Conduit abrasion
Phil.Perry(at)netapp.com
PostPosted: Tue Jan 19, 2010 8:43 am    Post subject: Conduit abrasion Reply with quote
This morning I shot a quick video describing some of my questions regarding abrasion protection of conduit.
http://www.youtube.com/watch?v=saRUrF2vtMI
In 1990, we used text and thought it was great. In 2000, it was the cherry on top if you could send digital photos. Now it’s 2010 and video is where we are. On a side note, what’s 2020?
Phil
Strasnuts
PostPosted: Tue Jan 19, 2010 9:20 am    Post subject: Re: Conduit abrasion Reply with quote
Here are some pics of mine. I did a similar setup but used two on each side instead of three. I cut my holes close tolerance under the seats and wrapped caterpillar grommets around them. The exiting holes are so tight they can't move. I stuffed two lines in one hole wrapped again with the grommet.
Maybe I will abrasion tape around the step where they contact the conduit like you stated.
 Filesize:  561.22 KB
 Viewed:  3442 Time(s)
 Filesize:  604.89 KB
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
PostPosted: Tue Jan 19, 2010 1:09 pm    Post subject: Conduit abrasion Reply with quote
Hey Sean,
I'm planning to add the tape to the conduit and not to the step...
As tight as those steps are, I can only imagine how hard it will be to
pull the step and tape through the mount.
Phil
Strasnuts
PostPosted: Tue Jan 19, 2010 1:15 pm    Post subject: Conduit abrasion Reply with quote
Good point. That would kind of take away the reason to make the plate to
make the step removable.
780 Hours
SuperSTOL 60 hours
