20
since it was first conceived and published. About
two years ago I confessed that it wasn't a good
idea and pulled it from the suite of drawings offered
on the website and the book.
It's my recommendation you consider Z-13/8 as the
lightest, simplest, and least expensive approach
to a highly failure tolerant system for light
aircraft. If you MUST go with the SD20 alternator,
then some variant on full-up, dual systems with
crossfeed is recommended.
Switching philosophy is a personal choice. Suggestions
made in the Z-figures are the product of 20+ years
of sifting simple ideas to meet design goals.
I'm not suggesting that the Z-figures are "golden",
only that they satisfied the design goals. If your
goal is to use the AML switches, you can add more
switches and give up the convenience and operational
safeguards offered by the two pole, progressive
transfer devices . . . or have the AML operate relay(s)
as needed to keep the functionality. Finally,
as you've suggested, you can start shuffling things
around . . . but it's no longer a Z-figure.
jonlaury
PostPosted: Wed Jan 20, 2010 8:54 pm    Post subject: Re: Z-13/20 questions Reply with quote
Arrgh, Bob.
After all my rumination to decide and you say "by the way that system sucks"? You're killing me!('Smile')
As you probably gathered from the Silicone Goo post, I already have the aux alternator. It's 40 amps, same basic unit as B&C. It's overkill but the penalty is just 1.5 #'s and I do need some of the capacity.
I'm choosing Z-13 over Z-19 for 6#'s less weight and unlimited electrical endurance at the expense of marginally less reliability than 2 batteries.
But I don't see an advantage to a cross-feed contactor in Z-13, or where it would go. It seems that Z-13 has everything that I would need. What did you have in mind?
I still don't understand the thinking of having a fuselink and fuse/CB on the same circuit ala the battery bus to e bus run. Otherwise I feel that Z-13/8(40) and I will get along fine.
PostPosted: Thu Jan 21, 2010 5:49 am    Post subject: Z-13/20 questions Reply with quote
At 10:54 PM 1/20/2010, you wrote:
Arrgh, Bob.
Sorry 'bout that . . . but it was not well thought
out. Shouldn't have published it without more thought.
than 2 batteries.
Only completely independent systems have/need
cross-feed capability. If you have the ability
to drive two alternators and get rated output
from them and your second alternator is hefty,
then perhaps Z-14 is a better bet with two smaller
batteries.
The only instance I recall using a fusible link in series
with a breaker is on systems that feature fuse blocks AND
crowbar OV protection. The only circuit protection on the
panel is the 5A breaker made necessary by the crowbar ov
system EXTENSION of the fuse bus up to the breaker calls
for ROBUST circuit protection that won't open when the breaker
trips.
Where do you see a fusible link, fuse and cb on the same
line in my drawings?
PostPosted: Thu Jan 21, 2010 8:15 am    Post subject: Re: Z-13/20 questions Reply with quote
John,
Here are some more AML rocker switches if you are interested:
http://tinyurl.com/yzesmjo
And the data sheet:
http://content.honeywell.com/sensing/prodinfo/manual/catalog/c30030.pdf
Joe
Joe Gores
jonlaury
PostPosted: Thu Jan 21, 2010 9:20 am    Post subject: Re: Z-13/20 questions Reply with quote
With silicone goo all over the 2nd alternator, 2 smaller batteries never crossed my mind. Looking forward to exploring that.
Re fuselinks and fuses/cb's on same line, the Z-13/8 version that I have shows that condition on the battery bus feed to the E-bus alt feed switch to the Ebus.
Joe,
Thanks for the links. I'd looked at the AML 24 series , but dismissed them because the contact rating is for just 2 amps resistive (at) 24vdc.
http://sensing.honeywell.com/index.cfm/ci_id/141354/la_id/1/document/1/re_id/0
I'm not sure if this matters for operating contactors, or some of the other circuits in the Z architectures. I thought that I would have more flexibility with higher amp rated switches at the expense of an extra switch or two, because of single throw limitation.
flyboybob1(at)gmail.com
PostPosted: Fri Jan 22, 2010 3:19 pm    Post subject: Z-13/20 questions Reply with quote
You wrote regarding Z13/20: "Shouldn't have published it"
I too had made the decision to use multiple alternators based on my
electrically depandent engine, I also have a design goal of no single point
of failure in the electrical system, so I decided on a light weight version
of Z14 for basic power distribution and an overlay of Z13 for main-bus and
E-bus. I like Z13 for it's simplicity of operation, and Z14 for it's
indepandant power supply. I submitted a wiring diagram that you stated you
were "praying over" a while back. Seems like I have fallen into an area
similar to John <jonlaury(at)impulse.net> so I thought I would probe you again.
In your last post regarding my inquiry you said to use Z9 which seemed to
address other issues. I figured you were just busy with moving so I didn't
pursue the issue at the time. Since John has asked a very similar question,
perhaps you could give us your opinion of using Z14 for battery bus, starter
and alternator, and then a main-bus and e-bus from there as with Z13. I
like this appriach because the inflight troubleshooting is eliminated.
Using a low voltage checklist you can get to stable operation in a few
seconds after a low voltage envent is detected on either battery bus. You
can see my wiring diagram at: http://kr.flyboybob.com/kr2/wd0004.htm.
Thanks for all you do to help us understand what trade offs we play in
making our electrical decisions.
Bob Lee
N52BL KR2
Suwanee, GA USA
92% done only 67% to go!
PostPosted: Sat Jan 23, 2010 8:34 pm    Post subject: Re: Z-13/20 questions Reply with quote
http://kr.flyboybob.com/kr2/wd0004_files/wd0004_frames.htm
Bob Lee,
The fuel injector relay is missing a wire on the common contact.
There are two current paths between Battery Bus 2 and the Endurance Bus, one through a diode and one through a 10 amp fuse. Since the second path through the fuse does not have a diode in it, current from Battery Bus 1 can flow to Battery Bus 2.
The ground power relay coil needs to have a diode in series with it to protect against reverse polarity. What is the purpose of the 5 amp breaker with two wires going to the ground power plug?
As drawn, the "Cross Contactor" is energized, but the indicator light is off. Did you intend that terminal 3 of the Cross Contactor Switch be grounded?
I suggest that the top half of the "Cross Contactor" switch control the ground side of the fuel injector relay coil instead of the hot side, thus minimizing hot wires inside of the cockpit. Of course that change would require changing the indicator light circuit too.
Joe
Joe Gores
PostPosted: Sun Jan 24, 2010 5:30 am    Post subject: Z-13/20 questions Reply with quote
Joe,
Thank you very much for your comments (see response below), you've helped me
improve my design. I made changes to the power distribution schematic and
reposted the dirgram at http://kr.flyboybob.com/kr2/wd0004.htm
Bob Lee
N52BL KR2
Suwanee, GA USA
<< The jumper from that contact to the relay coil was omitted. It's been
fixed. >>
<< Years ago I scored a bunch of AN-3160 circuit breaker switches for a
buck each at Oshkosh. The symbol you identified as a fuse is in reality a
guarded circuit breaker switch. As the note on the diagram states it is the
E-bus alternate feed path. If the E-bus goes dark, open the guard and flip
the alternate feed breaker. If the primary path E-bus feed through the
diode is dark I don't see the backfeed issue as problematic. >>
<< I just looked at Z-31B again and realized what I did. I put the diode
across the relay like a battery contactor. It's been fixed >>
power plug?
<< The breaker is in the ground path to the over voltage crowbar. The
ground symbol was up in the crowbar area. I moved it down to the circuit
breaker. I also changed the breaker to 2 amp rating per Z-31B. >>
grounded?
<< The relay is actually the starter realy that coincidently controls the
fuel injection cold start circuit. That is why it is on the hot side. I
changed the cross connect light circuit to get it's power from the cross
connect contactor. >>
mrspudandcompany(at)veriz
PostPosted: Sun Jan 24, 2010 6:49 am    Post subject: Z-13/20 questions Reply with quote
Bob Lee
In taking a quick look at your diagram, it appears that your cross feed
contactor will not work. You seem to have both sides of the contactor tied
together and through a switch (start/xfeed switch) to ground. When you
power this up a diode will vaporize.
I haven't looked over the rest of the drawing.
Roger
PostPosted: Sun Jan 24, 2010 8:10 am    Post subject: Z-13/20 questions Reply with quote
AeroElectric-List message posted by: "Bob Lee" <flyboybob1(at)gmail.com>
Yes . . . it was not a well considered or tested
recipe for success at the time of publication.
electrically dependent engine, I also have a design goal of no single point
independent power supply.
There is risk associated with cherry-picking features
from multiple recipes for the purpose of crafting a new
recipe. It begs to be sifted for the effects of single
failures (if flight for hire or transport, double failures
along with probability analysis). Finally, the value of
a new recipe is traded against existing recipes for addressing
design goals not easily addressed in existing recipes. Z13/20
was crafted and published without due diligence to these
processes.
I submitted a wiring diagram that you stated you were "praying over"
a while back. Seems like I have fallen into an area similar to
Z-9 was crafted to meet design goals offered by "Mr. Corvair
Engines" and fine tuned to adopt legacy design goals for failure
modes. Conversion packages for the VW would have similar electrical
system issues as the Corvair. You've stated that you found Z13/8,
Z-14 and I guess Z-9 inadequate to your design goals.
Cruising your website offers and impression that your
goals for the KR-2 are indeed extra-ordinary. I didn't
have time to read all the details so correct me if I'm
wrong . . . this is a highly experimental endeavor that
uses a lot of designs and hardware from projects never
before assembled in this combination on a single airplane . . .
much less multiple airplanes.
Not necessarily a "bad" idea. But it does suggest a long
list of risks requiring a "fine-tuning" of the airplane before
you can confidently launch on a series of long distance
travels with high probability of care-free arrivals.
This is not your grandpa's C-170. It will certainly test
your skills as a multi-discipline, flight test engineer.
From one who has participated in the flight testing and
product development of very complex airplanes
I can only caution that $time$ to test, de-bug, and
re-design seems to go up with the exponentially
with the number of "new ingredients" in your recipe
for success. Of course, given the unforgiving nature
of the aerodynamically supported machines, one hopes
that new de-bugging tasks are not displaced by
issues involving bent airplanes and/or broken bods.
You can see my wiring diagram at: http://kr.flyboybob.com/kr2/wd0004.htm
This is a busy electrical system. It has virtually
no legacy of design goals that birthed the Z-figures and
is essentially a scratch design. It would take hours
of conversation and mulling features to first understand
why the system is designed this way and then ratify
the ideas or suggest alternatives. This is something
I cannot offer right now as I have more than I can
handle for consulting clients already on the schedule.
My best suggestion is that you adopt Z-13/8 as a
system that gets its reliability from
simplicity. My sense is that you are going to have
a great deal on your plate getting other, much
more risky details ironed out. Electrical SYSTEM
failures are VERY SELDOM root cause of an unplanned
arrival with the earth. Z-13/8 with a well maintained
battery offers a rock solid energy generation and
delivery platform. "Stirring" the recipe only adds
risk for design error and complexity driven risk.
I'm working an accident right now that happened
for reasons involving a stirring of the recipe.
An expensive, complex airplane carrying people
hit the dirt for rudimentary lapses in judgement
about electrical system architecture. There was
always plenty of POWER available . . . but poorly
conducted to critical components.
I wish you well with your project. It's my
best recommendation that you don't stack electrical
uncertainties on top of the tasks before you.
PostPosted: Sun Jan 24, 2010 8:41 am    Post subject: Z-13/20 questions Reply with quote
Roger, I don't think you saw the cross connect light between ground and the
cross connnect contactor positive. The cross connect light will limit
current and prevent the diodes from vaporizing (assuming light and diode
component values are sized appropriately).
Bob Lee
N52BL KR2
Suwanee, GA USA
PostPosted: Sun Jan 24, 2010 10:11 am    Post subject: Z-13/20 questions Reply with quote
Bob Lee
My mistake, however, unless I am wrong again you will have
the cross feed actuated whenever the battery masters are turned on due to
the jumper between pins 1 & 3 of your Start/Xfeed switch.
Roger
winmail.dat
 Filename:  winmail.dat
 Filesize:  3.34 KB
 Downloaded:  520 Time(s)
Bob McC
PostPosted: Sun Jan 24, 2010 10:41 am    Post subject: Z-13/20 questions Reply with quote
Hi Roger;
Different Bob, but the starter/Xfeed switch depicted is a three position switch and with the switch in thecentre position which is presumably intended to be thenormal position the Xfeed is Off.
Bob McC
_____________________________________________
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com (owner-aeroelectric-list-server(at)matronics.com)] On Behalf Of ROGER & JEAN CURTIS
Sent: Sunday, January 24, 2010 1:08 PM
Subject: RE: Re: Z-13/20 questions
Bob Lee
      My mistake, however, unless I am wrong again you will have the cross feed actuated whenever the battery masters are turned on due to the jumper between pins 1 & 3 of your Start/Xfeed switch.
      Roger
Bob McC
Falco #908
(just starting)
